Fourtitude.com - **USRT Fueling Solutions Presents: The Genesis II Injector**
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 78
    1. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,667
      A founding Member of the 8v 350+whp Club, Now rocking a B7 S4 600whp V8!
      10-21-2012 11:31 AM #1
      With 500hp and 11sec track times becoming a new "norm" nowadays and gasoline prices inflating to consume whole paychecks, it's about time that hardcore builders had something their wallets might actually thank them for.
      With that we introduce an affordable, fuel efficient, and otherwise SUPERIOR fuel injector line for big turbo builders. The Genesis II injector is available now in 500cc, 630cc, 1000cc, 1600cc, and 2000cc flavors. It is specifically matched to the VW/Audi engine platforms and can be fitted to other makes and models as well.
      The Genesis II injectors feature Advanced Atomization Technology yet also big flow. Simply put, they’re a tuning weapon. Features also include wide-angle single cone or dual stream spray patterns with vapor/mist-like qualities. Cycle response time is super-fast with minimal dead time. No other product line combines this level of refinement with brute strength.
      Radically tiny droplets are aimed directly at the intake valves avoid wall-wetting. Superior atomization of the air/fuel mixture is guaranteed even with huge bore sizes and cold air. Thus, these injectors are exceptionally easy to dial in and tune. The result is improved fuel economy, faster turbo spool, more low-rpm torque, gains in peak horsepower, and buttery smooth DRIVABILITY. Demand support for Genesis II injectors from your software tuner today!
      1000cc Flow at 3bar base pressure is perfect to support power in the mid-500s with 1.8T engine or 800s with R32.**
      from [email protected] on Vimeo.
      1600cc Flow at 3bar base pressure is perfect to support about 600hp with 1.8T engine on e85 or over 1000 with R32.##**
      2000cc Flow at 3bar base pressure is perfect to support about 800hp with 1.8T engine on e85 or over 1200 with R32.##**
      **Up to 8bar rail pressure has been proven safe to take output even higher on each injector size.
      ##Do NOT run with Q16 fuel or in extremely high-heat conditions.**
      CLICK PHOTOS FOR MORE INFO AND ORDERING:
    3. Member sp_golf's Avatar
      Nov 28th, 2007
      Toronto
      4,032
      88 Golf 16vT
      10-21-2012 12:10 PM #2
      Do the 2000ccs fit on a 12v VR?
    4. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,667
      10-21-2012 01:16 PM #3
      Yes. The 2000cc will fit Mk2/3 VR6. Mk4 would require a manifold swap.
    6. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,667
      10-22-2012 01:05 PM #4
      So earlier this [email protected] swapped out the standard EV14 550cc injectors for a set of Genesis II [email protected]
      Here are the results:
      Numbers speak for themselves and if not the numbers then the drastic change in the area under the curve should definitely speak volumes.
    7. Member speed51133!'s Avatar
      Aug 5th, 2002
      alexandria va/milwaukee wi
      7,695
      02 audi tt 225 / mk3 jetta /audi 5000s turbo
      10-22-2012 09:44 PM #5
      I have a unitronic tune for siemens 630cc injectors. Can i just swap them out for these?
    8. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,667
      10-22-2012 10:38 PM #6
      Quote Originally Posted by speed51133! View Post
      Yes, you can.
    9. 10-26-2012 10:07 PM #7
      Nice
      I ran the old Genesis 550's at 4 bar on my old 1.8t BT, and they were amazing!
      These are even better?
      Quote Originally Posted by gdoggmoney View Post
      There's been too much butt sniffing before this dog fight.
      PagPartsTurbo www.speeding-g60.com INTEGRATEDengineering
    10. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,667
      10-26-2012 10:23 PM #8
      even better
    11. 10-26-2012 10:54 PM #9
      even better
      How is that even possible?
      Are they machined from unicorn horns?
    12. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,667
      10-26-2012 11:21 PM #10
      Quote Originally Posted by Rod Ratio View Post
      Elves....thats all u need to know
    13. 10-27-2012 12:09 AM #11
    14. 11-01-2012 12:10 AM #12
    15. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,667
      11-06-2012 11:00 AM #13
      got Fuel?
    16. Junior Member
      May 13th, 2012
      Boynton Beach, FL
      50
      1997 VW Jetta TDi
      11-15-2012 05:57 PM #14
      I think I'm going to order a set of these, I just have to decide on whether I want 1600's or 2000's. hmmm
      '08 BMW 335i
      '97 Jetta TDi 16v ABA PT6266
      '97 BMW M3/4 S366 3.0l Frankenstein
    17. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,667
      11-15-2012 10:55 PM #15
      power goals? fuel type?
    18. Junior Member
      May 13th, 2012
      Boynton Beach, FL
      50
      1997 VW Jetta TDi
      11-16-2012 12:09 AM #16
      500whp to start. I'll be running E85. I want room to grow, At some point I'd like to get into 700whp range.
      '08 BMW 335i
    19. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,667
      11-17-2012 06:59 AM #17
      Quote Originally Posted by BoostingSlow View Post
      pm me build details
    20. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,667
      12-22-2012 10:34 PM #18
      Happy Holidays!
    21. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,667
      01-27-2013 03:26 PM #19
      1000cc sellin like hotcakes!
    22. 01-31-2013 10:44 PM #20
      Hello,
      Do you have any USRT wire harness relay for fuel pump in stock. I need one asap. your Inbox is full, sorry for thread jacking.
      Thank you,
    23. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,667
      01-31-2013 11:04 PM #21
      Quote Originally Posted by 514passatvr6 View Post
      Hello,
      Thank you,
      pm'd
    24. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,667
      02-07-2013 08:33 AM #22
      big ups...
    25. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,667
      02-07-2013 12:47 PM #23
      brought over from the 1.8t forum thread....
      Quote Originally Posted by spartiati View Post
      Here's a log of my 630's dialed in. I've been keeping boost to a minimum because of the need to upgrade my fuel pump (USRT INTANK PUMP PLEASE!)lol. Genesis Intank isn't keeping up with the flow demands at 350+whp. You can see the dangerously high Injector pulsewidth in the higher rpms. I've since dropped to 12psi until I get the fuel pump situation worked out.
      With that said After going from the Deka 630's to the G2 630's idle is rock solid. No stumbling or anything like that. Driveability is far better than the Deka's.
      I will note that the superior atomization helps reduce the knock correction. On average I'm seeing 1.5*-3* less corrections. Great product guys. This can/will translate into alittle more power.
      For the record that is my ignition timing on 93oct with water meth.
      The GenI pump did what it was designed to do, he will now need the upcoming GenII pump to satisfy his engine's thirst...
    26. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,667
      04-29-2013 08:31 PM #24
      380cc added to the lineup!
    27. Forum Sponsor
      Oct 6th, 2009
      Around the world
      2,667
      05-01-2013 09:51 PM #25
      Ok so i made a boo-boo the new injectors are **330cc***. They are E85 compatible.
