Fourtitude.com - elevel w/switchspeed using air lift block manifolds
    Results 1 to 9 of 9
    1. Member YNO WGN's Avatar
      May 27th, 2005
      Wine Country SoCal
      3,509
      3x mk3, 2x mk2, 1x mk1, 1x mk4, 1x mk6, 1x e30
      11-01-2011 08:50 PM #1
      Been thinking about switching from Autopilot to elevel w/ switchspeed and am wondering if anyone has wired the air lift block manifolds up with the elevel ecu... if so, do you happen to have a diagram?
      What are your thoughts on using the air lift blocks as opposed to the vu4?
    3. Member blue bags's Avatar
      Jul 1st, 2009
      gengland, MA
      2,070
      14 TDI sportwagen
      11-01-2011 11:41 PM #2
      Quote Originally Posted by **STEVE** View Post
      your kind of talking about two different things here.
      E-level and switchspeed are seperate systems
      The controller is identical basically
      the difference is E level, the 1, 2 ,3 buttons are your preset auto adjusting ride heights which require installation of the leveling sensors
      On the switchspeed controller the 1, 2, 3 are 'speed' settings which send a pulse signal to your valves to make it go up and down faster or slower.
      There is roughly a $700 difference in cost between the two. (with a switchspeed setup, youll get the ECU, controller, harnesses. With an e-level setup youll get the ECU, controller, and level sensors)
      I personally have asco valves which a switchspeed ECU and controller. It is no different than wiring and AVS box to airlift manifolds. The ECU will come with a pre-cut harness which you will them wire to the manfolds accordingly. In the tech-section on bagriders.com they have a diagram for airlift manifolds, and the ECU for your accuair controller will include one for their harness so its very easy to match it all up.
      From what ive seen from doing other installs, the switchspeed 'speed' settings are much more crisp on an Accuair manifold VS. my valves. Ive never ran one with the airlift manifolds but it will 100% work, i just cant say how different itll be.
      If financially its in the cards, i would buy the manifold as well either way because then youll have a plug and play system from your manifold to ECU.
    4. Member BigMeecH's Avatar
      Sep 3rd, 2010
      Montreal
      1,071
      11-02-2011 12:24 AM #3
      Quote Originally Posted by blue bags View Post
      what do u guys think about matching the avs7 with vu4. is it worth saving a few dollars over the switchspeed kit?
    6. Former Advertiser
      Aug 22nd, 2006
      Malvern, PA
      8,088
      M3 / W211 Estate
      11-02-2011 12:25 AM #4
      As bluebags said, the mating of the e-Level system to the AutoPilot manifolds will function properly. However, you will experience better results when you pair the SwitchSpeed or e-Level with the VU4 manifold.
      Let me look around to see if I can dig up some diagrams for you
      Quote Originally Posted by BigMeecH View Post
      We mate the AVS box to the VU4 manifold in our Advanced Analog Kit. It's a great pairing and extremely simple to wire up. If you want to go switchspeed/e-Level down the road you just pick up a new harness and you're golden.
      Honestly, if you have the cash, go for the SwitchSpeed. It won't disappoint!
    7. Member BigMeecH's Avatar
      Sep 3rd, 2010
      Montreal
      1,071
      11-02-2011 12:58 AM #5
      i just dont c whats the difference between the avs switch box and the switchspeed controller since the pre sets are non functional
    8. Former Advertiser
      Aug 22nd, 2006
      Malvern, PA
      8,088
      M3 / W211 Estate
      11-02-2011 01:08 AM #6
      The difference is the burst technology which is incorporated into the ECU. It allows the user to program three different speeds at which the actuators open and close. It's actually a very cool system and works extremely well. It allows you to have precise control over your 'switch box' by pulsing the valves at a very high rate such that the car moves a very small amount with each adjustment.
      Check it out here.
    9. Member YNO WGN's Avatar
      May 27th, 2005
      Wine Country SoCal
      3,509
      11-02-2011 01:13 AM #7
      Yeah, I was referring to elevel w/ touchpad as opposed to elevel w/ rocker. Thanks for the great information though. From what I understand elevel is a direct plug and play with the vu4 manifold, whereas the harnesses would have to cut and spliced with the air lift blocks. Am I wrong?
      Parts4VW
      Instagram: @ynowgn
      My Timeline Thingy
    10. Former Advertiser
      Aug 22nd, 2006
      Malvern, PA
      8,088
      M3 / W211 Estate
      11-02-2011 01:17 AM #8
      No sir, you are correct. The e-Level + VU4 is a plug and play setup whereas the e-Level + AutoPilot manifolds would require splicing the harness and hardwiring the two (in this case three) together.
    11. Member mike4-vr6's Avatar
      Jun 11th, 2011
      TX
      1,024
      MK4 Jetta VR6 / E46 M3
      11-01-2019 12:00 PM #9
      Hey Andrew. Looking to upgrade my switchspeed to e-level and use my apv2 manifold. You wouldnt happen to have any diagrams indicating how to mate the two would you?
