Fourtitude.com - E-85 on IE dual 044 surgetank and Fuel manifold ?
    Results 1 to 8 of 8
    1. Member 10sec-rabbit's Avatar
      Oct 13th, 2003
      South Jersey
      2,298
      a bunch
      01-16-2012 09:29 PM #1
      Seems to streamline a dual 044 install but will the outlet manifold be a bottle neck?
      Likewise do you rely on the oem pump+screen for a pre-filter of sorts?
      Planning on using id2k injectors at what point do you need -10 feed on E-85 ?
      Who`s using this?
      Opinions?
    3. Member 04 GLI Luva's Avatar
      May 29th, 2007
      Miami
      2,247
      01-17-2012 01:53 AM #2
      Dont know why they're not using a -10 fitting or give the option at least, if anything you can replace the fitting with a -10 fitting
    4. Member turbodub's Avatar
      Jul 6th, 2000
      garden state
      4,262
      94 golf
      01-17-2012 10:09 AM #3
      make a surge tank. i personally run a factory tank with a factory pump to a surge tank w/ 2 044s with -8 line. simple and yet effective!
      Dec 14th, 2001
      Greensburg, PA
      3,270
      01-17-2012 11:48 AM #4
      If you do go with the IE surge tank you can skip the outlet manifold and run two outlet lines to a "Y". -8 will be plenty.
      Life begins at 101 kpa ...and so does poverty--Lugnuts Calhoun
    7. Member XXX008XXX's Avatar
      Mar 25th, 2002
      4,683
      2000 GTI 1.8t, 72 Standard Beetle, 95 Eagle Talon TSI Auto, 2002 Chevy Tahoe
      01-17-2012 03:57 PM #5
      the 044 is ment to be an in line pump... not in a "tank". i ran a regular surge tank to the 044s like todd... no problems. that setup hasnt been prooven in my opinion
    8. Member 10sec-rabbit's Avatar
      Oct 13th, 2003
      South Jersey
      2,298
      a bunch
      01-17-2012 07:05 PM #6
      Thanks All good points, Home brew is more my style anyway.
    9. Member lil8v's Avatar
      Jun 28th, 2002
      Jersey
      1,591
      03 20th ann..retired 97 gti that was a lil bit of everything
      01-17-2012 07:11 PM #7
      I believe in the ie surge tank i run it in my mk4 and even mounted upside down like in.my car at 700 whp on e85 the dash 8 feed is perfect and i still have.tons of fuel to throw at it
      2003 mk4 20th anniversary 10.30 at 151
      me-551 208 8850
    10. Banned
      Oct 23rd, 2011
      295
      01-17-2012 09:47 PM #8
      i use the plates mounted into a custom cell.
      dual -8AN to a T with single -10AN out.
      used to use a Y fitting with SS 1/2" hard tubing but i redid some things.
      E-85 and ID 2k's.
      no problem.
      -10AN feed to rail, -6AN return to FPR and on to cell.
      somewhere in 50% area duty cycle for fuel with ~32-33 psi boost and ID2k's with 648 AWHP. plenty of room to grow there.
      then again, i have ALWAYS used a -10AN feed to the rail. when ran with one A-1000 and C-16 and 35R and 1000's, to the dual 044's externally mounted, to the flush mounted 044's. not saying that i know anything or even what i am doing LOL.
