The Autocross Information Thread
108K views 83 replies 57 participants last post by  4ceFed4
It's about time this forum had a thread for common questions and answers. Feel free to add specific information or links on autocross or autocrossing VWs..
What is autocross?
Autocross, at its essence, is very simple. It's motorsports for the masses. Anyone can come out, with virtually any car, and test their driving skills in a safe, controlled manner. My favorite description of what exactly it is comes from Dennis Grant, one of the founders of the Street Modified class: "The basic concept is simple: take a large paved area. Describe, on it's surface, a race course, marked off with traffic cones and flour lines. Place a timer at the start and finish, and one car at a time, drive through as fast as you possibly can. Hit a cone, and get two seconds added to your time. The track is never the same twice from event to event. There are no practice runs. We run rain or shine. In Formula One terms, an autocross is like bringing your team to a track (which was completely torn down and rebuilt from the last time you were here); you get three qualifying laps, from standing starts (each one!) and on cold tires (no tire warmers allowed). The next day, you do the same thing, but in the opposite direction, and then the track owner rips up the track and starts building a new one. 6 runs total [generally 3 runs for one day events], best one each day counts. This all makes for a sport that is very different from any other style of motorsport. On the whole, it is less expensive and less dangerous than other forms, as there is very little chance of crashing into something hard, and speeds tend to be slower. On the other hand, it demands a very high level of aggressiveness and driver precision - you have to be instantly fast, and everything must go right right away. There is just no margin for error.
Races are won and lost by thousandths of a second, and the mental pressure can be enormous."
Is it dangerous?
Just like any other form of motorsports, Solo2 has some element of risk. However, the SCCA has specific rules defined to make an event as safe as possible and, in general, Solo2 is at least as safe as driving on the street. Usually, there are no more than 3 cars on a course at a given time, and that's only when the course allows sufficient separation. Workers are positioned around the course with fire extinguishers and red flags to inform cars when there's a problem. Courses are designed so that if a car does lose control, or spin, there's nothing even close to it that could be hit. Spectators are only allowed in certain areas around a course. Kids under 12 are not allowed in hot areas, which include grid, prestart, course and impound. Be aware that other organizations have differing rules, and many are not as safe as an SCCA event.
What is ProSolo?
ProSolo is a national series run by the SCCA. Where most Solo2 events run one car at a time, a ProSolo runs two cars head-to-head on mirror image courses with a drag strip start and a Christmas tree. Reaction times are part of the times. Each car gets 4 runs on each side and the best run on each side is totaled for their time. ProSolo also has a Super Challenge at the end of each event. Each car in the Challenge has a dial-in similar to bracket drag racing. In a given round, the two cars get a run on each side, whoever wins advances.
Example map: http://www.wincom.net/trog/new...e.JPG
Don't expect much in the beginning..
Out on the street, we all think we're the best drivers. And who wouldn't? There's no evidence to the contrary, so we get to think whatever we want. Often someone new checks out an autocross and just thinks it doesn't look like that big of a deal. Driving is a lot different than watching. Once you get to the start line, and there's a big sea of cones in front of you, things change. For those of you who may be nervous or a bit intimidated already (hopefully you're not!) the next couple sentences are not for you. For the street racer or canyon cruiser or spirited street driver, read on. Here's the first step. Check your ego in at the gate. Assume you can't drive, because chances are, compared to a seasoned autocrosser, you can't. This isn't a hit or a knock on your driving skills, because we all start out at this point. We all think we're the greatest, and then we get out there on course, see our times, and realize we're not. The best things you can do is listen to the experienced people around you, pay attention during the course walk, and take advice. Your goals for a first autocross should be to stay on course and, if you can do that, improve your time by the end of the day. At this point, the car you drive, or what modifications it has won't really matter. In fact, having a modified car will only hurt as it may mask things you may be doing slowly. The primary limiting factor will be the driver. As you get better, you will be able to truly take advantage of making the car better. A couple of mantras you will probably hear repeated in one form or another, but won't really "get" for awhile. "Slow down to go faster." The beginner usually tries to be too fast in the slow parts of a course, and too slow in the fast stuff. "In like a lamb, out like a lion." Generally, late apexing is the only answer.
Walking the course
Your goal when walking the course is twofold. To commit the entire course to memory so you can go through it in your head at "full speed", and to choose the line through the course that you think will be the fastest and be able to do it without thinking. So walk the course twice. Generally try to focus on what you're doing and have enough clear area ahead of you so that you can see what the course will look like when you drive it. Break the course up into sections and try to analyze the entire section as a whole to determine where you want the car to be at each turn. Memorize it, play it back through your head, and go!
SCCA Solo2 Classing Structure
Cars are classed in the SCCA first by modifications and second by the cars' set of traits and capabilities. Each ruleset is strict; in other words, if it doesn't say that you CAN do it, than you CAN NOT do it and remain legal for the class. The general progression of levels of modifications is as follows: Stock, Street Touring, Street Prepared, Street Modified, Prepared, Modified. Note that this is not a linear progression. Everything, for instance, that is legal for Street Prepared is not necessarily legal for Prepared. Once a car is placed in one of these categories, its placed in a specific class along with other cars that perform similarly. Example cars for each class are below.
Why the rules are the way they are; or why even adding 1psi of boost must be considered the same as adding 20 psi.
The ruleset is very stringent. To people new to autocross or motorsports in general this may seem antithetical. "Why does having a chip place me in Street Modified, its only a software map and I'm still underpowered!" or "I have a different transmission in my car, but it doesn't really help that much, so why am I placed in such a hard class?" are common questions. The ruleset for each class has to cover all cars. Further, the rules must be able to place cars properly based on the car's potential as it would be if it were modified TO THE LIMIT OF THE RULES. This is important. Changes in stock boost level, for example, are illegal in Stock, Street Touring, and Street Prepared. It would be an impossible task to set boost level maximums and actually be able to control or check levels at an event. The alternative is either allowing unlimited boost (which is what Street Modified does) or allowing no boost changes (SP and lower). Note that the below listings are not exhaustive. For complete rule details see the SCCA Rulebook. This is just a general guide.
Stock
Allowed Modifications:
Driver harness
Roll bar or roll cage (SCCA specs)
Shock absorbers with the same mounting type
Trailer hitch
Wheels with the same diameter and width as stock (i.e. a GTI 337/20th must use a 18x7.5", it cannot use a 17" from a GTI)
Front swaybar
Brake pads
Air filter (not intake)
Tires (anything D.O.T. legal including R compounds)
Cat-back exhaust
Classes and example/common cars for each class
Super Stock: Corvette Z06, Viper, 996 911, 93+ RX-7
A Stock: C4 Corvette, Mitsubishi Evolution, Subaru WRX STi, 00-04 Honda S2000, E46 BMW M3, Porsche Boxster S
B Stock: Mazda RX-8, Nissan 350Z, E36 BMW M3, MR2 Turbo, Porsche 968 M030
C Stock: Mazda Miata 1.8L, Toyota MR2 Spyder, Porsche 914
D Stock: Integra Type-R, Audi S4, VW GTI/Jetta 24v VR6, R32, Lexus IS300, BMW 325/328/330
E Stock: Toyota MR2 non-turbo, 90-97 Mazda Miata, Porsche 924
F Stock: Camaro V8, Mustang V8
G Stock: Celica GT, Mini Cooper S, VW Corrado VR6, GTI/Golf/Jetta 1.8T, 16v
H Stock: Mini Cooper, BMW 318
Street Touring
STS - four seat vehicles, maximum displacement of 3.1L NA and small displacement forced induction sedans
Shocks, springs, swaybars, strut bars/braces
Wheels up to 7.5" width
Tires up to 225 width
Street tires with at least 140 treadwear rating
Steering wheels
Short shift kits
Fully upholstered seats
Pedals
Body kits, spoilers, wings, removal of factory trim
Brake pads, rotors, lines
Intake, cat back exhaust, header
Emissions legal engine management
Underdrive pulleys
Relocation of battery
STX - 2WD vehicles may use any LSD, engines up to 5.1L NA, 2.0L forced induction.
STS modifications carry over
Any LSD for 2WD vehicles
Wheels up to 8" width
Tires up to 245 width
Example cars:
STS: Honda Civic, Dodge Neon, Toyota Celica, Mini Cooper, VW GTI/Golf/Jetta 1.8T, Jetta/GTI 16v, Corrado VR6, Audi A4 non-Quattro
STX: Honda Civic, Mini Cooper S, Subaru WRX, Integra Type R, E30 BMW M3
Street Prepared
The allowed modifications in SP are extensive, the following is a general summary.
Anything allowed in Stock
Update/Backdate rules for any cars on the same line in the rulebook
Any wheel and tire width
Camber plates
Any fully padded seats, steering wheels, pedals, roll cages up to 8 points of attachment
Fuel cells allowed with certain qualifications
Suspension bushings
Limited Slip Differentials
Carburetion, fuel injection, intake manifolds, intake, exhaust manifolds, exhaust
Motor mounts
Clutch/flywheel
Overbore to .0472" with oversize pistons
Balancing
Port matching, milling
Pulleys
Ignition system
Classes and example/popular cars for each class:
ASP: C5 Corvette, Lotus Elan, 996 911, 93+ RX-7
BSP: C4 Corvette, E36 BMW M3
CSP: Honda CRX, Toyota MR2 Spyder, Mazda Miata, Mazda RX-3
DSP: E36 BMW 325/323/328, Lexus IS300, E46 BMW 330, Fiat X1/9, Acura Integra GS-R, Mini Cooper S
ESP: Camaro V8, Mustang V8, WRX, WRX STi, Mitsubishi Evo
FSP: Honda Civic 92+, VW Scirocco 8v, VW Rabbit/Jetta 75-84
Street Modified/2
Allowable Modifications:
Anything in Stock, Street Touring, or Street Prepared
Drivetrain is unlimited except: engine from same company as manufacturer (Honda/Acura, VW/Audi swaps are OK)
Max displacements:
FI: 3L OHC, 4L pushrod
NA: 6L
Rotary: 1.5L
Suspension is unlimited except: Must use original suspension attachment points
Brakes unlimited
Rear passenger seat can be removed
Hood/front fenders can be changed
Firewall, roof, doors, rear quarter panels, floor pans, trunk lid must be stock
Minimum weights:
SM:
FWD: 1800 lbs NA, 1900 lbs FI
RWD: 2200 lbs NA, 2400 lbs FI
AWD: 2400 lbs NA, 2600 lbs FI
SM2:
FWD: 1500 lbs NA, 1600 lbs FI
RWD: 1900 lbs NA, 2100 lbs FI
AWD: 2100 lbs NA, 2300 lbs FI
Common cars:
SM: Any sedan/coupe with four seats (not sports-car based) such as VW Scirocco, Golf, Jetta, Passat, Dodge Neon, Honda Civic, BMW 3 series (including M3), Supra, WRX, Mitsubishi Evo, Talon/Eclipse, etc, etc
SM2: All two seaters/sports cars such as Corvettes, MR2, 911, Z cars, Honda CRX, Miata, or an underweight or over displacement SM car. All Lotus are excluded.
Autocross specific wheel philosophy
The general, most common rule of thumb in autocross is get the most rubber possible down at all 4 corners. While there are some minor exceptions to this rule, it almost always holds true. Wheel size will help you do this. Lets start with diameter. On the street, we all run big wheels because it looks cool. Drag racers tends to run small, wide wheels and tires with lots of sidewall. Several factors play into choosing a wheel diameter: weight, gearing, and fitment. The smaller the wheel, obviously, the lighter it is. The less unsprung mass, the better, so this is a good thing, and favors a smaller diameter. The shorter the wheel/tire combo, the shorter your gearing will be as well. So if you have a low-powered car, or your gearing is already very tall, a smaller diameter wheel will help you get a better gear ratio. Suddenly, you might not have to be shifting to third in a short straight. On the flipside, if you have a car with very short gearing (the STi comes to mind), a taller wheel/tire combo could help you stretch that out. The last main factor is fitment and tire size. Make sure you have an appropriate tire size for that wheel, and make sure it will fit on your car, clear your brakes, and not cause any tremendous problems.
As two examples, there are the high powered ASP/BSP cars, and there are the low powered ASP/CSP/FSP cars. The Corvette's of ASP/BSP want as much rubber as possible under their high powered, relatively heavy cars. So they run 17x11s or 17x12s with 315 or 335 width tires. The ASP Corvettes may also run 18s up front, allowing even less sidewall for better turn-in. The BMW M3s of BSP and even the E36 DSP cars are moving to 18s with 285 series tires and very short sidewalls. The low-powered, smaller, more nimble cars of ASP/CSP/FSP have none of these weight or power problems. So they all run 13" wheels that give them the shortest gearing, and the least amount of weight. Chances are they couldn't heat up a 275+ width tire anyway, so the 225/235 R comounds that Hoosier and Kumho offer are just fine.
Now on to wheel width. Let's say we've decided we're going to run 13" wheels on our SP cars. We have tires available that give us an 8-9" recommended width. What do we do? Well, the common thing to do here is to move to the wider side of the spectrum. The more width the wheel has that the same tire is on, the more width of the tire will be put down, so the wider the contact patch, to a point.
Of course, in a stock class, your wheel choice is limited to what came with the car, in which case you simply go with the lightest thing you can find, and then stuff the widest tire you can on it. C Stock Miata's usually have 225s on their 5.5" wide wheels.
BFB info
http://forums.vwvortex.com/zerothread?id=1362998
Links:
http://www.scca.org
http://www.tirerack.com
http://solo.wdcr-scca.org
http://www.sfrscca.org/solo2/
http://www.autox4u.com
http://www.nedivsolo2.org
http://www.sedivsolo2.org
http://www.solo2.cendiv-scca.org/
http://www.solotime.com
http://www.solo2.com
http://www.solo2.org
http://www.soloperformance.com
http://www.sccaforums.com
http://www.autocross.com/evolution/
Add more good information!
Modified by Mhyrr at 6:30 PM 1-28-2005
1
#52 ·
Re: The Autocross Information Thread (Mhyrr)
I've got a 91 GTi with ABA swap and cam upgrade.
Am I correct that the cam change would put me into SM? I think I would get killed.
Maybe it would be better to run my 07 Passat 2.0T instead!
Any Auto X clubs in CT? I am interested in getting into this
Thanks http://****************.com/smile/emthup.gif
#55 ·
Re: (joefis23)
Quote, originally posted by joefis23 »
can i put a 16v into a '91 8v GTI and still run in FSP because of update/backdate rules? I want to try to stay out of SM for this next year
Yes, I believe you can, and it will make for quite a competitive car if setup fully and properly. The 8v cars were a little lighter than the 16v's, and with the allowed mod's you can make to the motor in SP, you can easily get 135whp or more out of it. Of course, this means a full overhaul of the engine, boring it over to the allowed max, port matching the head 1" into the ports, porting the intake manifold/possibly building a short runner, running standalone, custom built header and 2.5" exhaust, etc... It will take some money to make it completely competitive nationally, but on a local level, just drop the 16v in with a header and exhaust and have fun.
#57 ·
Re: (schmuck)
I have a MKIV R32. I go to events to watch and am looking to start participating in the near future. Below is a list of mods I have, let me know what class you think they'll put me in. I'm going to get into it mostly for fun so I'm not too worried about what cars I'll be running against.
VF Stage 2 Superchager(not installed yet)
HPA CVP Intake manifold
EVOMS VFLOW Intake
APR/B&B 2.5" cat back
034 Track density Engine and Trans mounts
Koni 1150 Coilovers
Neuspeed Rear Sway Bar 19mm
Neuspeed Adjustable Lower Rear Control Arms
Stock 18x7.5 wheels with all season tires (Looking for OZ Alleggerita's or Ultra's as summer wheel)
The Charger is in my garage so I was wondering what class I would be in with and without it.
Thanks guys,
Ryan
#58 ·
Re: (SlamdSLC)
can't go thru and look it all up right now, but the links on here should be a help for you
http://www.indyscca.org/SoloPage.html
for reference I am running a local version of SM class w/ street tires, my mods are KW v3's, camber plates, rear adjustable lca's, rear adjustable sway, unibrace, vflow, vf motor mounts, front lsd, bhpp, stock exhaust w/ flapper, no ecu flash yet, tyrolsport caliper bushings, carbotech pads, street werks clutch, and a few more things
Modified by schmuck at 10:01 PM 7-5-2009
#62 ·
I've got an 04.5 GLI thats chipped, 3" TBE with high flow cat, APR 93 tune, CAI, Forge DV but otherwise stock. One street tires what class would I run?
And If I was to put on some R compounds on another set of wheels (probably not the stock BBS's and probably 16") what would I be looking at?
#63 ·
Solo classification question
I've got a 2003 GTI 2.8L and I need to know what Street Touring classification it falls under. I'm going to build the car to the limits of the class so I would like to know the slowest class is allowed in. It has less and 3.1L NA, rims 7.5 inches wide stock and tires are only 225mm wide so I think I can get away with STS. Am I correct?
#64 ·
Re: The Autocross Information Thread (AutoXMan)
Quote, originally posted by AutoXMan »
Also:
How do I class my car? (SCCA and clubs that use SCCA rules)
For starters, take a look at a worksheet like this one:
http://www.scca-milwaukee.org/...n.pdf
This will give you a basic idea of which class you go into: Stock, Street Touring, Street Prepared, Street Modified, Prepared, or Modified. The lists above are also good, but this chart will help quite a bit.
Then read the rules pertaining to that class. You can find the online rulebook here:
http://www.scca.com/_filelibra...s.pdf
You may find that there are other items you have that are illegal for that class - or you might get some ideas on what to optimized to better yourself in a given class. For instance - you put on a rear swaybar and that's all you did. That puts you in Street Touring or Street Prepared. Well, those classes also allow camber adjusters, coilovers, etc. So you can take advantages of the rules in that class instead of trying to bump down into stock.
Lastly, refer to Appendix A of the rulebook. Find the class you are in (say, Street Prepared) and then look for your car. If you have, say - an RX8 you will find it listed under 'Class B'. So you are competing in B, Street Prepared. Or BSP for short.
Note: Stock class is NOT SLOW. It is relatively cheap, but that plus R compound tires make the class extremely competitive. I daresay that Street Touring is a generally slower class. Some regions may offer 'Street Tire' classes. These will allow you to run stock class rules with street tires (or SP, SM rules). Check with your region to find out what they do.
The link to the classification worksheet isn't working... the new address is
#68 ·
If you change from the original engine yes. Autox classes are mostly meant for stock cars that have different preparation levels. Generaly speaking, engine swaps yeild large increases in performance so they are eliminated from most classes to keep it fair.
That is not to say you cannot autox your car though, having it in a certain class will have no bearing on how fun it is to flog the crap out of your car! :laugh:
#70 ·
I currently have a 98 passat sedan. Mild turbo swap. No suspension upgrades. Would I be able to just drive up and run?
Is there any other b5 guys running autocross that could give a beginner on which upgrades to make and which not to make.
I am assuming that I'd be in the street class and not prepared.
#71 ·
If you are planning to run with a club that runs SCCA rules your turbo swap will most likely move you to SM, which is street modified. Don't get caught up in the classing, just come out and drive and have fun. I would not change anything on the car, learning how to drive around the faults of a particular car will make you a better driver. Acquire the skills > then make the mods to the car. Good Luck:thumbup:
#74 ·
Fun has become an obsession.
To enter, make sure your car mechanically is in good shape, it will have to pass a tech inspection which looks for anything obviously loose and dangerous, bad wheel bearings, loose battery, loose items in the interior, etc. Almost every club has loaner helmets, but you will want your own soon enough, make sure it is SNELL rated as either a SA or M 2010 designation, If you plan to do track days then I would focus on the SA rated helmets. Best bet, check out the website for to club that is organizing the events you plan to enter and read everything you can. Additionally there is a great website, AutoX4u.com, click the novice link on the the right hand side and start reading.
#76 ·
Now I know what autocross mean,thank you for this wonderful information,it explained there the complete information about it.On that kind of sports we all know that a very good quality of automobile is very important, as stated there.If you are planning to get this type of car With personal car loans, you can afford a new car even if you do not make as much money as a CEO.
#77 ·
Honestly I think to many people here are getting way to caught up on being "competitive" based on classing. The flaw in this thinking, especially of the start (which if your worried about classing your obviously new anyways) is that in your given area, you might not even have another car in the class your worried about being competitive in. The only time its truely going to make a difference is for national or regional events, if your trying to win a title. Locally we have 40-50 cars that will show up, usually about 25-30 per event. I have had 1 other car ever show up and run in my class, 1 car in over 50 events over the last few years. At the end of the day having HS, or STX, or SM on the classing doesn't make a difference if your the only one in the class.
Another interesting note around here is basically we have a few guys that are always close for ftd, the classing and range of cars is crazy. We have a stock S2000 (GS or whatever class, on Hoosiers) but amazing driver, we have an STI in STU, a 73 toyota celica in SM, and a mk3 Jetta is FSP. The 4 drivers are always battling for FTD. If that doesn't show the range of driver, I don't know what else will. None of the cars are making the difference since the class should have the fsp car way faster then the GS and stu cars, but this isnt the case.
Just drive and have fun.
#78 ·
Honestly I think to many people here are getting way to caught up on being "competitive" based on classing....Just drive and have fun.
Okay, but I've won a couple times in H Stock and I feel like I'm punching below my weight, so to speak. How do I find out what's the next step up, and what I'm permitted to do? It used to be DSP, but with the new touring classes I'm all confused. Is there a checklist out there for the new rules?
#81 ·
Hey guys i have a few questions. Im building a MKII golf for autocross, trackdays, and possibly time attack. Im not concerned with being competitive, but I do want competition to run against.
If my car is even legal to run, Im sure it will be in the most extreme class.
Here are a few specs that will dictate class
Mildly worked over 1.8t
15x10 wheels
widened track
tubular subframe and control arms with radically moved pickup points
tubular front frame structure, highly modified front strut towers
The strut tower modification is what worries me most. There will be maybe 25% of the original steel left and thats it. I know lots of racing classes allow no chassis modifications between the strut towers except for safety devices such as a cage. Will cutting out the front strut towers and re working them make my car invalid to run in scca autocross?
