Fourtitude.com - Spark Plugs
    Results 1 to 21 of 21
    Thread: Spark Plugs
    1. Member 16racer's Avatar
      Nov 29th, 2005
      Washington State
      451
      Early Roccos
      05-26-2009 10:30 PM #1
      Curious what everyone runs for plugs in their vw racers.
    3. 05-26-2009 11:02 PM #2
      I use Bosch W3CC or NGK BR10ES or B10EV (when I can find them). Very cold "heat range" for the 14:1 compression I run.
      MC
    4. Member 03_jeeta's Avatar
      Sep 11th, 2008
      Olympia, Wa
      261
      2003 Jet GLS
      06-12-2009 04:58 PM #3
      bump
      this is a good subject and was glad i searched before asking the same....any other suggestions?
    6. 06-14-2009 11:45 PM #4
      ngk tripple prong plugs. more compression. lol
    7. Member flyinglizard's Avatar
      Aug 6th, 2006
      Spring Hill, FL. USA
      930
      FSP. ITB,wide body,Chumpcar
      06-15-2009 09:27 AM #5
      NGK triple or Bosch triple .WR7dtc
      The http://www.fwdracingguide.com/ Money back guarantee!, You can go 100$ faster with this 20$ guide
      Mike and Michael Ogren, Protech Racing,25 yrs of Racing VWs. [email protected][/email], 352.428/8983
    8. 06-18-2009 11:27 AM #6
      Quote, originally posted by flyinglizard »
      I thought the Bosch WR7dtc was NLA?
      my oil stain is bigger than yours
      the Race Dasher Project is now on Facebook, 180hp and 188tq... while miss-firing BADLY
      the Dasher Owners Group is now on Facebook
    9. 06-18-2009 12:25 PM #7
      NGK Iridium - bkr6eix
    10. 06-18-2009 12:27 PM #8
      Quote, originally posted by mgyip »
      how do you like them compared to traditional plugs, or dare I say vs Platinums?
    11. 06-18-2009 03:05 PM #9
      I'm quite pleased with Iridiums - I made the switch b/c of a rumored HP gain (very minimal - maybe 1 or 2) over Copper or Silver plugs but after 6 years with them, I have no complaints. In fact, I use the same plugs in my street car.
      For whatever reason, platinum plugs don't work well in 16v cars. I used one set that caused to car to have a horrible mis-fire. Turned out the plug had carboned up...don't know why or how and haven't had a problem with other similar style plugs (tri-electrode).
    12. 06-18-2009 03:09 PM #10
      For whatever reason, platinum plugs don't work well in cars
      very common complaint... the only cars that seem to run well with them had them "stock", but then the cars run even better when switched to coppers (i.e. there was a writeup from a Mk4 driver who proved it with his 1.8t)
      Oct 13th, 2004
      Frankfort, IL
      1,823
      81 Rocco S Race Car, 84 Rocco Race Car, 15 TDI Golf Sportwagon, 15 TSI Passat
      06-21-2009 05:07 PM #11
      It's kind of important to post what configuration you are running.
      Holley Carb
      14:1 Comp
      8V
      NGK Racing Plugs #8
      #R5672A-8
      We change ours every couple of race nights to get A/F reads on the plug.
      Craig
      Check out my Ebay auctions for Earl's Performance Braided Hose ends - NOS pieces for 50-60% the price of new. My Ebay Auctions
    14. Member
      Oct 13th, 2004
      Frankfort, IL
      1,823
      06-25-2009 08:33 PM #12
      what gap are you guys running?
      should i run .035 or .040"?
    15. 06-25-2009 09:21 PM #13
      Quote, originally posted by Shrttrackr »
      .030 is a good suggested starting point, if you experience spark "blow out" under boost, reduce gap .002 until it stops... .028 is considered "stock gap" for some VW engines
      edit... wait, Carbs on 14:1?
      what ignition system are you using?
      Modified by Southcross at 7:24 PM 6-25-2009
    16. Member
      Oct 13th, 2004
      Frankfort, IL
      1,823
      06-25-2009 09:49 PM #14
      yes one carb. holley 500 cfm 2bbl.
      i am running a mk1 Bosch Distrib -- older points style w/ pertronix electronic conversion
      i am running a pertronix epoxy coil (40,000V 1.5ohm). Morosso 8mm wires (blue max )
      we are not allowed to run an MSD box.
      i will be eventually be upgrading to a vw/audi 3a distrib w/o the knock sensor later this year.
      Craig
      Modified by Shrttrackr at 8:53 PM 6-25-2009
    17. 06-25-2009 10:08 PM #15
      assuming your not running resistor plugs... you could try .040, if you get misses, your gonna have to make the gaps smaller until it goes away
    18. Member
      Oct 13th, 2004
      Frankfort, IL
      1,823
      06-26-2009 10:27 PM #16
      ended up setting them at 35.....we'll see at the track tomorrow.
      what are signs will the motor give if i need to open the gaps up ?
      you guys ever index your plugs?
    19. 06-26-2009 10:46 PM #17
      unless your getting mis-fires... a Dyno will tell you
      I haven't indexed my plugs yet, but from what I read and understand... I believe in it
    20. Member gehr's Avatar
      Jan 27th, 2004
      5,803
      07-07-2009 10:33 PM #18
      Stock BKR5EKU......I can't do anything fancy to the motor anyway!
    21. Member Rabbit Farmer's Avatar
      Sep 21st, 2003
      Earth
      2,183
      MK1-MK4-WRX-Ford-Volvo
      08-05-2009 09:33 PM #19
      1.8 liter / 8V / Turbo / 25psi of boost
      NGK Racing Competition B10EGV (B-one-zero-E-G-V) The zero looks like an 'oh' on the plug.
      1.8 liter / 20V / GT2871R / 23+psi of boost
      Bosch Super F6DTC
      Steve
    22. Semi-n00b kosovoruss's Avatar
      Jul 16th, 2009
      E. Prov. R.I.
      15
      71, 76 Bug Conv,72 Bug Hdtp, 57K Orig, 2013 Turbo coupe hdtp.
      10-20-2012 01:08 PM #20
      Hi all, I have a 2007 GTI 2.0T that just turned 40K. I want to change the spark plugs. All I keep hearing about is NGK or Bosch Iridium plugs. I go to all of the local outlets and they look at me like I am from another planet unless I want Autolites. Can anyone give me part numbers for The NGKs or the Bosch. Car is stock and street driven only. Thanks
    23. Semi-n00b
      May 17th, 2008
      Australia
      16
      01-05-2016 06:33 AM #21
      Bosch F3CS, 13.5:1 compression, e85 Fuel
