Fourtitude.com - Tell me about your garage lighting
    Results 1 to 25 of 37
    1. Member Weakness's Avatar
      Apr 28th, 2000
      Palatine, IL
      2,868
      2010 VW GTI
      01-04-2009 05:43 PM #1
      I just finished building a house and need to get some overhead lighting for working on the car. I don't want those florescent tube lights that buzz. I would think LED would be the best way to go but appreciate some feedback.
      Step 1: Calm down about the CEL, embrace it, it adds more color to the instrument cluster
    3. 01-04-2009 05:45 PM #2
      i just use the tubes, never tried anything else, then again, that's what i have and it's good enough. also work outside too...
    4. Banned
      May 5th, 2008
      929
      01-04-2009 05:47 PM #3
      always used something like these. never noticed any buzzing sound though.
    5. Member VertigoGTI's Avatar
      Apr 1st, 2001
      Nati-licious
      10,025
      01-04-2009 05:48 PM #4
      LEDs are a tricky bunch. They don't have a lot of throw to them, so if you have a large garage, you'll need a LOT of them.
      I just bought a house and I'm doing LEDs in the ceiling with florescent tubes as a backup light. The only problem is that the garage is unfinished at the moment and to really make those LEDs work well will be to paint the ceiling and walls white.
      Quote Originally Posted by Surf Green
      The real world is more ruthless than TCL, and sensitivity was never one of Darwin's strong points.
    6. Member Art Vandelay's Avatar
      Dec 20th, 2005
      STL
      9,869
      SVO
      01-04-2009 05:48 PM #5
      I use some 500 watt halogen work lights mounted to a shelf at about 7 feet high, pointed down towards an open hood. The light quality is great for underhood work, and even bright enough to use while I'm working under the car. They are obviously not very energy efficient, but that works to my advantage when the garage is cold (they generate a lot of heat).
      LEDs for garage lighting sounds like a way to spend a spectacular amount of money. :shrug:
      JSW TDI, Mustang SVO, et al.
    7. 01-04-2009 05:50 PM #6
      one 60 or 100w incandescent light bulb.
      then again, our "garage" is only about 6 feet deep and is pretty much just a large storage closet.
    8. Member Gary C's Avatar
      Apr 11th, 2001
      here. there. who the hell knows anymore.
      10,666
      tonka truck, some old junk, a "few" motorcycles..
      01-04-2009 05:52 PM #7
      Personally... screw LED's.
      Go with T-8 florescent lighting and electric ballasts - specifically something in the 5000k or above range. That or if you don't mind the expense and your ceiling is high enough look into metal halide. Personally... I much prefer the T8 florescent setup. It's the only way to fly. Closest to natural sunlight without spending a truck load of cash. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      The key is the ballast if you run florescent. I say go with electric over magnetic every time, but that's just my 2 bits and using experienced gleaned from working garages...*hard*.
      make shiny.
      If crazy paid the bills.. I'd be freaking rich.
    9. Member
      Dec 31st, 2005
      SoCal
      16,492
      Corvette & SV650
      01-04-2009 05:55 PM #8
      Fluorescent bulbs don't have to buzz, just get good lamps. It's hard to beat the light output, the minimal heat output, power efficiency, low cost, and the even spread of light.
      If I could do it my way, I'd install them along the wall facing up and bouncing off a flat white ceiling. If I had lights in the ceiling, I'd have them sit flush with a frosted plate diffusing the light.
      Quote Originally Posted by apizzaparty View Post
      never thought once to use my lefty for the brake. sorry in my opinion it is dumb.
    10. Geriatric Member ATL_Av8r's Avatar
      Oct 17th, 2002
      Gapiana
      44,123
      2008 Camry Wagon
      01-04-2009 06:04 PM #9
      get flourescent lamps with an electronic ballast. it's the old-school mechanical ballasts that cause the buzzing noise
      MemeGate 2012 - First Responder, post #2
    11. 01-04-2009 06:05 PM #10
      No Longer : -=Camry Driver=- -=Camry Driver=- -=Camry Driver=- -=Camry Driver=- -=Camry Driver=- -=Camry Driver=- -=Camry Driver=- -=Camry Driver=- -=Camry Driver=- -=Camry Driver=-
    12. Member SpecialFX's Avatar
      Aug 19th, 2006
      Mauldin, SC
      3,644
      06 Stage 2 GTI, '93 Subaru SVX, '06 Honda Civic Coupe
      01-04-2009 06:10 PM #11
      LEDs are very energy efficient and put out good light, but they are poor lights for having to see very far away from the bulb. For overhead lighting, I say go with fluorescent tubes or compact. I have a mix of the 2 in my garage and it works pretty good other than I wouldn't have placed them the same way the builder did.
    13. 01-04-2009 06:11 PM #12
      Just use the tubes - bright, cheap and easy to replace. I have like 8 sets of them in my 3 car garage - turns night into day. Just put a stereo and cheap tv/dvd combo in while you're at it to negate the buzzing.
    14. Senior Member LT1M21Stingray's Avatar
      Sep 13th, 2006
      Somewhere North of Lyon Mountain.
      23,711
      SR71 C30 t53a/b/b
      01-04-2009 06:17 PM #13
      CFLs [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      I have seven 42W CLF bulbs with regular sockets, and I have plenty of light.
      http://www.1000bulbs.com/42-Wa...1086/
    15. Member Roadhog_'s Avatar
      Feb 25th, 2007
      Montana
      2,809
      19' R -- 93' Corrado -- 05' TDI
      01-04-2009 06:34 PM #14
      Quote, originally posted by Mtl-Marc »
      Is that dirt on your floor or is your floor dirt.
    16. Member
      Dec 31st, 2005
      SoCal
      16,492
      Corvette & SV650
      01-04-2009 06:39 PM #15
      Kitty litter?
    17. 01-04-2009 06:45 PM #16
      It looks like you have a house built on the beach
    18. Senior Member LT1M21Stingray's Avatar
      Sep 13th, 2006
      23,711
      SR71 C30 t53a/b/b
      01-04-2009 06:54 PM #17
      Quote, originally posted by oneofshempskids »
      It's a portable garage. I can bring it to the beach too. Wrench on the car, watch the girls in bikinis, etc... [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by Mtl-Marc at 7:01 PM 1-4-2009
    19. Member Weakness's Avatar
      Apr 28th, 2000
      Palatine, IL
      2,868
      2010 VW GTI
      01-04-2009 06:58 PM #18
      My garage is a 3 car tandem (2 side by side and 1 deep on my side) with 10ft ceilings, finished. I still need to paint them, but it will be high gloss for the light bounce.
      The tandem area is where most of the mower/snowblower/yard crap etc) - Work will be done over the two main slots in the front.
    20. Member
      Mar 2nd, 2005
      Reno, NV
      6,949
      2017 F-150 Lariat Supercrew w/3.5 Ecoboost & 10 speed auto, 2015 Nissan XTerra PRO-4X
      01-04-2009 07:01 PM #19
      Quote, originally posted by Weakness »
      or just use a semi gloss and save your corneas from the glare and potential 3rd degree burns
      Stock truck dyno: 340 hp, 464 tq
    21. Member Weakness's Avatar
      Apr 28th, 2000
      Palatine, IL
      2,868
      2010 VW GTI
      01-04-2009 07:40 PM #20
      Quote, originally posted by Wilhelm R32 »
      Good point... maybe I should have ordered the first aid kit for skin cancer.
    22. Member
      Mar 2nd, 2005
      Reno, NV
      6,949
      01-04-2009 07:50 PM #21
      Does your garage have smooth walls? If it has texture, you probably wont get the "light glare" you desire. I'd go with a good off-white semi gloss paint. Durable, easy to apply, or re-apply if you ever kool-aid thru a wall or anything. Plus, its cleanable [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    23. Member reelknead1's Avatar
      Oct 7th, 2007
      Charlotte, NC
      2,227
      Mk7.5 Golf R, Mk7 GTI PP
      01-04-2009 08:34 PM #22
      tubes above the car and then mounted on the side wall near the top so you have plenty of light when you pop the hood. that has worked great for me. also the new tubes don't buz
    24. 01-04-2009 09:32 PM #23
      Use florescent they have new ones that will light 0 deg. These lights don't buzz and are high efficiency. The electrician said they are around $150 each (his price) I circled each bay and its grate all most no need for a drop light.
    25. 01-04-2009 10:17 PM #24
      [IMG][https://www.storesonlinepro.com/files/1974975/uploaded/Philips%20Incandescent%20A-19%20Light%20Bulb.gif/IMG]
      That's all I have.
    26. Member
      May 28th, 2000
      Maple Grove, MN
      6,992
      8V, 16V, 20V, 30V
      01-04-2009 10:25 PM #25
      Thats what I'm using in our townhouse 2 car garage. I have 4 of them that are 6ft long each and they are great. I keep em on 24/7 in the winter and even when its -10 outside the garage stays 30 degrees or so.
      Quote, originally posted by skip57 »
