Fourtitude.com - I get water at my front floorboards (passenger side > driver's) when it rains?
    Results 1 to 8 of 8
    1. Member MattL@S.D.'s Avatar
      Mar 3rd, 2007
      San Diego
      122
      95' VR6
      01-22-2010 11:26 PM #1
      I have a 95 GTI and when it rains I get water in my front floorboards (passenger side greater than drivers side). I don't have any rust on my car, I can't see water running down from the sunroof, and it is not the heater core.
    3. 01-23-2010 10:31 PM #2
      Check the drain for your A/C if you have A/C. Mine clogged and would do the same thing I could also hear the water flowing when I turned after driving for a while an hour or two. The drain is under the heat shield on the fire wall.
    4. Member MattL@S.D.'s Avatar
      Mar 3rd, 2007
      San Diego
      122
      95' VR6
      01-25-2010 12:40 AM #3
      Thanks, I will check the AC drain!
    6. n00b EdsTwin13's Avatar
      Jun 2nd, 2009
      Columbus, OH
      4
      1987 Jetta
      03-12-2010 11:31 AM #4
      If that didn't work and you're still having problems, check your window seals. The rubber on my window seals dried up and pulled away from the windows, causing water to run into the door, then spill onto the floor of my car.
      "I couldn't find the sports car of my dreams, so I built it myself."
      - Ferdinand Porsche
    7. Member marauder228vw's Avatar
      Jul 2nd, 2009
      Made in Dade, Fl
      1,256
      sw20 mr2, z33 fairlady
      03-16-2010 10:49 PM #5
      I have the same problem in my mk2,where can I get new window seals
      Parked!!1
    8. Member 1BadTitan's Avatar
      Jan 14th, 2010
      MD/PA
      1,102
      2010 Toyota Tundra Rock Warrior, 2015 Passat Sport, 02 GTI 1.8T, 05 Suzuki GSXR750, 03 Suzuki LTz400
      04-05-2010 10:19 AM #6
      Where can I find the AC drain
      If a$$holes could fly, this place would be an airport.
    9. Member evol_mk3's Avatar
      Dec 27th, 2001
      Northern VA
      2,638
      97 VW GTI VR6, 93 Corrado SLC VR6, 08 Passat Wagon 3.6 4MO
      04-09-2010 03:51 PM #7
      check your sunroof drains... you can also get a hose, spray water (for a little while) and check for leaks around the front window too.
      Juston
      Stumblers C.C. (VA Chapter)
      "I'll fight for my brothers. I'll die for my family. Don't preach about peace. Cause it just seems like fear to me" - D.B.D.
    10. Member 1BadTitan's Avatar
      Jan 14th, 2010
      MD/PA
      1,102
      04-09-2010 09:07 PM #8
      Quote, originally posted by evol_mk3 »
      Juston
      Thats exactly what it was... Sunroof drain, the hose came disconnected from the door boot and ran right onto the front floor. I had to remove the dash to reconnect everything, what a PITA.
