Fourtitude.com - The "you need a Miata" thread
    Page 220 of 221 FirstFirst ... 120170210216217218219220221 LastLast
    Results 5,476 to 5,500 of 5505
    1. Member rq1trackaddict's Avatar
      Sep 21st, 2009
      Lehigh Valley
      4,783
      miata efr 6258
      04-09-2019 07:02 PM #5476
      My new Lip showed up, all the way from Japan
      Mar 13th, 2010
      NoVa
      1,481
      04-10-2019 05:03 PM #5477
      Ok Everyone, random question of the day. It seems my car has a weird issue I haven't been able to diagnose. 91 miata, 99% track only. Stock motor and everything except suspension and safety mods. Also has a 4.1 torsen swapped in.
      The car seems to be unable to rev at the top of 3rd gear (and possible 4th). 1st and 2nd are fine.
      But when I get to around 6800 in 3rd, the car climbs in the revs verrryyyy slowly. The way this was discovered was by simply comparing my car to a friends similar car. There are parts of the track where he absolutely has to shift, but I can hold the gear way longer. It's difficult to hit the rev limiter in 3rd unless I really hold it in the gear.
      My first instinct was possible crank keyway wear, but the car seems to be making good power everywhere else. I also thought maybe he has a 4.3 and doesn't know it, but we looked at the axles and it looks like a Torsen version 1. Also, that wouldn't change how the car revs at the top of the rev range.
      Any thoughts or ideas? I'm going to take off the crank pulley and look at the nose anyway, and also replace the alternator belt since it seems to keep getting loose and squealing.
      I checked the timing, and it does appear to be jumping around a tiny bit and the crank does have a bit of wobble. So that's why I thought could be keyway.
      However the car does not really feel down on power, except at the top of 3rd (and possible 4th). On the street I revved 1st and 2nd and it revs very quickly, as expected.
      On the track for example I was on the back straight of VIR and I could hold 3rd almost until past the crest of the hill and the flag station. The issue does seem to be exacerbated by going uphill.
      Thoughts?
    4. Member Stevo12's Avatar
      Jul 27th, 2015
      Hartford, CT
      2,614
      '14 WRB Frontier, '13 Mazda3, '10 Mini Clubman, '08 Outback, '98 M3, '91 GTI
      04-10-2019 05:35 PM #5478
      Quote Originally Posted by 300_munkeys View Post
      Thoughts?
      Bolded are the red flags I see.
      I suspect you have SNC symptoms, at least the beginnings of them. That means, while your crank isn't totally fubar'd yet, the engine is on borrowed time.
      Why?
      For starters, it's a 1991 Miata, stock engine, unknown history (IIRC you bought it used a few years ago, right?) That's not a good start. Crank pulley wobble, while it doesn't impact timing directly, shows that the keyway isn't in the best of shape.
      But the biggest red flag is that it's load dependent, usually indicative of a timing issue. Timing issues are usually exposed at high loads, since there's usually less tolerance for improper timing at higher loads. Checking static timing at idle is a great start, but it doesn't tell the whole story. That it "jumps around a bit" at idle is not a good sign. 1st and 2nd aren't great test of load on the engine, because the resistance on the engine isn't at great. This is why you don't test a clutch's holding capacity in 1st or 2nd gear, or downhill. Higher gears and/or speed and uphill grades are usually great load tests - as you're finding out.
      So, short of actually pulling the crank pulley myself and giving a diagnosis, I'd say there's a good chance there's a timing issue going on. And on a 1991 Miata, that has a good chance of meaning that it's suffering from SNC issues, which means it might be time to shop for a new engine. It *can* be saved with the Loctite fix, but being that it's a track car, and knowing how much it sucks to show up to a trackdaybro and not have your car work, it would be wise to replace the engine with a later '91+ 1.6L or go with a 1.8 conversion.
      (or Honda J-series, just sayin' )
    5. Member
      Mar 13th, 2010
      NoVa
      1,481
      04-10-2019 05:53 PM #5479
      Why?
      But the biggest red flag is that it's load dependent, usually indicative of a timing issue. Checking static timing is great, but it doesn't tell the whole story. That it "jumps around a bit" at idle is not a good sign. 1st and 2nd aren't great test of load on the engine, because the resistance on the engine isn't at great. This is why you don't test a clutch's holding capacity in 1st or 2nd gear, or downhill. Higher gears and/or speed and uphill grades are usually great load tests - as you're finding out.
      Thanks man! I didn't realize load dependence could indicate the snc issue. To be clear, it's a later 91 so a big nose but the timing belt was done by a previous owner and I bet the crank bolt wasn't torqued correctly.
      Tb done around 60k and currently 78k miles.
      In any case that is my next step to diagnose so I'll go through with that. I've done a loctite fix before and that car was wayyyyy down on power but the keyway was savable. Given the power this car is still making, if that's the issue I'll loctite it and keep tracking it until it goes.
      I forgot to mention, after vir I torqued the bolt to 120 ft lbs without checking anything or doing anything and it seems to have helped a bit. So it does seem to point to the keyway.
      I'll update once I get it apart.
    6. Member Claff's Avatar
      Nov 2nd, 2009
      Waldorf, MD
      1,377
      Five two-seat roadsters, a hatchback, and a big ass pickup truck
      04-11-2019 12:29 AM #5480
      Speaking of trackdaybro
      Signed up for my first Track Night in America which will be next Thursday at Dominion Raceway in Virginia. Taking my '90 which is pretty much as it came off the course in STS at the 2016 Solo Nationals. Added a roll bar and that's it. Changed the oil and flushed brake fluid. Pads have plenty of meat on them and three year old RE71Rs are about half worn.
      Dominion, I think, isn't a big braking track. It has a looooooooooooooooong straight going into turn 1 (I'll bring a book) and not much else after that. I think I'll be OK with STS-spec Napa Gold pads up front and HPS in back.
      Only thing that needs addressing is a halfshaft that's leaking from the outer boot. I have spares (thanks to 300munkeys) so that'll be addressed in the coming days.
      Parsimonious Racing - autocrossing Miatas in the Washington DC area and beyond
    7. Member cockerpunk's Avatar
      May 17th, 2010
      Twin Cities MN
      6,411
      #81 SM 1.6
      04-11-2019 09:28 AM #5481
      Quote Originally Posted by Claff View Post
      lemmie know how that goes, i have an STS car i am considering putting a bar in for double duty, and the brakes are my biggest concern. STS brakes are made for setting the car, not dropping 70mph lap after lap.
      Quote Originally Posted by VigorousZX View Post
      In their unquenchable thirst for world domination, the aristocrats tax peoples time so as to keep its cattle viewed populations forever in servitude. They have gone as far as brainwashing and banning the western world that marrying your first cousin is forbidden and results in retardation... and thus have disturbed human evolutionary densities because broken families are easier to control and will better fall into debt slavery.
      Mar 13th, 2010
      NoVa
      1,481
      04-11-2019 10:01 AM #5482
      Dominion is a decent track but it was hard for me to get comfortable there. I was also on one corded tire due to a flat spot which didn't help.
      The biggest issue is how close the walls are at some points.
      Still, overall a fun track.
    9. Member Claff's Avatar
      Nov 2nd, 2009
      Waldorf, MD
      1,377
      04-11-2019 08:50 PM #5483
      Given a choice, I think I'd rather have this at Summit Shenandoah than Dominion, but they don't do TNiA there.
      There's half a chance that if I come out of TNIA all smiles, I'll give the time trial national tour at Pittrace a serious look. But that's probably too much too soon, especially since time trials are quite expensive to enter.
      Mar 13th, 2010
      NoVa
      1,481
      04-12-2019 12:29 PM #5484
      Why?
      Alright Stevo and everyone, take a look at the pics. Crank keyway looks totally fine to me.
      Now, I suppose it's possible I caught this issue REALLY early, and there's some .5mm wear I can't see yet, but that seems improbable to me because I noticed this issue a few weeks ago, and put 4 track days on the car. I think the keyway should have shown some wear after that abuse.
      The 4 days had a lot of time, too - over 10 hours easily, maybe even 12 total track hours.
      So any thoughts? Tonight I will get a very thin needle and try to put it between the key and the crank nose to see if there is some miniscule gap there. If there is, since I already have some loctice 660 I'll but a tiny smear in there and call it a day. The key is very tight in there so I'd rather not take it out unless I want to do a tb job which isn't necessary I don't think.
      Any other reasons timing could be jumping around? It could just be a loose alternator belt and the crank was wobbling (no ac or ps so it's the only belt) and timing isn't actually moving.
      But that doesn't explain the inability to rev in 3rd gear. Could it be a transmission issue?
    11. Member Stevo12's Avatar
      Jul 27th, 2015
      Hartford, CT
      2,614
      04-12-2019 01:53 PM #5485
      Might not be a bad idea to throw some Loctite on it. That is a short nose crank engine - the key is not supported through the length of the crankshaft keyway.
      Maybe before doing the Loctite, throw the pulley and bolt back in and check your timing marks again. How does the tensioner look?
      If all checks out, throw some Loctite on the key for good measure, bolt everything back together and check timing again. Does it still jump around? If so, maybe look at the CAS on the back of the head - is it loose? Maybe itís a bad CAS throwing off the ignition timing?
      Edit- forgot that you were re-torquing the bolt. Since you have an SNC engine, you should be torquing it to 80 ft-lbs not 120. It could be that the bolt is stretching (since they are known to be weak) which is why the load is reducing on the timing belt cog. Best to get a new bolt. Usually SNC guys recommend replacing the bolt during a timing belt job, but itís not often done
    12. Member
      Mar 13th, 2010
      NoVa
      1,481
      04-12-2019 03:19 PM #5486
      Shenandoah is definitely my favorite track in the area as far as fun. It's so busy but so rewarding when you get a good rhythm, especially in a miata.
      Mar 13th, 2010
      NoVa
      1,481
      04-12-2019 03:46 PM #5487
      I have a later '91 which according to vin should be a long/big nose. The crank bolt/crank looks the same as the one in the nb I have. Am I wrong? I'll take a look at the pulley when I'm home but I'm almost positive I have the big nose.
      edit: last 6 of VIN are 224889 so that should put me way into the BNC.
    14. Member
      Mar 13th, 2010
      NoVa
      1,481
      04-15-2019 08:16 AM #5488
      So after taking everything apart, I've decided the crank nose looks too good to do a loctite fix at this time. I put everything back and torqued to 120 ft lbs. I'm putting a new alternator belt and tightening it properly since the old one was getting loose and squealing a lot. I'm not sure if that was due to a loosening crank bolt (thus leading to the pulley wobble) or something else but I figure a new belt can't hurt.
      I've got some other plans to refresh the car, including new clutch master and slave and a shifter rebuild, and hopefully I will be caging the car soon. Worst case I will put a new engine in eventually. But for now the problem only appears in rare situations and I'm hoping that with the re-torque it will be alleviated. If not, I assume the crank will get worn out a bit in which case I'll do a loctite fix at that time and go with that until it wears out again.
    15. Junior Member
      Apr 7th, 2014
      Chambersburg, PA
      40
      04-15-2019 11:02 PM #5489
      The first three generations of Miatas are sitting at an interesting price point right now, really nice NAs, middle of the road NBs, and cheaper NCs are all hitting in the $4-6k range. I've had a couple NAs, but I'm getting curious about the NC now. My commute has become 60mi/day mostly highway at 70mph. I have a Frontier for when I need something to be a truck or the super reliable daily driver, so this is a fun car for me but I'd like to be able to use it all the time and only break out the truck as needed. I'm assuming 30s me wouldn't enjoy an NA as much as 20s me did back in the day and the newer platform might be the way to go for a more comfortable highway cruiser. Any comments? I'm looking at the low end of NC prices, so I'm sticking to an NC1. I'd like to have a limited slip, and I'm not sure about the differences between the 5spd and 6spd manuals. Any suggestions to help guide my purchase?
      Random Google Image
    16. Member
      Mar 24th, 2001
      Beaverton, OR
      7,566
      1991 BRG Miata, 2008 Mercedes GL320 CDI
      04-16-2019 01:59 PM #5490
      Quote Originally Posted by Nitroracer17 View Post
      The first three generations of Miatas are sitting at an interesting price point right now, really nice NA middle of the road NBs, and cheaper NCs are all hitting in the $4-6k range.
      You might not be aware, but a "really nice" NA Miata is ~$8k almost anywhere in the country. Look at any clean 1990-1997 Miata with HT, <80K miles, and up to date maintenance and you'd be hard pressed to find one for anything less. Go over to BAT and look at their auction data.It's a real eye opener.
      Losing is just a winning streak in the wrong direction -DD
      Watch a headhunter find his own job - 9 month process
    17. Member CostcoPizza's Avatar
      Jan 20th, 2008
      Los Angeles
      6,067
      '12 MINI Clubman S '85 Mercedes-Benz 280CE
      04-16-2019 02:16 PM #5491
      I see decent NAs and NBs in that price range, but solid NCs seem to be a bit outside that range. For ex: a $6k NC will be an early year with 150k+ miles and slightly questionable history.
      I'm on the hunt as well.
    18. Member
      Mar 13th, 2010
      NoVa
      1,481
      04-17-2019 12:19 AM #5492
      Random Google Image
      NCs had a bad rap for not being "Miata" enough and being too heavy. But while technically a bit heavier than later nbs (I think around 100-150 lbs depending on options) the rigidity in the chassis and extra power make up for the weight very well.
      Biggest issues for me with the NC:
      - stock suspension is pretty crappy. Needs an upgrade to become more fun
      - engine has little character. There's a reason the 1.6 is the most fun engine even though it's the weakest. The 2.0 doesn't want to rev much
      - seats aren't great especially on the early ones
      - interior materials don't age very well
      For the nc1, especially 06 I would avoid the 5speed. It had an issue with 4th gear I think.
      If you can swing an nc2 the engines are more stout and have a higher redline. I believe the suspension and transmissions were also improved.
      I'm considering one as my next track car. Let us know how it goes!
    19. Member rq1trackaddict's Avatar
      Sep 21st, 2009
      Lehigh Valley
      4,783
      miata efr 6258
      04-19-2019 08:29 AM #5493
      New PTP blanket for 6258
    20. Member cockerpunk's Avatar
      May 17th, 2010
      Twin Cities MN
      6,411
      #81 SM 1.6
      04-19-2019 09:25 AM #5494
      best looking car on the grid.
      now she just needs corner balance and alignment, and some dyno time
    21. Member
      Jul 29th, 2001
      Corpitos, TX
      2,939
      04-19-2019 10:25 AM #5495
      I've got an NC3 and am loving the hell out of it. It's not stock though, as many items mentioned earlier have been addressed like adjustable coilovers, exhaust, etc. But with that, mine's not a commuter either, just a fun weekend toy. I agree with some of the other comments regarding a "cheap NC" though, you're going to be rolling the dice on a few things. If the top of your budget is $6-8K for instance, i'd be shopping for the nicest, least mileage Miata I could find for that money, not the newest year.
      '14 F-150 FX4 (bread and butter)
      '11 GTI (wifeys)
      '13 MIATA (dumb modified weekend thrasher)
    22. Senior Member Sporin's Avatar
      Feb 17th, 1999
      Vermont, USA
      30,977
      '94 Miata - '16 RAV4 - '10 Prius
      04-19-2019 10:32 AM #5496
      The PRHT NCís are very popular here in New England as they extend your season dramatically.
    23. Member smetzger's Avatar
      Oct 21st, 2004
      MD
      1,361
      2009 Odyssey | 2013 Fit | 2009 Miata | 07 Mazda3 | 03 Mazda Protege5 | 02 Mazda Protege
      04-19-2019 01:30 PM #5497
      I could be wrong, but I don't think the NC1s came with a 6 spd. 6spd just means you have to shift more, your revs at 70mph are going to be almost the same with the 5spd or 6spd.
      If you are not going to Auto-X or track, just get the nicest example you can find and don't worry about the LSD.
      But if you are going to, then spring for one.
      NC will be more comfortable and have more creature comforts for a semi-daily over the NA or NB.
      I am quite happy with my stock NC2 which I use as a weekend and occasional Auto-X (5-6 events per year)
      Nothing to see here move along.
    24. Member dwagner88's Avatar
      Jan 13th, 2011
      Chattanooga, TN
      1,767
      2014 Mazda CX-5 GT, 2011 Toyota Camry LE, 2006 NC Miata, 2018 Chevrolet Silverado 5.3 (work)
      04-19-2019 03:01 PM #5498
      Random Google Image
      I bought a high mileage cheap NC in 2016. Mine was a 2006 GT with every single factory option except the yellow bilsteins. It does have an LSD. It almost immediately developed a knock and needed a new engine. I put in an NC2 engine with 21,000 miles on it. Even with the motor swap, I was still in it for under $8 grand. Itís been perfect ever since. Itís the most fun Iíve ever had in a car. I may spend a little money this year on a new top, but I struggle to imagine having more fun for less money in a car. Even the insurance is cheap. I recommend the 6 speed. It has better in-gear acceleration than the 5 speed. I wouldnít call any Miata a comfortable highway cruiser. Even with the 6 speed, the engine is spinning at 4K at 80 mph.
      Past: 1998 Accord V6 LX
      2007 Mazdaspeed 3 (KIA 2-24-11)
      2009 Mazdaspeed 3 (KIA 9-19-11)
      2003 Jetta GLS 2.slow (good riddance)
      2010 VW GTI
    25. Member Smigelski's Avatar
      Dec 9th, 2008
      Annapolis, MD
      8,065
      Golf 7 R, Ford Ranger, ND Miata
      04-19-2019 03:10 PM #5499
      Quote Originally Posted by smetzger View Post
      The NC1 had the 6 speed on the higher trims and the 5 speed on the lower versions. I had a 5 speed 2006.
      Quote Originally Posted by dwagner88 View Post
      I think the gearing in 6th of the 6 speed is lower than the gearing of 5th on the 5 speed.
      Here you go:
      Vehicle Identification
      Gear Ratios (5-speed Manual) 1st - 3.136:1 2nd - 1.888:1 3rd - 1.330:1 4th - 1.000:1 5th - 0.814:1
      Gear Ratios (6-speed Manual) 1st - 3.815:1 2nd - 2.260:1 3rd - 1.640:1 4th - 1.177:1 5th - 1.000:1 6th - 0.832
    26. Member 88c900t's Avatar
      Jul 6th, 2014
      "typical wisconsin rust"
      8,332
      17 Focus ST2, 90 RX7 vert, Accord 6-6 sedan, 96 Montego blue Miata.
      04-19-2019 03:17 PM #5500
      Yikes, how did it develop a knock?
      NC's with their 170 hp are tempting...
      Sell current Miata and buy this? Hilariously, it's the exact color, year and trim level as mine. Just looks significantly nicer, much fewer miles.
      https://chicago.craigslist.org/sox/c...865352431.html
      Typical forum guy with busted third-hand cars.
      Quote Originally Posted by Kiyokix View Post
      I like this guy, I like this guy a lot.
      88c900t wins again, you really ****ing crush it at listing a ton of cheap options
      Quote Originally Posted by volvohutter View Post
      You'll always get a pass due to your history of owning classy and sophisticated automobiles
