Fourtitude.com - My N/A Build--Finally Started thread!
    Page 6 of 7 FirstFirst ... 234567 LastLast
    Results 126 to 150 of 167
    1. 12-21-2015 05:55 PM #126
      Quote Originally Posted by GasInMyVeins View Post
      I'm not sure this could create an issue only at WOT, but the stock plastic bleeder block has an incredibly small orifice in it, meant to dampen pedal feel for "normal" people. ECS sells one that is all aluminum and has a larger orifice for more flow; I put it on my 20th and noticed a more linear engagement and slightly heavier pedal. Here's a link.
      I actually ordered that today. Hopefully it helps solve my issue.
      Quote Originally Posted by root beer View Post
      That thing sounds good man. Keep at it.
      I really really want one of these motors if i were to hurt my 12v.
      Im getting tired and alil fed up. motor has been handling fine. but this clutch issue is killing me. grrrr.
      Racing Improves the breed..
      "I have fought the good fight, I have finished the race, I have kept the faith"- 2 Timothy 4:7
      CrossroadsLI
      MY ALL MOTOR BUILD THREAD
    3. Member GasInMyVeins's Avatar
      Jul 11th, 2010
      Ponte Vedra Beach, FL
      1,881
      2003 GTI 20AE #1901
      12-22-2015 09:58 AM #127
      Quote Originally Posted by fourthchirpin View Post
      2003 GTI 20AE #1901: my Jazz Blue racecar
      2014 GLI Edition 30 6M in Tornado Red: my wife's daily
      IG: @smf_20th
    4. Member itschrisb's Avatar
      Jun 7th, 2007
      Philly
      3,686
      mk1 vw caddy, chevy s10
      12-23-2015 10:41 PM #128
      Another inspirational thread. I need to do this to my mk2. It already has a 12v but like youve said im not interested in turboing it. Im pretty convinced it would end up costing somewhere near the same to make 12v go over 200whp as it would to swap in a 3.6. I could be totally wrong though.
    5. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      37,281
      15 Jetta 92 Corrado VR6
      12-24-2015 08:58 AM #129
      A 190-200whp 12v can be done for way less than this swap. Now a 220+ whp one, probably close in cost.
      -Paul
      1992 Corrado - ALL MOTOR Drag Project [email protected] and falling
      KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    6. Member itschrisb's Avatar
      Jun 7th, 2007
      Philly
      3,686
      12-24-2015 09:25 AM #130
      Quote Originally Posted by need_a_VR6 View Post
      Even if you were to find a full donor car for cheap. Sorry I'm just trying to get a gauge for what this ends up costing.
      Sent from my SM-G920T using Tapatalk
    7. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      37,281
      12-29-2015 02:07 PM #131
      Just a block and a head is around $3k for a low mileage one. Lots have damage to the intake manifold and hpfp assemblies if in a front ender. You will also need all the wiring, mk5 r32 downpipes, pedal, immo and abs deletes in the ecu... probably more I am forgetting.
      -Paul
    8. Angry Administrator nater's Avatar
      Apr 10th, 2000
      87,612
      2018 Atlas 4MO, 2008 3.6L Passat 4Mo, 98 O2M 3.0L VRT, '04 .:R32, 2014 CC R-line
      01-08-2016 08:26 PM #132
      Good thread.
    9. 06-26-2016 05:10 PM #133
      Finally got some more parts to put in. Between last update and now.
      While on the dyno I had issues of my clutch line popping off and clutch pedal falling to the floor on Full throttle that has been ever since I had this car. So i dropped tranny after i was getting noise coming from the clutch after the clutch line came off. I discovered that a few transmission bolts that hold the tranny to the block were missing and the pp was rubbing the transmission casing. So I had to get a new pp, fix the flywheel dowl pins, I opened the tranny to put back the original ring and pinions. And bought a brand new clutch master cylinder.
      newc clutch master cylinder
      CM 02M Slave cylinder
      CM FX500 clutch kit
      16 lb Flywheel
      New rear skinnies.
      So hopefully finally ill have no more issues with my clutch after all this. Stay tuned Im really trying to make it to waterfest in a few weeks! Enjoy everyone.
      CrossroadsLI
    10. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      37,281
      06-29-2016 09:38 AM #134
      -Paul
    11. 01-31-2017 05:25 PM #135
      update:
      clutch master slave cylinder was .200inch too big, they sent me an updated version that was smaller. I will be putting that in this month. Hoping I can finally solve my clutch issues finally.
      CrossroadsLI
    12. 02-03-2017 01:49 AM #136
      Fingers crossed!
    13. Member turboit's Avatar
      Oct 4th, 2001
      Delaware
      4,249
      '07 Audi S4 Avant, '93 Corrado SLC
      07-27-2017 01:13 AM #137
      Updates?
    14. 09-20-2017 10:11 PM #138
      Hey guys sorry that I havn't been updating this. During the spring clutch masters slave wasn't working with me so I went to OEM slave.
      Back in May, my axle popped out of its cv. In July I sent it to drive shaft shop. I was able to measure some things for them and they told me 1 side was too short. So they made the shaft longer for me 1/2" longer. Right now the car is back together. It feels good its supper loud. Brake scatter shield is rubbing and I need a bolt for my rear motor mount that I lost. Ill have both of those things completed by sunday. Maybe Ill make a video. the car is supper dirty inside well see. So far from driving it I havn't gotten that clutch pedal drop at all yet so Im happy about that. only issue is I have a leaky oil pan which I have a replacement already.
      CrossroadsLI
    15. Member prometheus_'s Avatar
      Oct 6th, 2009
      pickering, ontario
      2,437
      96 Golf GTI, 13.5 Super Beetle
      10-03-2017 12:21 AM #139
      I've been watching this thread intently, you'll get it sorted soon enough
      In the meantime, here's a vid from those crazy frenchmen who've been running their all-motor 3.6 rado.
      No idea what their setup is though
      https://www.facebook.com/BenCustomFa...6612213498013/
    16. 11-29-2017 09:12 PM #140
      Quote Originally Posted by prometheus_ View Post
      Def. sikk! No updates from me really. Seems that my clutch issue is 100% fixed. My DBW pedal keeps going dead at random usually during stop and go driving. I have a few ideas that I will try during the winter.
      CrossroadsLI
    17. 02-06-2018 11:09 PM #141
      new manifold, Cooling system and loosing some weight
      CrossroadsLI
    18. Member turboit's Avatar
      Oct 4th, 2001
      Delaware
      4,249
      02-07-2018 12:09 PM #142
      Ooooo very nice.. Who made that intake for you? Cams on your list?
      Sent from my Pixel XL using Tapatalk
    19. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      37,281
      02-07-2018 01:42 PM #143
      Swoops built “babymailbox” and cams better be on his list!
      -Paul
    20. Member turboit's Avatar
      Oct 4th, 2001
      Delaware
      4,249
      02-08-2018 12:43 AM #144
      Paul did swoops do your manifold too or did Jim?
    21. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      37,281
      02-08-2018 07:33 AM #145
      Jim made mine
      -Paul
    22. 02-08-2018 11:04 PM #146
      not yet!
      CrossroadsLI
    23. 03-18-2018 04:37 PM #147
      car is back home. my accelerator pedal keeps going out, only at idle randomly. Car drives fine, feels strong. I really want to dyno asap. I probably wont do anything until May or June like hit the track.
      CrossroadsLI
    24. Member turboit's Avatar
      Oct 4th, 2001
      Delaware
      4,249
      03-18-2018 07:28 PM #148
      New setup looks great! Crazy that you are having that pedal issues at least the clutch issue is fixed
    25. 03-29-2018 06:32 PM #149
      2015 setup
      2018 Swoops Built Short runner
      dyno on the new setup.
      pedal went out once on the dyno at the end. but it was fine while driving that day. I forgot to delete my 12 codes I had prior to the dyno not sure if that mattered or not. I will be running through the car looking for any issues as I dont have anything planned for right now. I would like standalone next to run it on corn or maybe loose some more weight by waterfest
      CrossroadsLI
    26. Member StateSideS3's Avatar
      Apr 13th, 2007
      NY
      3,776
      01' S3 VR Supercharged, 01' TT 225 roadster w/Hardtop (sold), 03' Jetta (sold)
      04-02-2018 08:00 AM #150
      nice numbers and sounds great
      thing must be a blast on the street!
      wanted to try and stop by swoops while it was there to check it out, didnt have the chance though
      DUB CULT _ DUBAUDI _ PVW Nov 2016 _ Performance Audi - Issue 39 April 2018 _ IG StateSideS3
