The baby 2.0T FAQ/DIY. Contributions welcome!
182K views 33 replies 28 participants last post by  oldroller
This is going to be a long work in progress but, it's about time it happened. PM me with topics you think should be added.
FAQ:
Chip FAQ - D.Passat00
Some stock MAF readings. - GT17B
MKV GTI Wiki - Various
List of similarities and differences between the S3 and 200HP engines. - D.Passat00
Forge DV installed - includes my impressions as well as pics and vag-com boost logs - D.Passat00
Why is there a milky substance on my oil cap? - Spax MC
Don't run 100 octane or higher in cold climates. - Kid Hobo
A word on the oil debate and VW 502 certification - raceware
The VW/Audi 502 and 505 approved oil list - GT17V
Why do I have fault codes after a chip flash? - Theresias
DIY:
Chipped 2.0T preventative maintenance. - (mkV)Jetta2.0t
Common issues and remedies. - D.Passat00
How to reset "Service Now" indicator - cerny420
Plugs & Coils Replacement - oooo-a3
Forge Direct Replacement DV - oooo-a3
Dogbone Mount Insert - oooo-a3
Forge Short-Shift Kit - oooo-a3
How to remove the engine cover / stock airbox. - oooo-a3
Forge "Twincooler" FMIC revisted - D.Passat00
DIY: Vag-com Logging and Graphing. - D.Passat00
How to change the air filter on 2.0T engines. - Chuibacca
Downpipe install. - Dean F
DIY DSG Fill Tool - VAS 6262 - ZWStewart
Noise Pipe Delete. - Twelvizm
How to change your cam follower. - jc@douglas
Intake cover retention. - 0000-A3
PCV installation and Eurojet PCV valve installation. - 0000-A3
Hot to check which revision cam you have. - NoRegrets78
How to properly find a boost leak. - syntrix
Modified by iThread at 9:13 AM 5-9-2008
#2 ·
Re: The baby 2.0T FAQ/DIY. (iThread)
Ok folks, here's how I'd like to handle submissions.
Reply to this topic with links you feel should be included in the FAQ/DIY. I'll review the links and then add them or reject them and let you know why.
After I make a decision I'll delete your post so I know I reviewed it.
#4 ·
Re: The baby 2.0T FAQ/DIY. (iluvtomesswithu)
ditto on that. would be very helpful to begginers or for some that end up doing this
trying to firgure it out lol
#5 ·
I have a picture tutorial, with captions, of how to inspect/install a cam follower on a Longitudinal Audi A4 2.0T. It includes a lot of extra pictures of the process and the tools needed for the job.
http://forums.vwvortex.com/zerothread?id=3940922
Might be redundant since you have one for the GTI/GLI/A3, but thought I would offer anyway. http://****************.com/smile/emthup.gif
#17 ·
Here is a DIY for replacing the engine cooling fan I first put in the MkV forums but is now also in the 2.0T FSI forums.
DIY: Cooling Fan Replacement
#19 ·
engine/bottom end removal
I am thinking of swapping out my 2.0T (bottom end is no good).
1) Is a full swap the easiest route to take considering that this is my daily driver and I need the motor running on this car stat?
2) Or would it be just as easy to swap the bottom end and keep the costs down?
3) Is there a DIY instruction for the engine/bottom end removal?
#22 ·
DIY: 2.0t Timingbelt (w / Non-divided cover) and Thermostat
DIY: 2.0t Timingbelt / Waterpump (w/ Non-divided cover) and Thermostat
The timing belt part of the DIY is finished. There is enough info for you to replace your thermostat, just not a step by step posted yet. I will be posting that later on this week! Good luck to anyone that is going to perform this procedure on their own! Anyone can PM me with questions any time!
cvincent78
:thumbup:
#23 ·
#25 ·
Hey guys good info on here but there are some dead links! I'm interested in the cam follower DIY but the link is dead. Can anyone send me some info or an updated link. Thanks
