Fourtitude.com - "Re-Code Invalid" and other newb VCDS questions
    Results 1 to 7 of 7
    1. 10-22-2012 12:02 AM #1
      New user to VCDS, please don't shoot me! I searched a few places for this "Re-Code Invalid" error but I seem to be drawing a blank. I tried to do some long coding changes on my car and I keep getting this "Re-Code Invalid" error. "This appears to be an uninitialized control module; valid WSC/Importer/Equipment data may be required. Yes for VCDS to us default values of 12345/123/12345, no for VCDS to try the values in the modules, Cancel to go back and manually edit the values.
      What does this error mean? Did I not set something in VCDS correctly before I tried to save them the new code, or is this the generic what I tried to change the module does not support error?
      Lastly, when I am doing changes to the modules, what state should the ignition be in? I have KESSY so my only real options are motor running, or not.
      Car is a 2011 Jetta, TDI, DSG, Highline w/o Nav.
      Thanks!
      ~Brian
    3. 10-22-2012 07:43 AM #2
      I would suggest starting at the beginning. Read the sticky thread in this forum, "Read This Before Posting..." so you don't feel the need to apologize for being new. Also, you'll know that post coding questions without a full auto scan is gets us nowhere and gets you nowhere.
    4. 10-22-2012 09:30 AM #3
      Since it was happening for any coding change I was trying to make I thought it was a most likely a "generic" operator error.
      Here is my scan:
      VCDS Version: Release 11.11.4
      Data version: 20120807
      Sunday,21,October,2012,16:40:06:23762
      Chassis Type: 6N0
      Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 44 56 77
      VIN: 3VWLL7AJ0BM006916
      01-Engine -- Status: OK 0000
      02-Auto Trans -- Status: OK 0000
      03-ABS Brakes -- Status: OK 0000
      04-Steering Angle -- Status: OK 0000
      05-Acc/Start Auth. -- Status: OK 0000
      08-Auto HVAC -- Status: Malfunction 0010
      09-Cent. Elect. -- Status: Malfunction 0010
      15-Airbags -- Status: OK 0000
      17-Instruments -- Status: OK 0000
      19-CAN Gateway -- Status: OK 0000
      25-Immobilizer -- Status: OK 0000
      2B-Steer. Col. Lock -- Status: OK 0000
      2E-Media Player 3 -- Status: OK 0000
      44-Steering Assist -- Status: OK 0000
      56-Radio -- Status: Malfunction 0010
      77-Telephone -- Status: OK 0000
      Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
      Part No SW: 03L 906 022 PB HW: 03L 906 019 DA
      Component: R4 2,0L EDC G000AG 8216
      Revision: 12H08--- Serial number: 00000000000000
      Coding: 0050078
      Shop #: WSC 00066 000 00000
      VCID: 74C904BD17E7FDB835D
      No fault code found.
      Readiness: 0 0 0 0 0
      Address 02: Auto Trans Labels: 02E-300-0xx.lbl
      Part No SW: 02E 300 052 G HW: 02E 927 770 AL
      Component: GSG DSG AG6 511 2267
      Revision: 05151112 Serial number: 00001006100975
      Coding: 0000020
      VCID: 1811100D2BCF79D8F95
      Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
      Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
      Component: ESP MK60EC1 H30 0105
      Revision: 00H30001
      Coding: B14B400C492200008D1402E5921F0042210000
      VCID: 8429D47D07474D3885D
      Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
      Part No SW: 5K0 959 434 A HW: 5K0 959 434 A
      Component: VWKESSYPQ35GP 085 0708
      Revision: 00085000 Serial number: 0137798023
      Coding: 030C0C
      ASAM Dataset: EV_KESSY_PQ35GP A01010
      ROD: EV_KESSY_PQ35GP_VW36.rod
      VCID: 334BC7A19A69BA80EC7
      Address 08: Auto HVAC Labels: 5C0-820-047.clb
      Part No SW: 5C0 820 047 L HW: 5C0 820 047 L
      Component: J301 Klimaanlage 0103
      Revision: 2000908S Serial number: 00000000036072
      Shop #: WSC 91426 999 11688
      VCID: 297725C980A5F05056B
      1 Fault Found:
      01314 - Engine Control Module
      004 - No Signal/Communication - Intermittent
      Freeze Frame:
      Fault Status: 00100100
      Fault Priority: 6
      Fault Frequency: 2
      Reset counter: 100
      Mileage: 25607 km
      Time Indication: 0
      Date: 2024.14.17
      Time: 00:00:10
      Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
      Part No SW: 5C0 937 087 C HW: 5C0 937 087 A
      Component: BCM25 JLB H3 H66 0226
      Revision: B2066001 Serial number: 03311236100019
      Coding: 73994B9A08230F0008382000240884C50082502E6000000030 A000000000
      VCID: 2D7FD1D9744DEC70BA3
      Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
      Component: J386__TSG_FT 002 3462
      Coding: 820000
      Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
      Component: J387__TSG_BT 002 3462
      Coding: 820000
      Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
      Component: J245 PS41.019 H08 0006
      Coding: 180000
      Subsystem 4 - Part No SW: 5K0 959 542 HW: 5K0 959 542
      Component: E221__MFL-TAS H05 0010
      Coding: 020000
      Subsystem 5 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
      Component: J388__TSG_HL 002 3462
      Coding: 800000
      Subsystem 6 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
      Component: J389__TSG_HR 002 3462
      Coding: 800000
      3 Faults Found:
      01758 - Bulbs for Brake Lamps
      011 - Open Circuit - Intermittent
      Freeze Frame:
      Fault Status: 00101011
      Fault Priority: 2
      Fault Frequency: 254
      Reset counter: 91
      Mileage: 24810 km
      Time Indication: 0
      Date: 2023.14.14
      Time: 08:05:33
      00901 - Back-Up Lamps
      Freeze Frame:
      Fault Priority: 3
      Fault Frequency: 1
      Reset counter: 91
      Mileage: 0 km
      Time Indication: 0
      Date: 2023.14.22
      Time: 14:12:47
      00329 - Control Circuit for Unlocking Rear Lid
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 4
      Reset counter: 91
      Mileage: 24812 km
      Time Indication: 0
      Date: 2023.14.21
      Time: 15:10:32
      Address 15: Airbags (J234) Labels: 5K0-959-655.clb
      Part No SW: 5C0 959 655 HW: 5C0 959 655
      Component: AirbagVW10G 012 0805
      Serial number: 003END07A4L9
      Coding: 00003232
      ASAM Dataset: EV_AirbaVW10SMEVW360 A01017
      ROD: EV_AirbaVW10SMEVW360_VW36.rod
      VCID: EFC38BD136C15E6048F
      Seat occupied recognition:
      Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
      Component: BF-Gewichtss. H10 0027
      Serial number: 6940000Y100000096F0+
      Coding: 303143
      Crash sensor for side airbag; driver side:
      Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
      Component: S.Sens.Fahr.V H01 ----
      Serial number: 3572MSME2D764254ZZZ-
      Crash sensor for side airbag; passenger side:
      Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
      Component: S.Sens.Beif.V H01 ----
      Serial number: 3582MSME59432054ZZZQ
      Crash sensor for side airbag; rear driver side:
      Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
      Component: S.Sens.Fahr.H H01 ----
      Serial number: 3516KSME05406208ZZZE
      Crash sensor for side airbag; rear passenger side:
      Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
      Component: S.Sens.Beif.H H01 ----
      Serial number: 3526KSME451D5B08ZZZ.
      Crash sensor for front airbag; driver side:
      Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
      Component: F.Sens.Fahr H01 ----
      Serial number: 3556LSME44510308ZZZJ
      Crash sensor for front airbag; passenger side:
      Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
      Component: F.Sens.Beif H01 ----
      Serial number: 3566LSME7A4F0308ZZZ%
      Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
      Part No SW: 5C6 920 850 C HW: 5C6 920 850 C
      Component: KOMBI H07 0406
      Coding: 370A00
      Shop #: WSC 00066 000 00172
      ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
      ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
      VCID: 297725C948A5F05056B
      Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
      Part No SW: 6N0 909 901 HW: 5C0 937 087 A
      Component: GW-K-CAN TP20 0226
      Coding: 102200
      VCID: F0C188AD23FF4198515
      Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
      Part No SW: 5K0 953 234 HW: 5K0 953 234
      Component: IMMO H07 0406
      Coding: 000007
      Shop #: WSC 20200 993 55045
      ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
      ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
      VCID: EAF59AC50D23BB481F1
      Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
      Part No SW: 5K0 905 861 HW: 5K0 905 861
      Component: ELV-PQ35 018 0120
      Revision: 00000000 Serial number: 10000117888005
      Coding: 0900000000000000
      ASAM Dataset: EV_ELVMarquVW360UDS A01003
      ROD: EV_ELVMarquVW360UDS_VW36.rod
      VCID: EDFF91D93CCDAC707A3
      Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
      Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
      Component: SG EXT.PLAYER H13 0111
      Revision: A1001003 Serial number: 7668368090
      Coding: 010000
      VCID: 277323F156B1C62040F
      Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
      Part No: 1K0 909 144 J
      Component: EPS_ZFLS Kl. 70 3001
      Revision: 00H17000
      Shop #: WSC 02069 000 90108
      VCID: 3147CDA9A87588909EB
      Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
      Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
      Component: Radio Prem-8 H13 0043
      Revision: -----26S Serial number: VWZ4Z7K3110695
      Coding: 2100040002
      VCID: 61E77DE9781578104EB
      1 Fault Found:
      02635 - Tuner Not Enabled/Activated
      000 - -
      Freeze Frame:
      Fault Status: 01100000
      Fault Priority: 7
      Fault Frequency: 1
      Reset counter: 111
      Mileage: 16513 km
      Time Indication: 0
      Date: 2017.14.16
      Time: 18:22:11
      Address 77: Telephone (J412) Labels: 7P6-035-730.clb
      Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
      Component: TELEFON H05 0440
      Revision: 1B001001 Serial number: 00007668236835
      Coding: 0A00000000010100
      Shop #: WSC 01383 790 50316
      ASAM Dataset: UHVNA A01007
      ROD: UHVNA_VW36.rod
      VCID: 3245C2A56573B388E71
      End ---------------------------------------------------------------------
    6. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      2,907
      02 Gti, 12 Tiggy SEL
      10-22-2012 10:12 AM #4
      Due to the modules with all zero WSC/Importer/Equipment numbers VCDS will produce that warning. This example is shown when attempting adaptation: http://www.ross-tech.com/vcds/tour/s.../adp-error.png
      WSC/Imp/Equip. numbers are explained in more detail on the following page of our interactive manual:
      http://www.ross-tech.com/vcds/tour/o...creen.html#WSC
      Click [Yes] or manually type in non zero values and providing the new coding is valid, the controller should accept it.
      Dana Marie
      P.S. No Scan = No Soup
    7. 10-26-2012 01:40 AM #5
      Thanks Dana! I spent far to long in the car with the laptop tonight and that worked great.
      The only thing that I could not figure out was how to make all the doors unlock from one press of the remote, or most importantly, from the drivers door handle (my car has KESSY)
    8. 02-12-2020 06:14 PM #6
      i can help i have golf v i want to turn on the puddle light and this pops up can help me some
      This equipment number is invalid! Equipment number must be 5-6 digits: 00000-262143
    9. Member cuppie's Avatar
      May 3rd, 2005
      Redford, MI
      4,300
      88 Scirocco 16v (Wilda); 02 Passat 1.8T wagon (the Brick); 09 Jetta Sportwagon (wife's.) Past: lots
      02-14-2020 06:22 PM #7
      Quote Originally Posted by Semir1a View Post
      Well, you're doing it wrong. You need to change the coding in the door modules, not the equipment number.
      To verify:
      You're doing puddle lights (the ones on the mirrors)? Or, entry (ground) lights (the ones on the bottom of the door panels)?
      In any event, the codding helper in VCDS will tell you what value in the door module coding needs to be changed. Hover your mouse over the current coding value, and a tooltip balloon will display. Note the "+xx" value for the feature that you're adding.
      Add that number to the current coding value. Enter the new value. Click <Do it!>
      - Cup
      '88 Scirocco 16v, 'tastefully' modified.
      '02 Passat 1.8T (The Brick.)
      things currently broken (Scirocco): 4
      things currently broken (Passat): 2
