Fourtitude.com - Ford Coil Pack on VR6 with Pics.
    Page 1 of 33 1234511 ... LastLast
    Results 1 to 25 of 811
    1. 01-28-2009 03:22 PM #1
      Hey Im a Newbie and felt I should share some knowledge of swaping a Ford EDIS 6 coil onto the VR6. Like alot of VR6 owners I started having Misfires. Knowing that the VR6 Coil is prone to failure I had no desire to buy a Brand New VW coil, Espicially for $330 at the local parts store. First I tried to cover it with epoxy that fixed some of the misfiring but not all of it. I saw a million GM Coil Pack swaps and the extra bracket and extra wiring to make them work, then I came across one guy who used a Ford EDIS 6 coil. Me being a Ford Guy at Heart It didnt take me long to Decide what I was gonna do. This swap is alot more straight forward and Stock Ford EDIS Coils are cheap and Never Fail. I picked up the Used Ford coil wiring plug and stock Ford plug wires off of a friends of mines Thunder Bird SuperCoupe.
      Here are some pics.
      Everything
      Ford Coil vs. VR6 Coil (note the bad epoxy job on the VW coil, ha)
      Almost fits right on there
      Ford plug soldered on and shrink wraped
      Ford Terminals on Stock VW wires
      Finished Coil
      Wires and Coil
      Finished
      Modified by GardenSnake at 12:24 PM 1-28-2009
      Modified by GardenSnake at 12:29 PM 1-28-2009
    3. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      20,568
      1943 Flugkreisel, 1945 VRIL-7
      01-28-2009 03:27 PM #2
      Congrats! As you know its been done before.
      http://www.gti-vr6.net/library..._pack/
      The original Dub and Dubber.
      Manche VWs sind einfach schneller als andere.
    4. 01-28-2009 03:32 PM #3
      Yes, that was the only other guy that I have seen do it. And since there are a million write ups for the GM coil packs why not have two for the Ford Setup? Also he is using a different style ICM and Coil Base, as well as he didnt convert to the Ford Style Terminals either.
      Modified by GardenSnake at 12:35 PM 1-28-2009
    6. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      20,568
      01-28-2009 03:49 PM #4
      When you look at the MSD pic with the ICM, look carefully and you'll see my (C) copyright.
      That was me that made the original wiring diagram with the 6 MSD coils, this was done in response to a question another member had.
      He was intrigued by this set-up, I have nothing to do with this one, nor is he using the VR6 ICM.
      So I made this diagram below for the forum member. With this diagram, others have chosen the 3 MSD coils and have made brackets. I have not made a cent off this, nor do you see credit given. As long as my name isn't erased from the diagram, people will make the connection. No pun intended.
    7. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      37,154
      15 Jetta 92 Corrado VR6
      01-28-2009 04:31 PM #5
      The car with the 6 MSD coils was BogeVR6's car, it was on Haltech and it ran a MSD DIS4 and a MSD DIS2 to drive them.
      -Paul
    8. Member ricardo's Avatar
      Feb 19th, 1999
      CA Bay Area
      6,969
      1995 mulberry GTi VR6 RIP, 1988 BMW E30 SETA, 2004 A4 B6
      01-28-2009 06:02 PM #6
      that looks more "stock" which is what Im looking for
      can you show the ICM to ford plug diagram?
      thanks
      "Public transportation......because you're poor"
      done everything that's cheap....broke the most expensive parts....
      having cooling problems? check this out http://the-corrado.net/forum/viewtopic.php?f=1&t=68720
    9. Member therealvrt's Avatar
      Jul 21st, 2004
      ottawa ontario canada
      9,787
      16 R
      01-28-2009 06:22 PM #7
      nice
      how does the car run with this? smoother? starts fine?
      #melnykout
    10. Member eurobred's Avatar
      Jun 10th, 2005
      Killa Cali
      8,914
      '91 2.9L VR6T, CCW'd '92 Corrado SLC
      01-28-2009 06:38 PM #8
      Quote, originally posted by Eric D »
      i'd love to run a setup like this on my VRT
      looks way clean
      R13 5
      ..24
    11. Member youlostme21's Avatar
      Aug 12th, 2008
      SEPA
      1,409
      98 S/C Vr GTi
      01-28-2009 06:45 PM #9
      You happen to know the part #
      I work at a FLM dealer and my parts guys is a dick about giving him Part#'s
      And as far as Kv goes, is it comparable to stock vw or higher?
      Modified by youlostme21 at 4:46 PM 1-28-2009
      If only I invested my money into something more practical then a VW....
    12. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      20,568
      01-28-2009 07:29 PM #10
      How about the 2001-03 Windstar coil pack?
      Looks like the coil towers might fit with the VR6 wire ends.
      Here is a Windstar wireset. Looks like Bremi/Beru etc ends, but I can't really tell from the small pic.
    13. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      37,154
      01-28-2009 08:37 PM #11
      Quote, originally posted by eurobred »
      looks way clean
      $60/ea for coils and about $600 in DIS boxes will get you there.
      -Paul
    14. 01-29-2009 10:11 PM #12
      The Car runs perfect now. I believe the Ford coil pack is a little stronger (higher voltage) than the VR6 coil as well. Since those pictures I have switched to lower resistance 8mm Taylor wires. My stock wires were going on 119k and I didnt trust them.
      Here is a diagram you asked for. Its not real pretty but you get the idea. Also the ICM is labeled with these same notations so you can match them up as well as Eric D has them shown on the ICM in his diagram.
    15. 01-29-2009 10:45 PM #13
      The Part Number for the Ford Coil is DGE456. I dont know if you care but you can get a New ACCEL coil for $50-$60. Probably cheaper than a Brand new Ford Motorcraft coil from a dealership.
    16. Member 97vr6blu's Avatar
      May 6th, 2008
      Northern CA
      646
      01-30-2009 02:14 AM #14
      That's f'n cool man - thanks! This is probably the route I will go - I noticed a crack in my coil body when re-assembling my GTI. And yes, you can pick up the new Accel coil off ebay for $55 shipped. Could probably get the wires from a junk yard cheap to have the factory ends, too.
      Modified by 97vr6blu at 11:18 PM 1-29-2009
      Gone & dearly missed: 1997 GTI VR6 in Windsor Blue
      Current: Red 2002 Focus SVT (Planned replacement: Mk7 GTI), 2012 Routan SE in white
    17. 01-30-2009 08:32 AM #15
      This is some really good ****. Thanks Man!! But Is this mean that i can run motorcraft oil on my VR6 and save some cash?
      Most people think Time is like a river, that flows swift and sure in one direction but I have seen the face of time and can tell you they are wrong. Time is like an ocean in a storm, you may wonder who I am and why I say this ,sit down and I will tell you a tale like none that you have ever heard.
    18. Member VLKWGN's Avatar
      Jul 11th, 2006
      860
      2,183
      stuff
      02-10-2009 04:47 PM #16
      [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Iam.
    19. 02-10-2009 08:04 PM #17
      Grassroots upgrades [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    20. 03-04-2009 03:55 AM #18
      How did you attach the brass colored Ford ends to the VR6 wires? Was there any soldering involved?
    21. 03-29-2009 01:06 PM #19
      I did this EXACT project on my wife's vr6 GTI.
      Worked Awesome! $25 for coil off what I think was a 1995 Ford Taurus maybe 3.0l.
      Sabre sawed the alum base to fit. made stand-offs to bolt it up. Works AWESOME!
      USED ACCEL wires, (not best option) went back to junkyard and got old plug wires for the ford ends. Haven't done that part yet.
      Thanks again for documenting this mod. WAS AWESOME, highly recommended.
    22. 03-29-2009 06:32 PM #20
      Ford also uses the VR6 in Europe, I wonder what coil-pack they use in these? It is some kind of van if I am not mistaken, Galaxy maybe?
    23. Member Grabbit's Avatar
      Apr 27th, 2001
      WA
      7,548
      Mk1, Mk2, Mk6, SR5 4x4
      03-29-2009 06:39 PM #21
      Quote, originally posted by AbsoluteNovice »
      The galaxy is just a vw van with a ford badge, most everything is still a vw part.
    24. Member Boost112's Avatar
      May 7th, 2002
      Miami/ Orlando
      5,531
      1995 VW : 2010 VW : 2016 VW
      03-30-2009 09:59 AM #22
      Quote, originally posted by 97vr6blu »
      found the ford accel unit on jegs for like $90... jegs makes one as well for like $80....
      Modified by Boost112 at 3:02 PM 3-30-2009
      question is what is the best way to do the wires.... how do you crimp the ends on to the vr6 wires... do you need to solder them on? can i just go down to discount and get the ends or is a junk yard better? any suggestions?
      Modified by Boost112 at 3:13 PM 3-30-2009
      --- SPACE FOR RENT---
      Quote Originally Posted by schwartzmagic View Post
      Those VRTs are so full of win :-D
      www.dubcartel.net
    25. Member Lord_Verminaard's Avatar
      Apr 6th, 2004
      Columbus, OH
      3,148
      1981 Scirocco S, 2008 Audi A3 2.0T, 2008 GTI, 1976 Kawasaki KZ400
      03-30-2009 10:58 AM #23
      This is cool! A question- with the ford packs, you don't need to fool around with resistors or other junk like you do with the GM DIS coils?
      Brendan
      '81 Scirocco 'S ...
      '08 Audi A3 2.0T FWD 6MT
      '08 GTI 2-doors, 3 pedals, no sunroof.
      '76 Kawasaki KZ400
    26. Member Boost112's Avatar
      May 7th, 2002
      Miami/ Orlando
      5,531
      03-31-2009 10:46 AM #24
      bump for other people....
      www.dubcartel.net
    27. Member UmbroVR6's Avatar
      May 23rd, 2000
      Miami, FL.
      11,121
      98 GTI VR6, 01 Jetta 1.8T
      03-31-2009 02:18 PM #25
      nice!
      LEASE THIS SPACE
