Fourtitude.com - fitting a DBW gas / throttle pedal into a MK2
    Results 1 to 17 of 17
    1. Member elRey's Avatar
      May 15th, 2001
      8,024
      16vt 2.0L MK4 Jetta Wagon | B6 A4 Avant
      01-29-2010 05:35 PM #1
      I've seen where someone trimmed the DBW brake/gas cluster, but has anyone used just the gas pedal? If so, how did you mount it?
      Thanks,
      Rey
    3. 01-29-2010 10:27 PM #2
      i get the mk4 gas and brake cluster, the drill the spot welds off the throttle bracket. once its off you can cut the pedal mounts off the mk2 cluster you want to attach the dbw bracket. it lines itself up literally. a few tack welds and some black spray bomb your done. this way the pedal sits the same as stock.
    4. Member hallkbrd's Avatar
      Apr 8th, 2000
      Oklahoma
      2,328
      Restomod Corrado 1.8T
      01-29-2010 10:37 PM #3
      Yes you can just do the throttle peddle... from my swap page:
      I worked a little this morning on the DBW issue. Here are a few photos to show the differences between the pedal angles and pivot point areas.
      First, this is how the original one it sits in the Corrado. Notice how it is to the right of the pivot point:
      Next, here they are side by side (from the side). I have put the pivot of both at the same location:
      Here is a view from the front, with the pivot points overlapped:
      I intend to cut off the right side part of the bracket where the pivot point is for the original pedal. Then I will see what the offset needs to be for the three mounting holes. I will need to obtain or create a mounting bracket for the new DBW pedal after that.
      A life frittered away disgusts God; he loves those who run straight for the finish line.
      Never Ending 1.8T Corrado Project
    6. 01-31-2010 07:00 PM #4
      my mk5 pedal bolts to the floor where the old pedal stop used to be 5 min install
    7. Banned dubbinmk2's Avatar
      Jan 15th, 2008
      planet earth
      9,028
      A2 86 Golf
      01-31-2010 08:45 PM #5
      Quote, originally posted by kevinmacd »
      thats dope very good to know knowledge is power!!!!!!!!!!!
    8. 08-03-2013 09:15 PM #6
      Looking for some pics, DIY, whatever anyone has found in the last 3 years. I read the above thread and got some ideas. any help would be appreciated.
    9. 08-18-2013 12:40 PM #7
      ya me too...i need to get this done for my AWW swap
    10. Member Apsik's Avatar
      Nov 12th, 2005
      Poland
      213
      '89 VW Golf 2.1 16VT AWD, '02 Audi A3 1.9 TDI PD
      08-18-2013 08:16 PM #8
      This is easy, here you have some DBW gas pedals
      At the back of the pedal you can find 3 holes (7mm diameter), that's how it bolts to the MK4 chassis. You can not bolt it directly to the MK1/2/3 chassis/firewall because it will be to much to the front and because of the floor shape it won't be moving.
      All you have to do is to make a bracket (2mm thick steel) with either 3 holes or 3 6mm thread studs and weld it to the MK1/MK2/MK3 chassis. Before welding anything check the pedal height to make sure it moves in full range and line it up with clutch & brake pedal.
      It is only theory but I hope is helps.
      One more thing. SWAPing 1.8T or other petrol engine from one MK4 chassis into another MK4 chassis does not require replacing the gas pedal. Tested it on 1.4 & 1.6 MK4 - it works.
      You have to replace the pedal if you SWAP TDI into petrol chassis or the other way.
      MK5/MK6 pedal is different than MK4 because it looks like this:
      but on some cars like Touareg, Q7 etc. you will find MK4 style pedal.
      Anyway if you have the pedal which bolts to the floor you don't have to do any kind of bracket.
      Simply bolt it to the MK1/2/3 floor Drilling is easy. I will post some pictures tomorrow.
      Because I just fit MK6 pedal into Corrado
    11. Member
      Sep 11th, 2009
      MN
      861
      1990 Corrado AWP 20v 1.8T
      08-19-2013 12:15 AM #9
      mine.
      it's not that I can't do it, it's that I don't know how yet...
    12. 08-19-2013 01:51 AM #10
      20VT do you have the mk4 pedal bolted back to the corrado cluster??? how did you make that work??
      i'll have to start pull my corrado pedal assembly and get working on this
      Sep 11th, 2009
      MN
      861
      08-19-2013 06:21 PM #11
      Quote Originally Posted by jettag60 View Post
      Bent the tabs that held the cable pedal in and welded the bracket to the pedal cluster.
    14. Member elRey's Avatar
      May 15th, 2001
      8,024
      08-20-2013 07:53 PM #12
    15. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,728
      08-19-2016 11:59 PM #13
      Quote Originally Posted by kevinmacd View Post
      Do you have any pictures? I'm debating what route I will go for a pedal on my Corrado 3.6 swap. I've read that I can use the mk7 firewall mounted pedal or the b6/mk5 floor mounted pedal.
      Thanks
    16. 11-09-2019 05:34 PM #14
      figured i'd update this thread for anyone else who needs to do this
      https://www.fablessmanufacturing.com...vw-mk2-corrado
      anyone use one of these before?
      for the shear ease i will be ordering one. i can't weld and this really looks like a nice clean option.
    17. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,728
      11-09-2019 10:00 PM #15
      I used the S&P adapter for the mk4 pedal in my corrado (same as a mk2)
      https://s-pautomotive.com/product/mk...t-dbw-adapter/
      Works great
    18. 11-25-2019 02:27 PM #16
      got my bracket from fabless, great looking product.
      one question, is there a difference between the auto and manual mk4 gas pedals?
      my pedal has the two top holes and the bottom one is split in the middle, kinda like a triangle
      where as the adapter has the two top lugs and one directly down in line with the left lug
      do i have an auto gas pedal?
    19. Member westbeach4's Avatar
      Aug 19th, 2006
      Puyallup
      272
      Built mkv gti, mk2 8v, Foha mk2 24v, Project mk2 1.8t, Built Xj, MK4 Tdi Wagon
      12-01-2019 09:35 PM #17
      both auto and manual gas pedal will work. Manual comes straight down. auto has a bend but comes down in the same spot.
      8:30 in the video
