The baby 2.0T FAQ/DIY.
This is going to be a long work in progress but, it's about time it happened. PM me with topics you think should be added.
FAQ:
Chip FAQ - D.Passat00
Some stock MAF readings. - GT17B
MKV GTI Wiki - Various
List of similarities and differences between the S3 and 200HP engines. - D.Passat00
Forge DV installed - includes my impressions as well as pics and vag-com boost logs - D.Passat00
Why is there a milky substance on my oil cap? - Spax MC
Don't run 100 octane or higher in cold climates. - Kid Hobo
A word on the oil debate and VW 502 certification - raceware
The VW/Audi 502 and 505 approved oil list - GT17V
Why do I have fault codes after a chip flash? - Theresias
DIY:
Chipped 2.0T preventative maintenance. - (mkV)Jetta2.0t
Common issues and remedies. - D.Passat00
How to reset "Service Now" indicator - cerny420
Plugs & Coils Replacement - oooo-a3
Forge Direct Replacement DV - oooo-a3
Dogbone Mount Insert - oooo-a3
Forge Short-Shift Kit - oooo-a3
How to remove the engine cover / stock airbox. - oooo-a3
Forge "Twincooler" FMIC revisted - D.Passat00
DIY: Vag-com Logging and Graphing. - D.Passat00
How to change the air filter on 2.0T engines. - Chuibacca
Downpipe install. - Dean F
DIY DSG Fill Tool - VAS 6262 - ZWStewart
Noise Pipe Delete. - Twelvizm
How to change your cam follower. - jc@douglas
Intake cover retention. - 0000-A3
PCV installation and Eurojet PCV valve installation. - 0000-A3
Hot to check which revision cam you have. - NoRegrets78
How to properly find a boost leak. - syntrix
Modified by iThread at 9:13 AM 5-9-2008
FAQ:
DIY:
