Fourtitude.com - Manual to DSG swap
    Page 2 of 2 FirstFirst 12
    Results 26 to 34 of 34
      Jan 8th, 2012
      the netherlands/europe
      348
      2.5 T corrado syncro 1997/4 motion 2018
      01-17-2012 03:24 PM #26
      [QUOTE=GTM libra;74669870]Hi,
      One thing you certainly need more is a DSG stick. The stick has a build in controller which tells the box (via CAN) to change between neutral, drive, reverse etc. With the stick you can also do manual changes. So far I did not get the paddles to work, but I am still working on it.
      Reverse light and speedo are two other things that are not working in my car.
      I do not have a problem with gearing. I used a box from a MK5 Golf GTI, which has about the right gearing for my application (800 Kg RWD sportscar) I do have a lot less power however. The DSG is specified to handle max 350 Nm, some folk put a lot more to it and it survives. Increasing the pros sure on the clutch helps preventing clutch slip.
      If you are searching for someone who might be able to put other software in your mechatronic you can contact JD engineering in the Netherlands.
      He changed the software of my friens DSG in his golf mark 2. The clutch can handle now 450 Nm.
    3. 03-09-2012 02:23 AM #27
      In China. totel we have total 4000 consumers DSG issue. around 200 changed the gearbox.unfortunatly, we are only 4 years or 150,000 km guarantee period. we will complaint DSG with your guys.
    4. Semi-n00b
      Apr 24th, 2008
      15
      04-01-2012 02:26 PM #28
      On a similar note, does anyone know if you need to code a different DSG box into a car is you swap it? I have a gearbox from a 170TDI which is higher geared which I am going to swap into my 104TDI, just wondering if it will need coding/ or even work? Physically it is looking the same
      Apr 27th, 2011
      San Diego
      389
      2012 CW GTI Autobahn w/DSG
      04-01-2012 03:13 PM #29
      Quote Originally Posted by zhengmin333 View Post
      How many DSG cars are there in China?
    7. Junior Member
      Nov 12th, 2008
      29
      05-05-2012 07:16 PM #30
      Another one here looking to make the swap
      I have passat '08 2.0TFSI with tiptronic and APR stg3 on it.
      Have anyone finished the swap?What about the mounts,the flywheel and the driveshafts?are the same??
      Thanks
      George
    8. 06-04-2012 11:14 PM #31
      Above 500,000 dsg cars in China. Unfortunately,most cars equied with dsg have the same problems.And many consumer have replaced the gearbox many times.
    9. Junior Member
      Mar 4th, 2011
      20
      MY2011 Seat Leon Cupra 2L TFSI
      04-04-2014 02:04 PM #32
      Thinking myself of doing it and yes my car came from factory with the dsg option, so what are the parts needed ?
      - DSG gearbox
      - gear selector
      - double pedals kit without clutch
      - engine starter
      - wire loom from gearbox to can bus
      - axles ?
      How do you remove/delete the hydraulic clutch circuit ? (will check into etka/elsawin later)
      Thanks.
    10. Member VWRally's Avatar
      Oct 7th, 2016
      Cle Elum, Wa
      130
      '77 Rabbit 16v DSG, '01 BMW 325i, '98 Audi A4 2.8
      07-04-2019 02:01 AM #33
      Anyone know here got one of these on the road yet? I have one bolted into a corrado, working on axles and a flywheel. I hear the tiguans have the same crank bolt pattern as the old 4 cyl blocks, anyone confirm?
    11. Member jimivr6's Avatar
      Feb 18th, 2003
      ft lauderdale, fl
      830
      2 92 corrado slc,97 gti,01 cabrio,97 cabrio,02 ttq roadster
      08-17-2020 10:55 AM #34
      Quote Originally Posted by dj_spark View Post
      - DSG gearbox
      - gear selector
      - engine starter
      - axles ?
      Thanks.
      Yes dsg box with harness
      Shifter with harness
      Starter
      Axles
      Flywheel early mk5 GTI,gli, eos Tiguan has 6 bolt flywheel
      For older cars
