Fourtitude.com - Build: A New mk2 Rally Shell for mid 2009
    Page 6 of 6 FirstFirst ... 23456
    Results 126 to 148 of 148
    1. 03-14-2011 04:03 PM #126
      Quote Originally Posted by 91redjetta View Post
      this is an awesome project.. talked to you guys when you had the gas car at waterfest a couple years ago.. couldnt be a nicer group to get ask questions.. i would be interested in knowing more about the tubular sub frame.. thanks.
      as for the pedals.. arent you going to have to worry about mounting the fly by wire pedal for the tdi? or are you going to try to fab up something else?
      engine wise. the head have anything done to it? i'm kind of a diesel geek and have some bad influences and just wondered what you guys can get by with engine mod wise?
      thanks again and sweet build
      Thanks for the compliments. The tubular subframe was made by Eric Langbein Racing but I don't think he is producing them commercially.
      Pedals: Mounting up the fly-by-wire mk4 pedal for sure. I have it all mocked up, just need to grap a piece of aluminum to mfinish up the mount.
      Head: totally stock. The rules are open so we could go down any route mods wise. Funding and time are of course the big constraints.
      Got a few more small subsystems ready on satuday... Fan shroud, rear shocks, Fuel tank skid plate, some wiring, some dash stuff, accelerator pedal...
    3. 04-05-2011 05:39 PM #127
      more updates...
      Engine bay side of the gas pedal mount. A floor mounted throttle stop will prevent me from tearing this off the firewall.
      2" x 1.5" aluminum tube profiled to match the firewall. Floor mounted throttle stop will be added too.
      Gas pedal mounting detail. White is a urethane spacer due to the 1/8" contour under the edge.
      Pedals in and lined up. Now just need a cover and grip tape for the brake to match the clutch
      Another angle of the pedals installed. The clutch is not hooked to a master cylinder yet so I had to get my hand in there to hold it out.
    4. 04-06-2011 10:41 AM #128
      i understand about the subframe.. the gas pedal looks right at home.. another question is why chop the gas tank? or did you use the bottom of the one chopped up one to put under the other for protection? these thread is awesome.. so many sweet things going on.. rally x i cant wait..
    6. 04-07-2011 02:19 AM #129
      ...or did you use the bottom of the one chopped up one to put under the other for protection?
      Exactly that.
      The VW gas tank is pretty burly plastic, but extra protection is required by the rules. Double-layering it like that is legal for the second layer of protection, it's cheap, it's form-fitting, and you don't risk getting rocks in there set to poke the tank like you do with just a sheet layered over it.
      The biggest problem with using the stock VW tank is that if you have a bent right rear spindle or shock the wheel can rub on the filler neck. Well, that and the lift pumps have a habit of going out at Just The Wrong Time.
      Josh: you might want to seal the edges of that to keep sand/gravel out.
    7. 04-24-2011 08:12 PM #130
      Holes in firewall for mounting clutch:
      Firewall reinforcement plate fore clutch--Outside
      Firewall reinforcement plate fore clutch--inside
      Also added a vertical strut and backing plate
      Added a throttle stop
      Built a hard/soft line from the Willwood pedal & master to the clutch slave and bled it.
      Here you can see the Stainless braid flex section in the middle.
    8. 04-24-2011 08:18 PM #131
      Built an aluminum block off plate from the bottom that is sealed here with silicon
      View of cover plate from the bottom
      Holes for the shifter cables outside view
      Hydro Handbrake bracket & install:
    9. 04-24-2011 09:19 PM #132
      Quote Originally Posted by mhoche View Post
      Yeah, the lift pumps can be temperamental. Hopefully ours will hold up to pushing diesel :-)
      We sealed the edge on our other car's fuel tank doubler but this one fits much much better for some reason ---- maybe laying out in the sun for a few years :-) ??
    10. 04-28-2011 01:11 PM #133
      Tune in tonight for an interview on Rally Notes TV
      https://www.facebook.com/#!/RallyNotes
      Footage will be here at 7pm Eastern
      http://www.sportce.com/shows/rally-notes.html
    11. 05-12-2011 04:14 PM #134
      More pics of progress. Mostly the laying on of the noodley harness.
      Hope it all works after removing lots of wires (AC, ABS, Climate control, Fan control Module...)
      Carbon Door cards installed
      Wrestling with wiring harness
      Sunroof delete panel installed
      Rear end-plates from mk4 beam for futre rear brake project. Might get some of these laser cut so people can adapt mk4 rear stub axles, wheel bearings, hubs, etc... leaves the potential to go to 10"+ VENTED rear discs from the 337 & R32 cars.
    12. Member MrMook's Avatar
      Dec 2nd, 2006
      518
      4,830
      o_O
      05-25-2011 11:19 AM #135
    13. 05-29-2011 02:14 AM #136
      It seems to me that the gas and brake pedals are too far apart...Do you/can you still heel toe?
    14. 05-31-2011 02:21 PM #137
      Quote Originally Posted by Sead View Post
      Never found a need to heel/toe. Lots of left-foot brake but no heel/toe.
    15. 06-29-2011 07:01 PM #138
      What we have been up to besides attending yet even more weddings
      Plumbing for the intercooler, radiator, intake and exhaust is coming along. Updates as they are available.
      Spliced in the mk2 tailight harness to the mk4 chassis harness
      All the lights are on but nothing caught fire, melted, or sizzled
      AC Delete requires new serpentine routing and a custom tensioner. Thanks to Justin Carven at Greasecar for this one
      Replaced the rain gutters and all new weatherstripping for the doors and windows
      Gold foil for extra speed! (Zipties to keep the wires from flapping in transit on an open trailer)
      And, videos from Mount Washington Hillclimb last weekend in the Gasser (took 2nd place in class)
      Fog at the top
      http://youtube/NIR5QbcIDgw
      Exciting moment on the bottom of the mountain
      http://youtube/1KQS1Cq06Mk
      REALLY EXCITING moment on the top of the mountain leading to a flat tire
      http://youtube/yJQHjsrP95I
    16. Member MKIII_96's Avatar
      Nov 24th, 2006
      Herndon, PA
      1,488
      MK4 GTI 1.8t project and a 98 bug
      07-05-2011 09:54 PM #139
      is there a beater class in rally that i could enter my rusted out mk2 i wish i could get into this. looks like loads of fun, just too pricey. nice car too
    17. Member MrMook's Avatar
      Dec 2nd, 2006
      518
      4,830
      o_O
      07-05-2011 10:07 PM #140
      Quote Originally Posted by MKIII_96 View Post
      There's always rallycross.
    18. 12-05-2011 07:56 PM #141
      Can you enlighten me on the need for the lateral bar in this photo?
    19. 12-06-2011 12:59 PM #142
      Quote Originally Posted by Towona View Post
      To try to keep the frame 'rails' where the rear beam mounts from moving/bending/deforming when the rear end goes sideways into the ditches :-)
    20. Member Skinny Sumo's Avatar
      Dec 9th, 2009
      Quakertown PA
      239
      1969 BMW 2002, '73 BMW 2002, 84 VW Scirocco
      01-11-2012 06:32 PM #143
      NJMP just announced 4 rounds of rallycross this year! will we be hearing some diesel clatter at the front of the pack?
    21. Member G-K-R's Avatar
      Aug 27th, 2006
      Orange county NY
      1,432
      Evos and a gti thats taking forever to build itself
      01-16-2012 02:10 PM #144
      Quote Originally Posted by Skinny Sumo View Post
      I was so happy to hear about this. Now I just need to finish my car.
    22. Junior Member natep123's Avatar
      Feb 14th, 2012
      NH
      22
      1989 Golf MKII, 2013 FR-S
      02-17-2012 01:13 AM #145
      Great job on this build. How the hell do you have the time and resources to build such a high quality rallycar? i'll see you hopefully at NEFR2012.
    23. 02-29-2012 05:53 AM #146
      It is necessary to prepare for rally seriously) It well that such actions are carried out. Though I didn't participate yet
    24. 02-29-2012 01:19 PM #147
      Quote Originally Posted by natep123 View Post
      Well, it has taken over 2 years so far to get this one built. We would go a lot faster with the build if we didn't have another car that works perfectly already :-)
    25. Member dextervw's Avatar
      Sep 2nd, 2002
      East Greenwich RI
      2,307
      95 GTI TDI RALLY CAR
      03-08-2012 08:18 PM #148
      What are you doing for a dash? I've been debating the dash delete in my TDI rally car...
