Dyno Help
21K views 1 reply 2 participants last post by  rotundapig
Just purchased an '04 GLI 1.8T
After a complete paint job I had it in for a stock dyno run.
Flashed APR Stage 1 and completed a 93 Octane Run
These are to be my base runs for all future mods.
The runs are all done
WHP@MPH
WTQ@MPH
Why would the runs be recorded this way instead of @RPM? What use are they?
#2 ·
The dyno records speed of the roller (and wheel) in mph. You can read rpm from the ignition system, but with COPs it's a bit trickier to do, and unless you tell the operator to do it specifically I'm not surprised that they didn't do it.
If you want to know the rpm that your runs were done at, all you really need to know is what gear the pulls were done in. You can check the rpm/mph ration by simply driving in that gear. This will only be as accurate as your speedo, so you can also look up the gear ratios for your tranny and get the rpm from mph numbers.
