Fourtitude.com - TT MK2 Wheel/Tire Fitment Thread - Ask all your questions here and post up pictures
    Page 2 of 17 FirstFirst 12345612 ... LastLast
    Results 26 to 50 of 411
      May 15th, 2011
      Scottsdale, AZ
      267
      2016 Boxster GTS; 2018 TT RS; 2018 GT3
      08-25-2011 04:43 PM #26
      OK, less than 100 miles on the car so far, but thinking of a second set of wheels for some DOT-R tires. Perhaps some of our overseas friends who have had the car for a couple years can help.
      Current Ride Height/Projected Ride Height: Stock TT RS
      Wheel Specs (Height, Width, Offset): 19x9 et52
      Wheel Brand & Model: OEM titanium 'rotor' wheels
      Tire Size (if appicable): 255/35/19
      Question: Are there any 18x9.5 wheels that will fit without issues? I'm thinking of maybe trying a 265/35/18 tire. Maybe Yokohamas or Toyos. It seems like there are more tire choices with an 18" wheel.
      Any input would be appreciated. Also, is the lug bolt pattern 5x112 on the TTRS? Anyone know the center bore? What offset would fit over the brakes without using spacers?
      Thanks!
    3. Member TheSandeman's Avatar
      Jan 12th, 2011
      Where the headless horseman roams, New York, United States
      1,723
      Audi MK2 TT 3.2 CQ
      08-25-2011 07:30 PM #27
      PCD is 5x112, centerbore is 57.1..
      Sent from my iPhone4.
      May 15th, 2011
      Scottsdale, AZ
      267
      08-25-2011 07:47 PM #28
      Quote Originally Posted by TheSandeman View Post
      Thanks!
    6. Member eweu's Avatar
      Jul 22nd, 2001
      Silicon Valley, CA
      2,861
      Golf Alltrack, TT VR6, F350, IS 300
      08-25-2011 08:19 PM #29
      Quote Originally Posted by Dr. Bill View Post
      FWIW, a 265/35 will fit on an 18x9 wheel without issue. That should broaden your choices a bit.
      Also, be careful about your front brakes with 18s. My stock 18x9s didn't fit over the TTRS brakes, and I'm sure it will be hit-or-miss whether aftermarket 18s fit. The problem wasn't with with spoke clearance (so offset is no help), but rather with the barrel. The TTRS uses 370 mm rotors compared to the 345 mm (I think) rotors of the 3.2 TT and TTS.
    7. Member TheSandeman's Avatar
      Jan 12th, 2011
      1,723
      Audi MK2 TT 3.2 CQ
      08-25-2011 08:22 PM #30
      Thanks!
      no problem, Bill dont stray away from the CB differences when it comes to wheels... there are many options to adapt a hub bore to a wheel bore, depending what youre planning to do with the fitment you can use one of the following.
      Custom Spacers
      Custom PCD Adapters
      Hubcentric Rings
      easiest being the hubcentric rings but be sure to get the metal kind, the plastic/rubber kind lead to vibrations at highway speeds
    8. Member TheSandeman's Avatar
      Jan 12th, 2011
      1,723
      Audi MK2 TT 3.2 CQ
      08-25-2011 08:24 PM #31
      Quote Originally Posted by eweu View Post
      this is true, sometimes youll need to use spacers to give you that added clearance depending on the wheel spoke design, offset, etc. best way to figure it out is to use a tape measure and depend less on the online calculators
    9. Member eweu's Avatar
      Jul 22nd, 2001
      Silicon Valley, CA
      2,861
      08-25-2011 08:29 PM #32
      The TT Shop shows this picture on their TTRS brake upgrade page.
      I have no idea how they got that wheel to fit, because I couldn't even get the bolts to line up and I have the same wheel. Perhaps the European 10-spoke wheel has a different manufacturer that gave it a wider barrel. Regardless, be very careful selecting wheels for those massive TTRS brakes.
    10. Member TheSandeman's Avatar
      Jan 12th, 2011
      1,723
      Audi MK2 TT 3.2 CQ
      08-25-2011 08:35 PM #33
      could it be that they were ninja and shaved a little bit of the back of the wheel spokes to make it fit? (sounds outlandish but you never know), or maybe they fit spacers?
      i do agree, i dont know how the hell they fit that wheel over those TTRS brakes
    11. Member
      May 15th, 2011
      Scottsdale, AZ
      267
      08-25-2011 08:40 PM #34
      Yeah - it took 8mm hubcentric spacers to get them on my 2009 TTS!
    12. Member eweu's Avatar
      Jul 22nd, 2001
      Silicon Valley, CA
      2,861
      08-25-2011 11:19 PM #35
      They said no spacers. I was bummed when I found they didn't fit my wheels. Oh well.
    13. Member kendoist4162's Avatar
      Mar 15th, 2010
      Los Gatos,CA
      354
      2009 Audi TT 2.0
      08-29-2011 12:08 AM #36
      These are what I put on for my stealth run to Vegas this year....
      Current Ride Height: down 1.3 inches on H&R sport springs
      Final Wheel Specs: 5x112 19x9 et45
      Wheel Brand & Model: Bremmer Kraft BR05 black
      Tire Brand & Size: Hankook Ventus V12 evo K 110
      Additional Hardware: hubrings that came with the wheels
      Rubbing?: Nope
      Pictures: Before & After
      Before:
      After:
      Brilliant Black 2009 TT-APR Stage 1 flash, Neuspeed P-Flo air intake, Torque arm insert & RSB, H&R sport springs, FK all black grill, TTS front brakes w/SS lines, 8kK headlights, 3kK yellow fog bulbs w/yellow LaminX, Bremmer Kraft BR05 black 19x9et45 wheels w/Hankook Ventus V12 evo K 110, Veil anti-laser painted lights&plates.
    14. Member ProjectA3's Avatar
      Aug 12th, 2005
      Anthem, AZ
      4,382
      2015 S3 / 1996 VW Cabrio VR6
      09-20-2011 02:56 PM #37
      can we make this a sticky?
      2015 Audi S3 Sepang Blue/ fifteen52 wheels / Air Lift Performance / TOYO T1 Sport tires / TTRS brakes / GIAC Stg2 / BFI mounts / B&B TBE / HG Intercooler / CTS Turbo parts - Parts Score
      @brianmccauley1 on Instagram these are my personal views
      AudiNorthScottsdale
    15. Member TheSandeman's Avatar
      Jan 12th, 2011
      1,723
      Audi MK2 TT 3.2 CQ
      09-20-2011 07:53 PM #38
      Quote Originally Posted by ProjectA3 View Post
      agreed!
      235/35-19 is my tire size to answer your PM very slight stretch (none more than some)
    16. Member TheSandeman's Avatar
      Jan 12th, 2011
      1,723
      Audi MK2 TT 3.2 CQ
      09-20-2011 07:54 PM #39
      Quote Originally Posted by kendoist4162 View Post
      Rubbing?: Nope
      Before:
      After:
      love the wheels and the concavity
    17. Semi-n00b ( . )( . )TTlovin's Avatar
      Jun 20th, 2011
      La Puente CA.
      18
      2015 S5,2009 TT, 2003 GTI,1991 GTI, 1958 ragtop
      09-24-2011 12:14 AM #40
      2 inch drop
      MAM mt1 18 x 10 all around
      Rubbing ? yup
    18. Member bigstu's Avatar
      Mar 6th, 2008
      Orange, Ca
      690
      '01 Cabrio, '05 Volvo V70, '14 CC R-Line, '06 Porsche 911
      09-24-2011 04:08 AM #41
      Whats the offset and tire size on your MAM setup TTlovin? Looks freakin awesome!
    19. 09-24-2011 09:04 AM #42
      Quote Originally Posted by ( . )( . )TTlovin View Post
      2 inch drop
      Rubbing ? yup
      Good bit of poke there.
      What is your front lip?
    20. Junior Member
      Dec 13th, 2011
      Columbiana, Ohio
      74
      2008 Audi TT 2.0 APR tuned
      01-27-2012 10:52 AM #43
      Eibach springs-1.3 drop front .08 rear
      Tire size-245 40 18
      Wheel 18x8
      Can't decide between et35 or et45. I would like to keep my existing tire size, they're almost new. Prefer the look of the et35 (equivalent of running 5mm spacers). Concerned about rubbing. Any inputs or opinions would be greatly appreciated.
    21. Member
      Mar 4th, 2004
      Canada EH !
      1,190
      2011 Q5, 2011 A4 30th Anniversary, 2013 Boxster
      01-27-2012 11:28 AM #44
      Quote Originally Posted by robnami View Post
      Tire size-245 40 18
      Wheel 18x8
      Tough one to say for sure due to the drop. For comparison purposes, my 18 x 8.5 ET 35 with 245/40's had some minor rubbing. The 45's would be the safe bet and adding 5 mm spacers would provide a compromise allowing for the better stance. That said, the 35's will probably be ok and you can always fiddle with camber or eventually replace the tires with something that's a less square (if not 235's).
      Previous rides: B5 A4, B6 A4 Avant, B7 S4 Avant, B7 RS4, TTS
    22. Member TheSandeman's Avatar
      Jan 12th, 2011
      1,723
      Audi MK2 TT 3.2 CQ
      01-29-2012 08:52 PM #45
      Quote Originally Posted by Stevelev View Post
      Steve nailed it on the head. We have adjustable control arms. Just be advised camber does wear your tires more
    23. Member
      Apr 21st, 2010
      Lake Tahoe
      328
      2008 A3 VRT
      01-29-2012 09:25 PM #46
      Looking to install 18x9.5 +40 with stock tire size 245/40-18. Do you think I will have any fitment issues. That's 18mm out from stock. It looks to be perfect in the back. The front looks a little iffy.
    24. Member TheSandeman's Avatar
      Jan 12th, 2011
      1,723
      Audi MK2 TT 3.2 CQ
      01-29-2012 09:54 PM #47
      Quote Originally Posted by korben007 View Post
      What are your plans with lowering the car?
      Have a little closer look at the fenders in the front- the front fenders a little flared out than the rear. I have a square set up on my car and the front is tucking in more than the rear.
    25. 01-30-2012 01:01 AM #48
      Current Ride Height: maxed kw fronts and rear has the adjusters out
      Final Wheel Specs: 5x112 18x8.5 et 38 F and 18x9.5 et42 R
      Wheel Brand & Model: CCW Classic
      Tire Brand & Size: I forgot
      Rubbing?: Nope
      Same as above except wheels are Work Equips 18x8.5 et 30 F and 18x10 et 38 R
    26. Member
      Apr 21st, 2010
      Lake Tahoe
      328
      2008 A3 VRT
      01-30-2012 02:20 AM #49
      Gonna lower on the H & R Springs so nothing crazy. I'm sure ill have to grind the rear bumper tab a little just don't want any major issues since its my wifes ride
      Current Rides:
      2000 Toyota Celica GT-S Supercharged - 2008 Audi A3 3.2 - 2003 Audi RS6 Avant - 2008 Audi TT 3.2 - 2002 S6 Avant Manual w/ S8 engine - 1990 Audi Coupe Quattro(SOLD) - 1993 Toyota MR2 Big Turbo(SOLD) - 2000 Audi S4 Stage 3(SOLD) - 2001 Audi S6 Sedan (SOLD)
      Check Out My Facebook
    27. 02-23-2012 12:12 AM #50
      Just bought an 09 3.2L MT quattro Roadster. It has the 10 spoke 18" bicolor rims with run flat tires. I've got plenty of time, but what do people recommend for winter? I intend to drive this most of the year. i want to maximize traction in the winter months and I'm thinking I should go with 17" rims and a slightly narrower winter tire. Will that pose any problems or is it totally unnecessary?
      thanks
