Fourtitude.com - VW Alternator Wiring - new alternator - light still on
    Results 1 to 5 of 5
    1. 08-06-2007 12:25 PM #1
      Does anyone have the proper wiring for a replacement VW alternator? I believe I have the Bosch one. I currently have 2 wires connected to it, a + that is connected directly to the battery (shouldn't this go to the starter?) as well as the light blue wire to the VR post. It is getting ground through the bracket currently - though I am not sure this is supposed to.
      The alternator IS charging the battery, and is outputting the proper voltage, but the alternator light is on while the car is running, even with the proper voltage output (revving the engine does not help).
      Bentley's is my next purchase - which is a good thing as I now have 3 of these Bunnies in my garage.
    3. Member Aurora_GL's Avatar
      Aug 10th, 2004
      BUFFALO
      3,105
      1988 VW Jetta, 99.5 Audi Avant
      08-08-2007 02:22 AM #2
      what is a VR post? blue wire is the exciter wire to let the alt charge and tell the light to go off while charging.
    4. 08-08-2007 06:31 AM #3
      Voltage regulator post. The alternator is charging properly, though the light does not go off.
    6. Senior Member The_Hamster's Avatar
      Jul 31st, 2000
      Alberta
      22,718
      Barbie Jeep Power Wheel
      08-08-2007 10:10 AM #4
      Quote, originally posted by tjtryon »
      That would be very odd. What voltage is the alternator outputting?
    7. Member Aurora_GL's Avatar
      Aug 10th, 2004
      BUFFALO
      3,105
      08-08-2007 10:39 AM #5
      yes voltage must be at least 13.8 when charging.
