Fourtitude.com - My car sounds like it's screaming bloody murder..Any clue what it is?
    Results 1 to 25 of 39
      Jul 1st, 1999
      12,101
      Blog Entries
      1
      06-14-2012 09:21 AM #1
      This randomly began on my way to work. It's extremely loud. Any idea what this may be? I took a short video of the sound. Thanks in advance.
      Link to video: http://www.youtube.com/watch?v=gteaklCYpgg
      Jul 1st, 1999
      12,101
      Blog Entries
      1
      06-14-2012 09:28 AM #2
      Failed water pump?
    4. Member JRutter's Avatar
      Nov 25th, 2009
      Bellingham, WA
      3,840
      07 A3 3.2 stormtrooper
      06-14-2012 09:48 AM #3
      I don't know the 2.0 very well, but maybe belt tensioner pulley?
      A VR6 AWD w/ lots of goodies
    5. Member VWAddict's Avatar
      Jun 12th, 1999
      Orlando, FL
      6,604
      '08 Audi A3 (8P), '99 Golf MkIV, '89 Porsche 951S
      06-14-2012 10:15 AM #4
      Lift the hood.
      See if it's coming from the belt side (on the left as you look from the front) or elsewhere.
      If the belt:
      See if it goes on or off with A/C compressor. (does your A/C function?) If the belt, replace belt. Water pump seized would have rewarded you with a stripped cambelt by now, and motor wouldn't run
      If not the belt:
      Does it 'quieten briefly as you 'blip' the throttle, then get louoder again as the revs decline again? -If so, remove the oil cap. -See if it stops. -This is actually not unlikely, and means some sort of failure of a valve in the emissions/recirculation system.
      That's all I got for now...
      Quote Originally Posted by MisterJJ View Post
      A "jump from a VW to an Audi"?!? I wouldn't call it a jump. It's more like shuffling along the sidewalk, tripping on a crack, bumping into a gorgeous blonde, walking away in a daze, and later finding out that she stole your wallet.
      Jul 1st, 1999
      12,101
      Blog Entries
      1
      06-14-2012 10:27 AM #5
      Quote Originally Posted by VWAddict View Post
      Lift the hood.
      If the belt:
      If not the belt:
      I'll try the A/C and oil cap. I do notice that if I blip the throttle (while car is parked/in neutral) it screams a bit. And as soon as I turn the car off/remove key a faint, little scream happens every time.
    7. 06-14-2012 11:05 AM #6
      It might also be the alternator pulley clutch. In any case, see if the belt tensioner is vibrating.
      If it keeps going after you turn off the engine, check the fans on the radiator. They might be rubbing on something. (but that wouldn't change with the throttle blip.)
      Jul 1st, 1999
      12,101
      Blog Entries
      1
      06-14-2012 11:15 AM #7
      Quote Originally Posted by dreaminga3 View Post
      Belt tensioner is vibrating. Though I'm not sure it's vibrating any differently than it's always vibrated. This noise is happening before the two fans on the radiator are even engaging. Using the A/C slightly exacerbates the problem.
    9. Member VWAddict's Avatar
      Jun 12th, 1999
      Orlando, FL
      6,604
      06-14-2012 11:20 AM #8
      Alternator pulley doesn't HAVE a clutch... and the tensioner will always 'hop' and 'ride' (I wouldn't say 'vibrate').
      Jul 1st, 1999
      12,101
      Blog Entries
      1
      06-14-2012 11:52 AM #9
      This could be completely crazy, but I did park under a tree yesterday which dropped a ton of leaves/junk on top of my car (especially on the hood/windshield). I'm wondering if some seeds/leaves or debris fell through the car and got down into the engine area and or belt.
    11. Member VWAddict's Avatar
      Jun 12th, 1999
      Orlando, FL
      6,604
      06-14-2012 12:42 PM #10
      is it COMING from the belt side with the hood up? (Tilt your head to check...)
    12. Member
      Jul 1st, 1999
      12,101
      Blog Entries
      1
      06-14-2012 12:46 PM #11
      I want to say it is, but I just can't be certain. It's not happening as consistently as it was in the video. I have to blip the throttle or roll the car forward/reverse to get the noise to happen now.
    13. Member brungold's Avatar
      Oct 8th, 2007
      Los Angeles
      2,903
      2008.5 A3 TSI Ibis White 6MT S-line
      06-14-2012 01:57 PM #12
      Quote Originally Posted by Xymox View Post
      did you check for racoons?
      2008.5 A3 | 2.0TSI | 6MT | Ibis White | Ti | OpenSky | Xenon | S-line
      Brungold Build Thread
      SoCal A3s on Facebook
    14. Member VWAddict's Avatar
      Jun 12th, 1999
      Orlando, FL
      6,604
      06-14-2012 03:35 PM #13
      Do you have a vacuum gauge?
    15. Member
      Jul 1st, 1999
      12,101
      Blog Entries
      1
      06-14-2012 03:38 PM #14
      No. Appointment scheduled at the VW dealer tomorrow. I hope it's okay driving home and to the dealer tomorrow morning.
    16. Member
      Feb 27th, 2010
      boston
      369
      Golf r
      06-14-2012 03:49 PM #15
      Have u had the PVC recall done? They can fail and cause a loud high pitch noise
    17. Member
      Jul 1st, 1999
      12,101
      Blog Entries
      1
      06-14-2012 03:51 PM #16
      Quote Originally Posted by obdboost View Post
      Not to my knowledge. I never received anything from AoA on a recall.
    18. Member VWAddict's Avatar
      Jun 12th, 1999
      Orlando, FL
      6,604
      06-14-2012 04:01 PM #17
      Didja try with the oil cap off yet?
    19. Member
      Feb 27th, 2010
      boston
      369
      Golf r
      06-14-2012 04:04 PM #18
      What ur vin?
    20. Member
      Jul 1st, 1999
      12,101
      Blog Entries
      1
      06-14-2012 04:13 PM #19
      What ur vin?
      Welp, just got off the phone with AoA, never received it, but I have an open recall for the PCV valve and fuel pressure sensor. Thoughts?
    21. Member
      Jul 1st, 1999
      12,101
      Blog Entries
      1
      06-14-2012 04:14 PM #20
      Engine running, oil cap off (and/or dipstick) and the car wheezes and shakes around a good bit creating my own vacuum leak.
    22. Member
      Feb 27th, 2010
      boston
      369
      Golf r
      06-14-2012 04:15 PM #21
      Get the recalls done first the PVC might fix it. It hard to tell without see it.
    23. Member
      Jul 1st, 1999
      12,101
      Blog Entries
      1
      06-14-2012 04:39 PM #22
      All sorts of red lights are flashing in my head after finding these two threads:
      http://www.audiforums.com/forum/audi...-valve-172009/
      http://forums.audiworld.com/showthread.php?t=2809353
      Is my car okay to drive until Tuesday (when my recall work is being completed)? Or should I drop it off now?
      Thanks.
    24. Member
      Feb 27th, 2010
      boston
      369
      Golf r
      06-14-2012 04:53 PM #23
      It ur call, I would play it safe and try and get the recalls done ASAP and only drive the car to the dealer. Before going I would check the oil level, to be safe
    25. Member VWAddict's Avatar
      Jun 12th, 1999
      Orlando, FL
      6,604
      06-14-2012 04:53 PM #24
      It's a fairly easy job for them. -If the squealing stops when you pop the cap, that's it, which is why I mentioned it in the first post.
      I wouldn't drive it more than to the dealership, if there's a loaner that you can drive instead.
    26. Member
      Jul 1st, 1999
      12,101
      Blog Entries
      1
      06-14-2012 04:55 PM #25
      Oh those "wonderful" folks at SUN Motors won't be able to give me a loaner until sometime in July.
      Earliest they can get me in is Tuesday morning. Really sorta stuck at the moment.
