Fourtitude.com - Dimentions needed!!!! vw motorsport shifter.
    Page 1 of 20 1234511 ... LastLast
    Results 1 to 25 of 483
    1. Banned jetta88a2's Avatar
      Jul 26th, 2001
      2,167
      01-27-2005 12:12 PM #1
      If anyone has a vwms shifter and would be willing to take some measurements for me I'd like to build one in my machining class. The only really critical dimentions would be from the centerline of the pivot points to the mounting surface or hole location for the ball studs. I might even be able to document the build up with all the various setups if anybody's interested.
      Pic for views thanks!
      Modified by jetta88a2 at 3:44 PM 1-27-2005
      Oct 2nd, 2001
      Vancouver, B.C. Canada
      5,153
      1993 Eurovan Westy TDI, 1996 Golf TDI, 1997 Golf Variant Syncro TDI, 2011 Golf TDI, 2014 GSW TDI
      01-27-2005 06:18 PM #2
      I'm interested as well. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    4. Member bahnblitz's Avatar
      Jan 18th, 2002
      LI, NY
      14,826
      Audi Allroad, scirocco 16v, jetta coupe 16v, ecodiesel jetta
      01-27-2005 07:45 PM #3
      There is a picture right there. Thats where I got my dimensions!! My shifter came out fine
      e2 Motorsport / 174 N. Main St. / Freeport, NY
      516.208.7773
      VW/Audi specialists, VAG-COM certified! PVW featured! I-Car Platinum certified!
    6. Banned jetta88a2's Avatar
      Jul 26th, 2001
      2,167
      01-27-2005 08:21 PM #4
      What cables are you using? I just dont want to build it and find out it wont work because the arms arent long enough or something like that. I have to make a blue print before my teacher will approve it anyway so I figured I'd try to find the right dimentions
      Modified by jetta88a2 at 5:23 PM 1-27-2005
    7. Member bahnblitz's Avatar
      Jan 18th, 2002
      LI, NY
      14,826
      01-27-2005 08:58 PM #5
      mine is rod change mk1 style no cables this one uses vwms cables
      516.208.7773
    8. Member bahnblitz's Avatar
      Jan 18th, 2002
      LI, NY
      14,826
      01-27-2005 08:59 PM #6
      dimensions can be taken from stock shifter
      516.208.7773
    9. Banned jetta88a2's Avatar
      Jul 26th, 2001
      2,167
      01-28-2005 01:29 AM #7
      I was under the impression that the distance from the pivot points to where the cables attach would be longer on the the vwms shifter to reduce shift throw. Hmmm, I'll just make it adjustable. I'll post pics up as I go.
    10. 02-06-2005 12:06 PM #8
      I'm picking up a VWMS shifter in a few weeks, and then a friend of mine with a cnc machine is going to make a few copies. I'll supply all the dimensions for you if you'd like, and will also offer a copy of the unit for a price. I'm shooting for half the price of the real thing. we'll see what happens. I'll make a feeler post after the first shifter is made.
    11. Banned jetta88a2's Avatar
      Jul 26th, 2001
      2,167
      02-06-2005 01:57 PM #9
      Sounds good man. [IMG]http://*****************.com/smile/emthup.gif[/IMG] Do you plan to use the vwms cables? I ordered a set from bildon but here is a copy of the email I recieved from them.
      VWR has gone through a major restructuring and now parts are getting hard to get.
      I've already had an inquiry in about these parts.* I should know tomorrow about availability.
      Regards,
      Bill Sulouff - Bildon Motorsport
      Volkswagen Racing Equipment
      http://www.Bildon.com
      That was on jan 27th... I still havent heard back.
    12. 02-06-2005 02:21 PM #10
      Quote, originally posted by jetta88a2 »
      Regards,
      I was planning on using vwms cables, but if they're no longer avaliable, i will have some custom made for our application.Hopefully i don't have to make customs cables
    13. 02-08-2005 01:14 PM #11
      here's a couple pics i took a few years ago .. should have measured it when i had the chance
      post specs up here if you get it to work, i'd like to build one too
    14. Member
      Aug 2nd, 2000
      4,763
      02-08-2005 05:02 PM #12
      Have any of you guys bolted the shifter in yet?
      Lots of work, no doubt about it.
      Also, I ended up making a custom tower for the shifter to bolt to, as the one it comes with is too low... the main cable won't clear the center tunnel.
      Anyway, I'll see if I can dig up some pics.
      I was a man... I was a good man... Selling insurance...
    15. Member bahnblitz's Avatar
      Jan 18th, 2002
      LI, NY
      14,826
      02-08-2005 10:37 PM #13
      I have a fully working rod selector model for 020 gearboxes if anyone is interested in buying one!!!
      516.208.7773
    16. 02-09-2005 01:17 AM #14
      I've deicided to make a completely custom unit that will work just like the vwms shifter, but it will have the ability to be adjusted for longer or shorter throws. We're making a prototype right now. The longest throw will still be shorter then stock by about 25-30 percent.
    17. Member
      Oct 19th, 2003
      1,015
      02-10-2005 01:30 AM #15
      Which car/trans combo will your shifter work with? Can you give a very rough ball park of what you think it might cost?
    18. 02-10-2005 07:04 AM #16
      Quote, originally posted by Byron N. »
      i'm going to make it only for cable shift trannys at first, and then i'll make the 020 shifter if i can sell these. I'm shooting for around $400. After i make the prototype, i'll figure out the cost, see how much interest there is for this shifter, and them i'll make a batch of them. I may also take pre-orderes after the first one in done to help pay for the materials. Its a lot of dough to put on the line you know...Pics in 2-3 weeks of the shifter.
    19. Member
      Oct 19th, 2003
      1,015
      02-10-2005 03:37 PM #17
      I understand about costs. I was looking into going with a cable shift box in my 86 GTI, if I go this route and you are close to your estimated price I will be very tempted. Those things are so trick looking, and you can mount them at a height that you like. I didn't think one of those could even work with an 020.
    20. Member bahnblitz's Avatar
      Jan 18th, 2002
      LI, NY
      14,826
      02-10-2005 03:46 PM #18
      Quote, originally posted by bahnblitz »
      I guess you guys seemed to miss this
      516.208.7773
    21. Member speed51133!'s Avatar
      Aug 5th, 2002
      alexandria va/milwaukee wi
      7,815
      19 VW Atlas SE / 02 Audi tt 225 / mk3 Jetta / Audi 5000s turbo
      02-10-2005 03:46 PM #19
      shoot....i could make one of these things NO PROBLEM with better quality than thoes pics!
      it would not take me 400$ either to do it......
      all i would need is dimensions, or a unit to copy.
    22. Member bahnblitz's Avatar
      Jan 18th, 2002
      LI, NY
      14,826
      02-10-2005 03:51 PM #20
      I made mine no dimensions and its for 020!!! There are some bits in there which add up. The aluminum stock in nothing but thrust washers and bull**** like that get expensive.
      516.208.7773
    23. Member bahnblitz's Avatar
      Jan 18th, 2002
      LI, NY
      14,826
      02-10-2005 03:54 PM #21
      BTW the above unit is pretty clean!! It is a VWMS unit!! You might offend someone on here!! The welding could be better. Thats about it. The dimple press needed to make the base is pretty expensive!!
      516.208.7773
    24. Member
      Oct 19th, 2003
      1,015
      02-10-2005 06:09 PM #22
      Ive never seen one in person. Is the pin on the top with the spring behind it for the reverse lock out?
    25. Member speed51133!'s Avatar
      Aug 5th, 2002
      7,815
      02-10-2005 09:24 PM #23
      VWMS or MVWS who cares!
      i dont think it LOOKS anything fancy. the weldnig looks like it was done wih a vortex style mig! haha
      anyways, the dimple thats pressed in, is that dimple a functional part of it?
    26. Member bahnblitz's Avatar
      Jan 18th, 2002
      LI, NY
      14,826
      02-10-2005 09:32 PM #24
      Well, yes, for strengthening the bases. If not then its just flimsy metal. Tons of major race fabricators use them. What would you do to yours to make it fancy?????
      516.208.7773
    27. Member bahnblitz's Avatar
      Jan 18th, 2002
      LI, NY
      14,826
      02-10-2005 09:35 PM #25
      Yup, you got it!
      516.208.7773
