Fourtitude.com - Sunroof sticking when opening
    Results 1 to 7 of 7
      Jul 1st, 1999
      12,101
      Blog Entries
      1
      04-25-2013 07:42 PM #1
      I noticed my sunroof has began to stick when opening. I cleaned the rubber seal around the opening, but was wondering if any one could share maintenance or lubrication points so I don't end up with a seized sunroof.
      Thank you.
      Jul 1st, 1999
      12,101
      Blog Entries
      1
      04-26-2013 05:10 PM #2
      Any one?
    4. 04-26-2013 05:44 PM #3
      I've had mine repaired 3 times. My motor is currently out. I've removed the fuse and wont repair it again.
      I used it every day.
      These broke several times.
      Quote Originally Posted by nm+ View Post
      Time to give up and buy a horse.
    5. Member
      Jul 1st, 1999
      12,101
      Blog Entries
      1
      04-26-2013 05:45 PM #4
      Quote Originally Posted by Rogerthat View Post
      So what happened? It got stuck (like mine) and you kept powering the switch and it eventually gave way and snapped/broke?
    6. 04-26-2013 05:50 PM #5
      The things that snapped off prevented it from closing properly. I had to make sure they were positioned correctly before closing. The sticking while opening was the motor going out. I would eventually get it open but the very last time I did I had to manually close it. That's when I pulled the plug.
      Jul 1st, 1999
      12,101
      Blog Entries
      1
      04-26-2013 07:31 PM #6
      Sorry to hear. I don't use my sunroof all that often. Since cleaning the rubber seal I noticed it doesn't stick like it was. Maybe I solved my own problem.
      Jul 1st, 1999
      12,101
      Blog Entries
      1
      04-30-2013 01:47 PM #7
      It's sticking again. Does anyone have a lubrication point(s) for our dual panoramic sunroof? That would be most helpful.
      TIA.
