Here's an article written by a coworker that covers the basics of dyno numbers. It covers the basic misconceptions well, although it has an overt anti-dynojet slant.
Why the Horsepower Numbers Will Never Match
I have worked for SuperFlow commissioning new chassis dynos for 13 years1. During this time I have provided countless training sessions with customers who purchased SuperFlow products; read volumes of technical documentation, magazine articles and marketing hype; and endured the complaints of nearly every customer I ever met about why their dyno numbers don't match those from another dyno. In this document I explain this so you, the reader and new dyno owner, can think about how to handle this issue.
Take the information in the following paragraphsas my experienced opinion, mixed with words found on the Internet or from magazine sources. I try to identify those sections so as not to completely plagiarize what others have said, but in some cases, I simply do not know who theauthor was, so blame me and I'll assume credit for the information. Some of it is based on actual physical science, so I cannot take any credit for those sections—that stuff existed long before me.
A great book for any new dyno operator to read is Dyno Testing and Tuning by Harold Bettes and Bill Hancock. These two guys have over 50 years combined experience in the dyno business and offer some good general guidelines to help make the most of the business you are entering into. I make no money from the book sale and just think it is a good primer to read.
What's the Difference between Your Dyno and a Dynojet?
In the chassis dyno world, Dynojet has the bulk of the market. They've been around the longest, are affordable, and are easy to use. But, do they produce real horsepower numbers bound by the laws of physics? Read on.
Since Dynojet is the most popular chassis dyno, many people compare the numbers they get from their dyno, regardless of type or brand, to those obtained from a Dynojet. It doesn't matter whether it is an inertia dyno or loaded dyno, motorcycle dyno or car dyno—Dynojet is still the most likely comparison you'll see. If you see chassis dyno numbers in a marketing brochure, a magazine article, or on the Internet, they most likely came from a Dynojet, or they've been manipulated to appear as if they came from a Dynojet.
1. Written by Bret Williamson, SuperFlow Technical Support Engineer.
Bottom line: if you are using a dynamometer other than a Dynojet, your numbers will not match theirs. Period. End of discussion.
Wow, that's a pretty bold statement, Bret. Can you explain why? Yes, I think so. Some of this is going to be a little technical, but stay with me to the end, and hopefully it will all make sense.
How is Horsepower Determined?
Perhaps the first thing you need to understand is how horsepower is measured and what it is. First, it cannot be measured: it must be calculated. You can measure torque, revolutions per minute, and acceleration, but you cannot measure horsepower. No one can. It is always derived by measuring something else. Horsepower is the ability to accomplish a specific amount of work in a given amount of time, such as moving a race car down a quarter mile track in 10 seconds. Torque alone accomplishes no work—it is only a force. Thus, when a force (torque) is applied to an object and displacement of the object (movement) occurs, work is performed. Power, then, is the rate of performing work, expressed as the time derivative of work.
The physics behind this did not come from SuperFlow, Dynojet, or any other dyno manufacturer. It came from an inventor, James Watt. Please read about him here:
http://en.wikipedia.org/wiki/James_Watt
Mr. Watt wanted to sell steam-powered engines and needed a marketing scheme to convince the buyers how much more work the steam engine could do over the work of a team of horses. He was no different than you, as your dynamometer is a way to convince car or motorcycle owners you can give them more power to win races, impress friends, or simply boost their ego. Mr. Watt gave us the following equation:
Torque ×RPM
Horsepower =-----------------------------------------
5252
Many of you probably want to know where the constant 5252 came from. The Internet has many links where you can read about this, so why rewrite it all here? Here's a great link to start with:
http://en.wikipedia.org/wiki/Horsepower
When you finish with that link, go here to read more:
htt p://www.epi-eng.com/piston_engine_technology/power_and_torque.htm
I reproduce the explanation in this Web page at the end of this document. It is simply one of the best explanations I have ever found.
In simple terms, for those of you who do not want to read about it on the Internet, one horsepower is the ability to lift 550 pounds one foot in one second, or 33,000 pounds one foot in one minute. A few great athletes may be able to do that, but most of us cannot, so we rely on an engine to do it for us.
How Does This Work on a Chassis Dyno?
Unfortunately, with most chassis dynos (those without in-line torque transducers), the math is a bit more complicated than what Mr. Watt gave us above. Generally, there are two types of chassis dynos:
Those that can only measure a rate of acceleration of a known mass, sometimes called “inertia-only dynos” or “accelerometers”
Those that can do the above, plus have some type of load device—usually an eddy current Power Absorption Unit (PAU) or fluid brake
Only a few chassis dynos can perform loaded tests, as they have no “rolls of mass” to accelerate.
What you need to understand is that the fundamental physics in all dynamometer types still must correlate to Mr. Watt's equation. It must be used in some form or another to compute the correct horsepower.
Let's examine the equations used in a SuperFlow chassis dynamometer. Afterward, ask yourself if you think these formulas should apply regardless of the dynamometer manufacturer. SuperFlow did not invent these equations; they are derived from Mr. Watt’s equation and other basic physics fundamentals. The basic equation SuperFlow uses is:
InertiaPower +DynoLosses +AbsorberPower =WheelPower
The inertia power is nothing more than a measurement of acceleration, as in revolutions of the roll in a given amount of time. SuperFlow, as do other dyno manufacturers, must provide the software with a known value of equivalent inertia mass (in this case, the roll) which is derived through a very thorough process. In SuperFlow's case, the process was certified to use in the IM240 emission dynos we developed in the early 90s. For the most part, you simply must trust that these numbers are valid, as you really have no simple way to prove otherwise.
In an inertia only dyno, we must compute the force moving the rolls. An acceleration value is derived by comparing the velocity of the surface of the rolls from one revolution to another. SuperFlow does this comparison many times during one revolution to increase the accuracy of the acceleration measurement. Others (such as Dynojet) may only do this once per revolution.
After finding the acceleration value (in this case, miles per hour per second), power can be computed as:
InertialMass ×Acceleration inGs)
(× RollSpeed 375
Using English units, the roll speed displays as miles per hour. The constant, 375, is a convenient way to convert units: 1 hp = 375 lbf times mph (taken from the Wikipedia link to horsepower mentioned above). The inertia times the acceleration portion of the equation is the force (torque) applied to the roll. Look hard enough, and you'll see Mr. Watt's equation in there.
Now how about dyno losses. What are these? Very simple: any time we rotate something, we use a little power doing so. Nothing is friction free, and certainly not the dynamometer rolls. Frictional losses occur when rotating in their bearings. Windage losses occur as they spin through the air. These losses consume some of the vehicle power applied to the rolls during the test. To properly compute power applied to the rolls, we must add this lost power to the inertia power calculated previously. SuperFlow determines these losses at the factory. The values are embedded in the software, and a lookup function is used to add them back into the power equation during any type of test. Other dyno manufacturers must do the same.
How do you know the loss values being used are accurate? SuperFlow provides a calibration sheet with every chassis dynamometer it sells. I cannot speak for other manufacturers, but they must add back in parasitic loss data, or else the power numbers produced when testing a vehicle will be incorrect. Here is SuperFlow's formula:
(InterpolateRollSpeedToLookupTableHP)×CurrentAirDensity
The air density portion is necessary for correct windage loss computations. The lookup table looks like this:
So, for any given speed in mph, a horsepower value is looked up on the table and added to the power derived through acceleration (inertia power).
Now let's look at the last part of the equation: absorber power. This portion of the equation is used only if the dyno has a PAU attached so it can apply load. Part of the PAU includes a device called a strain gauge which provides an electrical means of measuring a force—in this case, torque. This is a real, indisputable measurement of exerted force. The dyno manufacturer normally provides a means to precisely calibrate this device using some certified weights and a calibration arm of specific length. SuperFlow does.
The formula is quite simple, as it resembles Mr. Watt's equation with only slight variations. Since the power is exerted at the roll, the equation must use its torque and rpm references at the roll, not at the engine. Thus, the equation looks like this:
RollTorque ×RollRPM 5252
There is no need to measure engine rpm because we are only concerned with the revolutions of the roll. This is why obtaining wheel power figures from a chassis dynamometer does not require the operator to hook up a device to obtain engine rpm. It simply isn't necessary in any of the wheel power formulas.
That's it—the calculations we use to compute wheel horsepower are no longer a secret. Those of you content with knowing this information may now stop reading and use your dynamometer for its intended purpose—to provide a baseline and evaluate changes to the vehicle and their impact to that baseline. For those of you who live and die by the numbers, read on.
The “Zen of Inertia” by Mark Dobeck
In 1985, the Dynojet dynamometer became a product for anyone to purchase. Dynojet founder Mark Dobeck decided everyone could benefit by having a chassis dynamometer, so he set out to build and sell them. Much like Mr. Watt, he had other motives: he needed a way to prove his jet kits worked so he could sell more of them. Mr. Dobeck succeeded in producing and selling a chassis dynamometer and has long ago sold off his interests in the company. He gave an interview to Sports Car International that was published in March 2006. The most revealing part of that interview is extracted here for your entertainment and understanding:
“One of the biggest headaches of Dynojet's go-it-alone chassis dyno project was figuring out how to assign meaningful power numbers in the face of unknown inertia from the moving parts of hundreds or thousands of engine, drivetrain and tire combinations.
Wrestling to fully understand inertia and powertrain losses, Dobeck and his team quickly realized that the standard physics formula of weight, time and distance for converting acceleration into horsepower simply didn't work right. Even after eliminating all drivetrain losses and attempting to account for all heat loss in the vehicle and dyno systems, the derived number was always lower than accepted numbers.
The Dynojet team poured on resources and burned up time and money investigating the Mystery of the Missing Power. But no matter what it did, the mathematics never added up.
Dynojet's final number fudge—which would eventually be applied to every vehicle strapped to a Dynojet chassis dyno—was arbitrarily based on a number from the most powerful road-going motorcycle of the time, a 1985 1200-cc Yamaha VMax. The VMax had 145 advertised factory horsepower, which was far above the raw 90 horsepower number spit out by the formula. Meanwhile, existing aftermarket torque-cell engine dynamometers delivered numbers that clustered around 120.
Always a pragmatist, Dobeck finally ordered his chief engineer to doctor the math so that the Dynojet 100 measured 120 horsepower for a stock VMax. And that was that: for once and forever, the power of everything else in the world would be relative to a 1985 Yamaha VMax and a fudged imaginary number that was close to the 'agreement reality' of the average of some other imaginary numbers.
Dobeck's engineering staff was dismayed by the decision. But the Dynojet 100 measured surplus power available to accelerate the vehicle' mass—no more, no less—and that was true even if the power modification was a low-inertia flywheel or lightweight wheels. As long as the inertial dyno's numbers were repeatable, the critical question of whether a particular mode make the engine accelerate faster or slower would be answered correctly.”
Dobeck then began selling the new “bogus meter” to dealers all across the USA. But whether the numbers were right or not didn't matter, because at that time, his was the only game in town, and no one knew differently. Again, if the dyno was used to provide a baseline and then evaluate how a change to the vehicle impacted that baseline, it worked great!
So what does the “imaginary number” Dynojet employs mean if you do not have a Dynojet dyno? In the article above, if you do the math, it appears Dobeck manipulated the numbers by as much as 33%. It simply means your numbers will never match those produced by a Dynojet. Period. End of story. That’s because Mark Dobeck and his team of engineers changed the laws of physics. So stop trying to make the comparison.
Ah, but there are many Dynojet dynos in the marketplace, so the comparison is inevitable. Some current estimates of the difference range from 5% all the way to 21% over true rear-wheel horsepower and anywhere in between. Some even believe it is a sliding scale, based on horsepower or speed of the vehicle. Try to get the actual formula from Dynojet, and they will give you their “it's proprietary” rhetoric.
Regardless, it is simply not a real number, but a Dynojet number, and should be referred to as such. The horsepower terminology should now include a term called DJHP to indicate the numbers were derived from a Dynojet machine and cannot be duplicated on anything other than another similar Dynojet machine.
In a sense, the imaginary number created by Dynojet has ruined this industry but certainly has been a boon for them. The consumer of dyno services is often only interested in an ego-boosting figure, and the Dynojet certainly delivers on that aspect. The other manufacturers are forced to supply additional power calculations to attempt to “match” the magic number derived from a Dynojet.
SuperFlow's WinDyn™ software easily allows for this, and we encourage customers to use these figures if their market insists upon it (most do). We default the imaginary number to 10% (a multiplier of 1.10 to the standard SAEPwr number) based on feedback from our customers who make comparisons to Dynojets, but it can be adjusted to suit your market if necessary. We identify the resultant numbers as DJWhPw and DJWhTq, separate from the real SAEPwr and SAETrq numbers that have no magic applied to them. Take a look at the graph on page 2 of this document for an example.
Nevertheless, I have heard the same story over and over: “But I just want to give my customers the real numbers—no bull.” I admire your integrity, but in most cases, you won't sell any dyno time to your market. It is because the customers simply do not understand what has been going on for over 25 years. Sure, you can try to educate them, and we encourage that, but that gets old over time; for most, it's just easier to give them the ego-boosting numbers they expect and take their money.
By the way, it may interest you to know that even though SuperFlow can provide the real numbers and the imaginary numbers on the same printout if desired, as of this writing, a Dynojet dyno cannot. That’s because there is no way to obtain a true horsepower number that follows the laws of physics from a Dynojet.
Torque ×RPM
5252
(× RollSpeed 375
