Fourtitude.com - Sale: New 16V Distributors, Cams, Ignition Wires, Gasket Sets, Pistons, Rods
    Page 5 of 6 FirstFirst 123456 LastLast
    Results 101 to 125 of 136
    1. Member Teighlor O''s Avatar
      Aug 18th, 2011
      1,160
      02-07-2012 08:02 AM #101
      Hey does that distributor come with a new O ring seal, the one between the block and the distributor itself?
      "Reasonable people adapt themselves to the world. Unreasonable people attempt to adapt the world to themselves. All progress, therefore, depends on unreasonable people."
      -George Bernard Shaw
    3. Member Bazmcc's Avatar
      Jan 10th, 2005
      Northern Ireland
      6,870
      2002 Bora TDI, 1994 2.0 16v Corrado, 1991 MK2 Golf, 1983 MK1 Golf Driver, MK4 Golf, 1971 Fastback
      03-13-2012 08:30 AM #102
      Just out of interest how much is it to ship a set of 82.5mm pistons to the UK.
      These ones for the 9a:
      Wossner Forged Piston Kits $549 2.0 16V 9A 12.3:1 20MM Pin
    4. Banner Advertiser
      Jan 12th, 2005
      1,952
      92 Corrado SLC , 92 Audi S4
      04-03-2012 02:54 PM #103
    6. Member Bazmcc's Avatar
      Jan 10th, 2005
      Northern Ireland
      6,870
      04-03-2012 04:20 PM #104
      I have a couple of questions. The first I'll need a very accurate and specific answer for.
      1. I have a late 2.0L 16v 9a engine (abf head) to which I'm fitting Piper 294 duration cams with 11.3mm lift. If I order the K9031DA (82.5mm) or the K9031D050 (83mm) am I going to have any issues with clearance or is the recess in these pistons oversized to allow big cams and if needed clearance on 34mm intake valves if I decide to go oversized?
      2. How do you accept international payment?
    7. Banner Advertiser
      Jan 12th, 2005
      1,952
      04-03-2012 08:59 PM #105
      We would recommend you use modeling clay to see if you have any contact.
      We don't know what your head or block tolerances are, either may have been decked in the past.
      As for the pistons, we recommend the 83mm and have your block bored. This would allow for the proper wall clearance for expansion and also proper oil control.
      The UK is covered by Paypal sellers protection, so we can accept any major credit card via Paypal.
      Before you purchase please ask for a freight quote.
      Due to a recent change with Royal Mail and the USPS, all international orders over $100 will be shipped Express Mail. This is done because they allow for higher insurance rates to cover loss.
      www.fourseasontuning.com
    8. Member Bazmcc's Avatar
      Jan 10th, 2005
      Northern Ireland
      6,870
      04-04-2012 06:50 AM #106
      Quote Originally Posted by FourSeasonTuning.com View Post
      I understand but ideally that test would be done with the new pistons. The head is untouched as far as I can see. See below for block tolerances without head gasket.
    9. Banner Advertiser
      Jan 12th, 2005
      1,952
      04-04-2012 04:59 PM #107
    10. Member Bazmcc's Avatar
      Jan 10th, 2005
      Northern Ireland
      6,870
      04-11-2012 11:51 AM #108
      OK I'm going to go for a set of the K9031D050 83mm Wossner pistons. The high compression ones. You can let me know if these are definitely correct. The parts numbers are easily mixed up. Can you confirm that these include rings, pins, and clips?
      Let me know about shipment for these (I think $75 was mentioned) and the total and how the paypal payment can be done and I can sort that out.
      My friend is going to have a look at your site and let me know if he needs anything for his VR6 as well. If not, it'll just be the pistons.
    11. Member 2008cc's Avatar
      Apr 16th, 2001
      Charlotte, NC
      2,928
      82 VW Caddy, 01 Audi Avant, 14 VW Passat, 75 Dodge Dart "Hang Ten"
      04-16-2012 09:26 AM #109
      need a price on autotech cams, valve springs and lifters.
      Chapter 11 Dubs - 054
    12. Banner Advertiser
      Jan 12th, 2005
      1,952
      04-17-2012 03:43 PM #110
      IM replied, ordered shipped.
    13. Member 2008cc's Avatar
      Apr 16th, 2001
      Charlotte, NC
      2,928
      04-17-2012 04:48 PM #111
      Easy transaction.
    14. Member Bazmcc's Avatar
      Jan 10th, 2005
      Northern Ireland
      6,870
      05-04-2012 03:16 PM #112
      Top quality products, service and prices.
    15. Member
      Aug 27th, 2008
      Winnipeg, Canada
      117
      1987 Scirocco 16V
      06-25-2012 08:51 PM #113
      I have a 87 Scirocco 1.8 16v with digi1 fuel set up, will this wideband work with digi1 and how does it work when i already have a O2 sensor.
      Innovate Motorsports Wideband Blue Gauge Part Number: 3795
    16. Banner Advertiser
      Jan 12th, 2005
      1,952
      06-25-2012 10:08 PM #114
      The 02 sensor in the innovate kit would not replace your current narrow band 02. It comes with a bung that should be welded in pre-cat. This will only give you a readout, it will not adjust your current setup at all.
      These are more commonly used in boosted cars to keep an eye on the AFR.
    17. Member Roger@Silvern16vT's Avatar
      Jun 9th, 2012
      Norway
      102
      1986 Vw Golf GTI 16vT
      07-12-2012 03:30 PM #115
      Do you send to Norway ?
      I'm interested in:
      -16V Distributor for my 1,8 16V KR engine- with cap and rotor
      And maybe if you can give me good price on this things:
      -8MM Ignition Wire Set RED Fits 1.8 16V
      -1.8- 2.0 Lightweight lifter set
    18. Banner Advertiser
      Jan 12th, 2005
      1,952
      07-12-2012 04:58 PM #116
      IM sent with information.
    19. Member
      Apr 6th, 2008
      2,368
      1981 Jetta 16v, 1977 Scirocco
      07-23-2012 04:19 PM #117
      I finally went out to my US mailbox to pick up my light weight lifters
      the shipping itself was very fast, I just had to wait a while to pick them up
      great product, well packaged, fast, great stuff guys
      although the packing grease from the lifters had leaked out and caused the paper in the box to become see through, hahaha
    20. n00b
      Apr 8th, 2012
      xalapa,ver
      2
      90 mk2 GTI
      07-28-2012 09:33 AM #118
      hello do you sell intake valves for a 1.8 16v engine i would need 8 of them thanks
    21. Banner Advertiser
      Jan 12th, 2005
      1,952
      07-29-2012 12:49 PM #119
      $18 each made in Italy.
    22. 11-12-2012 07:58 PM #120
      How much for cast 83 or 83.5mm pistons/rings?
    23. Banner Advertiser
      Jan 12th, 2005
      1,952
      11-13-2012 03:49 PM #121
      Contact us at the shop to discuss your needs.
      Our number is in the sig below.
    24. Junior Member
      Dec 10th, 2011
      europe, north of the articcircle
      24
      93 Golf gti 16vT, 04 TDI pd150 4motion
      12-08-2012 09:26 AM #122
      Hey.. my order arrived today.. Thanks!
      you will hear form me again.
    25. Member baggedgti's Avatar
      Jul 6th, 2011
      denver
      261
      98 vw gti, 1984 16v rabbit
      03-26-2013 08:06 PM #123
      I need a complete engine gasket set for a 9a 2.0 16v pm me please
      Sent from my DROID RAZR using Tapatalk 2
    26. Member shysty's Avatar
      Oct 19th, 2010
      Ontario, California
      1,080
      05-21-2013 08:09 PM #124
      up
    27. Member DocWalt's Avatar
      Sep 6th, 2012
      Royersford, PA
      1,827
      '92 GTI, '17 GT350
      04-24-2014 03:36 PM #125
      I picked up a spare distributor from you a while back. Haven't needed to use it yet thankfully, but it looks good
      R135
      - 24
