Fourtitude.com - USRT Group Buy: Snow Performance water/alky injection
    Page 5 of 12 FirstFirst 123456789 ... LastLast
    Results 101 to 125 of 293
    1. Member Alaska's Avatar
      Oct 30th, 2005
      1,343
      '01 GTI APR3 and some...
      06-05-2006 02:58 PM #101
      bump for interest and dammit cuz I only get 90octane in Alaska
      so my performance gains would be less then that-
      Then again my ECU is only programed for 93
      *currently I run torrco fuel additive to boost my octane-
      Modified by Alaska at 12:01 PM 6-5-2006
    3. 06-06-2006 01:53 PM #102
      Would this kit be logical for someone with say...APR 93, DV, Exhaust, downpipe, and other small stuff like that?
    4. 06-06-2006 05:05 PM #103
      of course!
    6. Member VWturbo2Ltr's Avatar
      Aug 4th, 2001
      Cockeysville MD
      936
      92 Corrado VR6 (current project)
      06-06-2006 09:01 PM #104
      water injection does not care what your current setup is.......... from stock to the craziest of setups you WILL make power........ period.
      in my opinion you get even more bang for you buck with water injection vs your standard chip program
    7. 06-13-2006 10:09 AM #105
      I beileve there are a few guys running the APR 100 program with pump gas and WAI without issues. Can't wait to get my WAI setup.
    8. 06-13-2006 01:11 PM #106
      I would love to get my hands on giac race gas file... Right now... I'm simply doing the timing advance on my own...
    9. Member Space9888's Avatar
      Mar 18th, 2002
      Connecticut
      1,967
      81 Rabbit Convertible 1.8t project
      06-16-2006 01:11 AM #107
      sounds worth it on my 1.8t K04erd, too bad i should do the fuel pump and injectors first
    10. 06-19-2006 08:01 PM #108
      Scott,
      Could i run this WAI on my distributer VR6 S/c with 8 psi and be safe using stock fuel and stock software?
    11. Member WMTJ's Avatar
      Jan 26th, 2001
      Florida
      913
      95' GLX
      06-20-2006 07:00 AM #109
      Anyone here running this system with SEM? I'm wondering how aggressive people have pushed the timing envelope. If you're turbocharged, are you using it pre-boost to help spool the turbo better with aggressive timing and the additional fuel nessesary? Can this system even be used this way?
    12. Forum Sponsor
      Jan 13th, 2005
      Haddon Heights, NJ
      3,929
      MK4 Jetta 2.0T, Mk1 Scirocco 16v, 323 GTX
      06-21-2006 09:05 AM #110
      Quote, originally posted by THEERY2.1 »
      Scott,
      You might be able to get away with this. A 75% proportion of methanol could be used for auxiliary fueling just like a second bank of injectors. The 25% of distilled water would make the stock ignition curve more workable. I'd add the Safe Injection failsafe box and a solenoid to purge boost in case of trouble.
    13. Forum Sponsor
      Jan 13th, 2005
      Haddon Heights, NJ
      3,929
      06-21-2006 09:40 AM #111
      Quote, originally posted by WMTJ »
      Folks with factory ECUs see their timing retard go to zero. With SEM you could go beyond that. How far you can go would depend on many variables like engine design/spec, boost level, water/alcohol proportions, type of ignition system, etc. There's no one answer to this good question.
      Quote »
      This is a means of enhancing the octane rating of the intake air/fuel charge. The spray is delivered when combustion begins to become uncontrolled. So, just as with race fuel, it's effects are only realized when the engine needs help controlling detonation. A forced induction engine that detonates before boost has serious tuning or mechanical problems. So, this wouldn't be the cure.
      With that said, there is a way to actually *add* energy rather than just maximize safe release of existing energy. That is to mix a small amount of nitromethane into the spray solution. Does that sound crazy? I don't expect every dubber to run in that direction immediately, but it does work extremely well and folks will wise up in time.
      Fwiw, up until this season most folks were saying that WAI was ridiculous, couldn't work or was unecessary in a superior VW/Audi engine, would cause instant hydrolocking, or was only suitable for Japanese cars. IGNORANCE! Our scene is finally waking up. There's power to unleash and safety to be had!
    14. Member MKII16v's Avatar
      Oct 23rd, 1999
      Maple Valley, WA
      5,456
      2015 Golf Sportwagen TSI M/T 2012 VW Gti 2 dr Autobahn M/T
      07-12-2006 11:53 AM #112
      I installed a WI system on an SRT4 last night. Used a 5gph nozzle a little before the throttle body. This car previously made 402 whp on pump gas running 25 psi from a GT3076R with the ecu pulling 10 degrees of timing. After the install and running 21 psi, the ecu was allowing 29-30 degrees of advance! The car feels much faster with the WI at 21 psi than without at 25. A/f was 11.5:1. This system is just a static system with no flow control. We are going to add a controller and hit the dyno and bring the boost back up to 25 psi. Anyone not running WI is really missing out. I would never build a boosted car without it.
    15. Awaiting Email Confirmation scott66's Avatar
      Jul 5th, 2003
      Charlottesville, VA.
      856
      Original Golf; 1990 E30
      09-05-2006 11:24 AM #113
      DARN IT, Scott......i was on vacation and didnt see this. is it over? i read on your first post that is said 100% complete, sure hope that isnt true, let me know.
    16. Member CA Solt's Avatar
      Feb 22nd, 2003
      Freekland, PA 18224
      208
      1997 Jetta GT, 2.0; 2002 T4 EuroVan GL 2.8 24v; 2004 New Beetle GL, 1.8T; 1995 Cabrio (Canada) 2.0
      09-07-2006 02:17 AM #114
      Yes, I'll be willing to add my name to this GB; or maybe start another round.
    17. 11-29-2006 06:55 PM #115
      is this group buy still alive?
    18. Forum Sponsor
      Jan 13th, 2005
      Haddon Heights, NJ
      3,929
      11-29-2006 07:11 PM #116
      It isn't, but... keep your eyes open for another. Soonish like.
    19. Member jmaddocks's Avatar
      Jan 31st, 2004
      Greater Denver area
      1,886
      Corrado 16vt, 14 LR4, LX450, 08 GTI, 11 Subaru LGT, 89 Jetta 1.6d HE200, 79 Rabbit, Bigfoot 24SL 4x4
      11-30-2006 10:49 PM #117
      Let us know soon, so I can return my kids' Christmas presents...
    20. Member
      Sep 6th, 2001
      Baltimore, md
      4,875
      87 vw golf gti 16v
      12-03-2006 11:35 AM #118
      question can I put washer fluid in the bootle?
    21. Member spooln6's Avatar
      May 27th, 2005
      Manheim
      870
      95 sc vr cabby 08 evo 10
      12-03-2006 07:30 PM #119
      I am interested
    22. Member Golf_kris's Avatar
      Dec 1st, 2001
      Norfolk, VA
      725
      2001 Golf 1.8T, 2008 DBP .:R32, 2010 CW GTI
      12-04-2006 12:38 AM #120
      I'm also interested [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    23. Forum Sponsor
      Jan 13th, 2005
      Haddon Heights, NJ
      3,929
      12-04-2006 03:34 PM #121
      Yes, you can use washer fluid. However, I don't recommend it because the dye can clog the holes in the nozzles over time. Also, washer fluid generally contains only about 20% methanol. You'll want closer to 50% for best cooling, octane improvement, and easier tuning. The better bet is to mix your own or buy the "Boost Juice".
    24. 12-04-2006 04:20 PM #122
      Quote, originally posted by [email protected] »
      2 weeks?
      but in all seriousness, 2 weeks would be perfect
    25. Senior Member TBT-Syncro's Avatar
      Apr 28th, 2001
      Vancouver
      20,415
      92 VR-T syncro GTI, 2011 husaberg FS570, 2014 Aprilia Tuono V4 APRC
      12-11-2006 06:28 PM #123
      make sure that if you are using washer fluid, it doesnt contain any glycol.
    26. Member cvisinho's Avatar
      Apr 1st, 2003
      Rhode Island
      2,879
      15' Autobahn GTI, 02' bt 337, 99 4dr wolfy golf, 88 jetta carat
      12-22-2006 07:50 PM #124
      I have a question...
      I have been researching kits and want to buy one but i have a slight proplem possibly. I want to get a kit and use a MAP controller but do i need a controller with certain voltage capabilities?
      I have a 337 with stage 3+ APR if that makes a difference.
      Another company has 2 controllers for MAP, a 2 bar and a 3 bar and apparently neither is compatible with my MAP as far as they know.
      This poses a problem if i order any kit i am assuming because the controller wont work, correct?
      What are my options? i really dont want to run a MAF controller unless its a last resort just incase the MAF craps out.
      Thanks
    27. 12-25-2006 09:35 PM #125
      just installed...................
