Fourtitude.com - Differences between Q7 2012 oil filter housing and Passat..a quest for answers...
    Results 1 to 25 of 36
    1. Angry Administrator nater's Avatar
      Apr 10th, 2000
      87,612
      2018 Atlas 4MO, 2008 3.6L Passat 4Mo, 98 O2M 3.0L VRT, '04 .:R32, 2014 CC R-line
      08-31-2011 07:15 PM #1
      03H 115 403 J
      Listed as an oil filter housing for Q7 and Toureg 3.6L and 3.2L. Seen at worldimpex.com
      Applications include:
      Year Make Model
      2004 Volkswagen Touareg 3.2L Base V6 BAA
      2005 Volkswagen Touareg 3.2L Base V6 BAA
      2006 Volkswagen Touareg 3.2L Base V6 BAA
      2005 Volkswagen Touareg 3.6L Base V6 BMX
      2006 Volkswagen Touareg 3.6L Base V6 BMX
      In speaking with my local VW parts guy he said he looked at the pictures of the new Q7 part (year 2012) and the 06-08 3.6L passat and saw that they are "completely different".
      Now, I haven't looked at either because I can't see a picture anywhere on the internet. But I NEED to find a way to make this housing work.
      The part that user JBallou says has been updated includes a new check valve that combats the dry start up worries. He speaks of it on this post in the 3.6L failure thread: https://forums.vwvortex.com/showthrea...1#post70965422
      Trust me, dry start up noise that you hear is that of your bearings making noise. How do I know? Well, the same noise I heard upon start up was the noise I heard when I spun my bearing. This can't be good for the motor and I'm sure it's only going to make my motor spin it's new bearings I just put in (spun 2 of them....cylinder 4 and 6).
    3. Junior Member
      Jan 6th, 2009
      84
      2007 Q7 S-line 3.6l
      09-02-2011 12:25 AM #2
      It sounds like a different housing than the q7, but it could have a check valve. That is what really matters a check valve. Do yourself a win and order the part, save the reciept. Then give it a good hands on and see if it has a check valve. Thats what you need to do. If no way to keep the oil up in the upper parts of the motor with some fancy valve or wierd passage, send it back. Get your money back.
    4. Junior Member
      Jan 6th, 2009
      84
      2007 Q7 S-line 3.6l
      09-02-2011 12:27 AM #3
      You dont need to modify anything to put the one from the q7 in, your post speaks of a updated part # for the passsat.
    6. Angry Administrator nater's Avatar
      Apr 10th, 2000
      87,612
      09-02-2011 08:24 AM #4
      Quote Originally Posted by JBallou View Post
      How do you know this for sure? I only found these parts by searching through the Audi tsb. I didn't get this part # from the dealer in regards to my passat. Can you clarify?
      Thanks
    7. Junior Member
      Jan 6th, 2009
      84
      2007 Q7 S-line 3.6l
      09-09-2011 04:32 PM #5
      What I mean to say is the Q7 part will fit the Q7, most likely not the passat. You need the passat part. The dealers were no help in providing part numbers. Just able to confirm the numbers. I ordered it online. The less idiot parts guys involved the better.
    8. Angry Administrator nater's Avatar
      Apr 10th, 2000
      87,612
      09-09-2011 08:31 PM #6
      Parts guys are telling me no new passat part exists.
    9. Member Shtbox's Avatar
      Nov 27th, 2010
      NJ
      2,718
      14 CAAD10 5
      07-17-2013 08:44 AM #7
      any update on this? does the q7 actually have a check valve, and does it fit? i am SO TIRED of hearing my bearings going to **** every time i cold start!
      coolWATER
    10. Angry Administrator nater's Avatar
      Apr 10th, 2000
      87,612
      07-17-2013 10:15 AM #8
      Quote Originally Posted by Shtbox View Post
      No update.
      But I wonder if its just timing chain noise?
      That's what has put my mind at ease for the time since I posted this.
    11. Member Shtbox's Avatar
      Nov 27th, 2010
      NJ
      2,718
      14 CAAD10 5
      07-17-2013 10:24 AM #9
      Quote Originally Posted by nater View Post
      No update.
      I really hope you're right. My ******* puckers and my face cringes every cold start
      coolWATER
    12. Angry Administrator nater's Avatar
      Apr 10th, 2000
      87,612
      07-17-2013 10:47 AM #10
      Well, I don't have extra money to just play around with otherwise I'd get each housing in my hand and see what is so different....
      Maybe it can be made to work. Then install and see if the noise goes away.
      Seems like a lot of $ and time just to find out if it indeed is chain noise or not.
    13. Member jddaigle's Avatar
      May 30th, 2003
      Denver, CO
      7,118
      2008 Passat Wagon VR6 4motion, 2013 FIAT 500 Sport
      07-18-2013 09:17 AM #11
      Don't some/all Mobil1 oil filters have an internal check valve? Someone could try running one of those for an oil change and see if there's any difference.
      I suspect it's either chain noise or the hydraulic valve adjustment system repressurizing. If all that racket was bearings I feel like every 3.6 would need new ones every 50,000mi!
      - Jeff
      B6 Passat 3.6 & 4motion Resource Thread
      Now: 2008 VW Passat 3.6 4motion Wagon, 2013 Fiat 500 Sport
      Then: 1987 Volvo 745GLE, 1989 Volvo 745GL, 1994 Volvo 940T, 1995 Infiniti G20, 2000 VW Passat 1.8T, 2001 VW Jetta Wolfsburg Ed (x2), 2004 VW Golf TDI, 2006 Jetta TDI
    14. Member Shtbox's Avatar
      Nov 27th, 2010
      NJ
      2,718
      14 CAAD10 5
      07-18-2013 09:31 AM #12
      coolWATER
    15. Angry Administrator nater's Avatar
      Apr 10th, 2000
      87,612
      07-18-2013 10:56 AM #13
      3.6L uses a canister element. No check valve.
    16. Member jddaigle's Avatar
      May 30th, 2003
      Denver, CO
      7,118
      07-18-2013 02:18 PM #14
      That's right, there couldn't be any check valve in the element--shouldn't post before I have my coffee!
      I still suspect that the noise comes from the top-end rather than the bottom. The camshaft adjusters and valve lifters seem to have the biggest potential for leakdown as they're furthest from the sump.
      According to the self-study guide for the 3.2/3.6L GDI VR6, the oil filter housing has a check valve, and the oil pump has a reservoir that doesn't drain down to the sump to provide oil pressure right away. Based on the position and orientation of the filter housing, it seems like there'd be quite a bit of oil pooled there on cold start, too.
      See pages 28 and 29:
      http://sandbox.enjoybeing.net/veedub...self_study.pdf
      - Jeff
    17. 07-18-2013 09:40 PM #15
      I'm pretty sure the passat housing has a check valve. I have it off of the engine and can take pics tomorrow.
      here's the q7 images http://www.ecstuning.com/ES275791/PriceAlert/
    18. Member jddaigle's Avatar
      May 30th, 2003
      Denver, CO
      7,118
      07-18-2013 10:09 PM #16
      Quote Originally Posted by Corrado4Life View Post
      Nice! It'll be great to have some photos for comparison.
      - Jeff
    19. Member DBVeeDB's Avatar
      Aug 2nd, 2007
      IL
      5,165
      B6 S4 Avant - '06 Lincoln LS - Mk4 Jetta Wag
      07-19-2013 01:18 PM #17
      All I can say is I definitely have this cold start noise. And it breaks my heart every morning.
    20. Angry Administrator nater's Avatar
      Apr 10th, 2000
      87,612
      07-19-2013 06:28 PM #19
      http://youtu.be/RyEDlq25kNE
      This is a video I took this am, documenting the noise.
      But this is quiet compared to the usual.
      Ill add a vid of the louder one in the am.
    21. Member jddaigle's Avatar
      May 30th, 2003
      Denver, CO
      7,118
      07-20-2013 12:19 AM #20
      That sure looks like a check valve on the right to me. Is the the inlet or outlet? Thanks for posting the photos!
      - Jeff
    22. Member jddaigle's Avatar
      May 30th, 2003
      Denver, CO
      7,118
      07-20-2013 12:27 AM #21
      Sounds just like mine.
      How are your new bearings holding up? Any change in the noise, before and after the new bearings?
      - Jeff
    23. Angry Administrator nater's Avatar
      Apr 10th, 2000
      87,612
      07-20-2013 05:06 AM #22
      Quote Originally Posted by jddaigle View Post
      Noise is the same. And after 30k+ miles I'd say they are holding up well considering I threw them in there.
    24. Member DBVeeDB's Avatar
      Aug 2nd, 2007
      IL
      5,165
      07-20-2013 09:57 AM #23
      looks like there is a blank plug/port on the housing just like the older VRs. Maybe I'll add my own oil press or temp gauge.
      video sounds just like mine Nater
    25. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      37,281
      15 Jetta 92 Corrado VR6
      07-20-2013 01:26 PM #24
      Thats the same housing as the 2.8/3.2 24v. Any of those suffer from the same issue?
      -Paul
    26. Angry Administrator nater's Avatar
      Apr 10th, 2000
      87,612
      07-20-2013 03:44 PM #25
      Quote Originally Posted by need_a_VR6 View Post
      My 12v does not have (never has had) that issue.
