Fourtitude.com - *TECH DISCUSSION* Turbo intake piping size...when does it become a restriction?
    Results 1 to 17 of 17
    1. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,664
      A founding Member of the 8v 350+whp Club, Now rocking a B7 S4 600whp V8!
      03-27-2013 08:04 AM #1
      Say you have a 60mm turbo with a 4" anti surge inlet...
      But you only have space to run a 3" pipe.
      How much air can a 3" diameter 24"long or 36" long pipe support?
      I'd imagine so long as the pipe can support more CFM than the turbo is rated for you're good...right?
    3. Member wabbitGTl's Avatar
      Jan 1st, 2007
      Indianapolis
      1,502
      95 GTI VRT, E46 Touring
      03-27-2013 10:58 AM #2
      Quote Originally Posted by chucchinchilla View Post
      People spec their Porsche cars like they select bottles of wine when going on a date. Few people want to be the guy buying the cheapest bottle on the menu. The rest, like myself, realize they'll be just as happy (and just as laid) buying the cheapest. Garcon, one base Carrera for me please.
    4. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      4,460
      03-28-2013 01:06 AM #3
      I just follow the same as the expected limits for exhausts.
      2" 300hp
      2.5" 500hp
      3" 700hp
      3.5" 900hp
      But in reality, as big as can possibly fit.
      Think about it this way, the anti surge inlet is larger to accommodate the porting around the wheel. I would bet you could drop down to the size of the inducer and be ok for the full flow.
      Sent from my SCH-I535 using Tapatalk 2
    6. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,664
      03-28-2013 01:14 AM #4
      Quote Originally Posted by Pat @ Pitt Soundworks View Post
      2" 300hp
      2.5" 500hp
      3" 700hp
      3.5" 900hp
      so in reality it could be a little more due to the fact exhaust tends to be much longer than 3ft or less...unless you be one dem drraaaaaag cars
    7. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      4,460
      03-28-2013 01:16 AM #5
      Well also hot rod magazine proved even a 500whp supra saw a 50whp gain from going to a 3.5" from a 3" exhaust. And 100whp at the 700ish hp level. But you're right, length makes a difference.
      I'd be really interested in seeing the mathematics behind it, though.
    8. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,664
      03-28-2013 03:12 AM #6
      i remember that issue.
      Yea i'd love to see the math as well and how turbos are affected by smaller intake paths...
    9. 03-28-2013 04:37 PM #7
      I would say to avoid going smaller than the inducer diameter is a good, practical rule of thumb. Practical because the compressor housings usually have a decent contraction upstream of the rotor inducer and this let's you drop down a pipe size or two for fitment concerns and still have some margin left over. For example, my to4s cover at 4" houses a 2.4" inducer
      The only penalty you will pay in going with a somewhat undersized pipe is that you will have higher pressure loss upstream of the compressor so the compressor will have to work harder to reach your target boost pressure. The downside to this of course is increased heat load on the intercooler, radiator, and additional backpressure on the exhaust (turbine has to work harder to turn the compressor). In terms of length vs. diameter; losses scale linearly with length and squared with diameter, so a longer pipe of a greater diameter is better than short and small diameter.
      As far as the mathematics go, the compressor flow function (horizontal axis on compressor map) is dominated by the inducer relative inlet Mach number^2 and rotor passage area. This is why compressor maps are a strong function of what we call "corrected speed" and turbine maps are nearly independent of rotor speed (need to increase a/r to increase flow/drop back pressure, can't just spin it faster ).
    10. 03-28-2013 10:02 PM #8
      Upon researching for my own behalf I came across this and would be a perfect add to this thread..
      *.4 Mach is the point at which air becomes turbulent and losses in efficiency start to occur exponentially. The key is to stay under that speed. You want to use the smallest piping possible that still flows enough to meet your needs. Larger than necessary piping increases lag time with no measurable gain
      The velocities are in miles per hour and mach, and the flow rates are in cfm. Measurements for the piping are in inches.
      2" piping
      1.57 x 2 = 3.14 sq in
      300 cfm = 156 mph = 0.20 mach
      400 cfm = 208 mph = 0.27 mach
      500 cfm = 261 mph = 0.34 mach
      585 cfm max = 304 mph = 0.40 mach
      2.25" piping
      3.9740625 sq in = 1.98703125 x 2
      300 cfm = 123 mph = 0.16 mach
      400 cfm = 164 mph = 0.21 mach
      500 cfm = 205 mph = 0.26 mach
      600 cfm = 247 mph = 0.32 mach
      700 cfm = 288 mph = 0.37 mach
      740 cfm max = 304 mph = 0.40 mach
      2.5" piping
      4.90625 sq in = 2.453125 x 2
      300 cfm = 100 mph = 0.13 mach
      400 cfm = 133 mph = 0.17 mach
      500 cfm = 166 mph = 0.21 mach
      600 cfm = 200 mph = 0.26 mach
      700 cfm = 233 mph = 0.30 mach
      800 cfm = 266 mph = 0.34 mach
      900 cfm = 300 mph = 0.39 mach
      913 cfm max = 304 mph = 0.40 mach
      2.75" piping
      5.9365625 sq in = 2.96828125 x 2
      300 cfm = 82 mph = 0.10 mach
      400 cfm = 110 mph = 0.14 mach
      500 cfm = 137 mph = 0.17 mach
      600 cfm = 165 mph = 0.21 mach
      700 cfm = 192 mph = 0.25 mach
      800 cfm = 220 mph = 0.28 mach
      900 cfm = 248 mph = 0.32 mach
      1000 cfm = 275 mph = 0.36 mach
      1100 cfm max = 303 mph = 0.40 mach
      3.0" piping
      7.065 sq in = 3.5325 x 2
      300 cfm = 69 mph = 0.09 mach
      400 cfm = 92 mph = 0.12 mach
      500 cfm = 115 mph = 0.15 mach
      600 cfm = 138 mph = 0.18 mach
      700 cfm = 162 mph = 0.21 mach
      800 cfm = 185 mph = 0.24 mach
      900 cfm = 208 mph = 0.27 mach
      1000 cfm = 231 mph = 0.30 mach
      1100 cfm = 254 cfm = 0.33 mach
      1200 cfm = 277 mph = 0.36 mach
      1300 cfm max= 301 mph = 0.39 mach
      In order to convert from Lb/Min to CFM for the equation above, you take the flow rate in Lb/Min for your turbo (generally an educated guess based on the pressure ratio and power created) and multiply it by 14.27. That will yield the CFM flow for your setup.
      For Example:
      T3/T04e 57trim .63ar @ 21psi makes 452 whp
      This turbo is known to have a 50lb/min compressor wheel which will make ~500bhp. Since we're using whp above, we can assume this turbo is pretty close to its max of 50lb/min.
      Now to convert that to CFM, you take 50lb/min x 14.27 = 713.5 CFM. When you refer to the table above, you can see that we're starting to max 2.25" piping, but we're still in the "good" range for 2.5"
      but it also depends on how smooth the piping is inside... and all the bends. this i would say is " perfect piping conditions" and if you would pick a number to upsize your piping at it would be when you hit about the .3 maximum .35 mach region.
      d.i dubinvasion.co
    11. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      4,460
      03-28-2013 10:07 PM #9
      For intakes that appears to work. I wonder how pressure affects this. There's a local evo that makes 500whp on a mustang and uses all 2" piping.
    12. 03-28-2013 11:35 PM #10
      The calculations posted above are based on volume flow (CFM, not lbm/min) so the pressure does not have an impact. If you wanted to do the same calculations downstream of the compressor you would have to account for the fact that the speed of sound is proportional to temperature, so as the air temp goes up so does the speed of sound. You would also need a new conversion factor to get from CFM to lbm/min since the air density would also be different (this is where pressure comes in). Obviously post compressor where densities are higher you can flow more through a given pipe size, so 2" boost piping is less of a restriction than 2" intake piping (for similar length pipes).
      One more thing... the "Mach 0.4" guideline doesn't really have much to do with turbulence. It's true that losses do increase proportional to Mach (or velocity) squared, but whether you draw the line at Mach 0.3, 0.4, 0.5 it's really only a judgment call. Keep in mind that the calculations above are using an "average" Mach number to compute CFM but in pipe flow the maximum air speeds are really ~twice the average (in a laminar flow, slightly less for turbulent) so even at the computed Mach 0.4 the centerline pipe velocity is significantly higher.
    13. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,664
      03-29-2013 09:55 AM #11
      good reading in here
    14. Member skydaman's Avatar
      Dec 16th, 2005
      NoVa
      12,260
      03-29-2013 09:41 PM #12
      Race cars dont have intakes or filters on their turbo's... let it eat! I dont have room for an intake because I kept functioning A/C plus there is no real need for one. I don't notice any downsides in spool time, horsepower level, or performance compared to those who run 3", 4" piping to a filter or even those who run a filter right on the turbo. I'm currently running a 59mm, no anti surge, 24-25lbs.
    15. 03-30-2013 07:57 AM #13
      Not sure about intake but as far as charge pipe I think most tuners tend to over do it with size not realizing there losing velocity which equates To slower spool wether it be 700-300rpm. I chose 2 1/4 to aid a bit with reaction and to combat a bit of lag. Not so much in our scene I see it, but I've seen so many cars with 3" charge pipes pushing 250-350hp.. Over kill
      d.i dubinvasion.co
    16. Member 05JettaGLXVR6's Avatar
      Jan 24th, 2006
      Annapolis, MD/Stockblocks, NJ
      4,211
      03-30-2013 09:11 PM #14
      Quote Originally Posted by skydaman View Post
      My car loses a few MPH intake (out the headlight) Vs. No intake
    17. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,664
      03-31-2013 05:00 AM #15
      Quote Originally Posted by 05JettaGLXVR6 View Post
      maybe because removal of the headlight is causing alot of turbulence throughout the engine bay when moving? Or you have one dem fancy fully sealed deals with the bellmouth and all?
      Pics?
    18. 04-17-2019 03:19 PM #16
      that's really neat to learn! i feel like you always hear bigger is better
      24v VR club
    19. Member V-dubbulyuh's Avatar
      Nov 13th, 2005
      4,910
      Mk3 VRT, Mk4 VRT, Mk4 VRT, A3 VR QT, B6 3.6 4Motion, B5 1.8BT, B5 Avant QT VRT
      04-22-2019 02:48 PM #17
      Quote Originally Posted by 35i 2000 View Post
      Isn't that what he's saying though?
      To: 3.5"
      From 3.0"
      Net = performance gain
      "OP sounds like a MKIV guy"
