Fourtitude.com - 20V Hybrid - How To
    Page 5 of 74 FirstFirst 1234567891555 ... LastLast
    Results 101 to 125 of 1836
    1. Member Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      13,487
      91 Audi 80 2.0T
      12-08-2004 08:44 AM #101
      Quote, originally posted by Wizard-of-OD »
      OBDI or OBD II?
      Quote, originally posted by GTi Leo »
      lol thats it but yeah so i donno i may need to get the pistons custom but the ones on the G60 or other 2.0s don't need to be done???
      They all Need to be done except with a PG block you can use the original stock 1.8T rods and pistons.For the 2.0 Applications I recommend giving Rodney Huss (rhussjr) a Buzz as he can get JE pistons for the 20V fr around $550US in 83mm bore.You can use the AEG conrods for the time being and if in the future you feel skeptical about them,you could always have Pauter make a set to match your crank and JE pistons [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by Wizard-of-OD at 2:20 PM 10-10-2005
    3. 12-08-2004 07:09 PM #102
      what about double stanking the gaskets since i'm turboing it and will have a boost controller i can upp the boost and the compression will still be nice with added power and more valve clearance. i donno if it'll work but meh. or what about a thinker gasket
    4. Member Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      13,487
      91 Audi 80 2.0T
      12-08-2004 07:12 PM #103
      the CR is allready "low" by most standards when placing a 20V head on an 8V block.Double stacking will drop the CR down a point bringing it to about 7.5:1,Maybe lower.The stock 1.8T has a CR from 9.3:1 to 9.5:1.I didnt know thinner HG's were available...got me there.
      I would suggest the pistons dude.Honestly [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    6. 12-08-2004 07:46 PM #104
      aight thats cool but now that i looking at the ABA block with JE pistons i don't see that hes got em modified for the 5 valve i looks like its just flat up agains the top of the block.
      do you know how much the valves open anyways like i'm trying to figure this out and your suggestens seem to be the best way to do it but there could be others i'm just trying to figure it out cuz i wanan do this it'll be like a mk 2.0T this way
    7. 12-08-2004 08:31 PM #105
      lol what do you mean save it ABA is weak to and i'll have to change everything it would seem that the AEG would be stronger since its more liek the AEB
    8. Member Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      13,487
      91 Audi 80 2.0T
      12-08-2004 10:09 PM #106
      Early AEB's had an external water pump and followed the old style of VAG Blocks.
      and ABA is far from week my friend.You will have an advantage of a higher rod ratio when comparing the ABA to AWD/AEG
      ABA has a rod length of 159mm whereas the AEB has a rod length of 144mm.My advice is to at least change the pistons.You wont go wrong [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    9. 12-09-2004 12:49 AM #107
      ABA is from a mk4 isn't it or am i stupid and thinking wrong
      ugh i'll just swap a 1.8T its less hassle and cheaper and then i'll get it bored out and put 2.0 forged pistons if they will fit
      Modified by GTi Leo at 11:50 PM 12-8-2004
    10. Member Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      13,487
      91 Audi 80 2.0T
      12-09-2004 10:28 AM #108
      Good Luck,Post up your findings [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Just a bit of Longitudinal mounting Reference for you Passat 1.8T guys/Audi A4 1.8T guys in terms of engine mount brackets for the ABK/AEB or ABA/AEB set-up
    11. Banned Scirocco20v's Avatar
      Mar 24th, 2004
      2,293
      12-09-2004 06:20 PM #109
      ABA = Mk3 engine
      It wont bolt into a Mk4 chassis because it doesnt have the pass side engine mount mounting points.
      AEB will bolt into a mk3 no problem since it uses an older style block with the exception of extra oil drain holes.
    12. 12-09-2004 10:49 PM #110
      Quote, originally posted by Scirocco20v »
      ABA = Mk3 engine
      then which is the 20v head that will bolt up to a mk4 AEG is it the AWD
    13. Banned Scirocco20v's Avatar
      Mar 24th, 2004
      2,293
      12-10-2004 01:22 AM #111
      Like Ive told you before, dropping a 20v head on a mk4 2l block seems pretty simple. You really only have to swap to a custom pistons, 1.8t headgasket, 2l timing belt and engine management to run it all. All 20v heads are the same at the deck surface. AEB's have larger ports and AWW/AWP engines have variable cam timing.
      If all goes well I will be building my buddies AVH into a 20v engine and have more info on the conversion in a few months.
    14. 12-10-2004 02:26 AM #112
      hmm but which one have the 5 oil returns and which is better and is used on the 2002-2004 1.8Ts with 180 hp
    15. Member Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      13,487
      91 Audi 80 2.0T
      12-10-2004 09:10 AM #113
      AEG follows the new style of Blocks with an Internal waterpump.Only 1.8T engine to follow the old style of blocks was the AEB which was a modified old style external water pump with 5 return oil holes.
      So physically a 1.8T 20V head will bolt up to a new model 2.0 block without any modifications.Just need to work on pistons. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    16. Member vwpat's Avatar
      Oct 25th, 2000
      ATL
      6,667
      12-10-2004 10:29 AM #114
      Audi pistons can be used for N/A but will be too high for F/I so would need Wisecos, JEs, etc. http://www.porttuning.com has a selection of Wisecos and can get whatever you need.
    17. 12-10-2004 10:47 AM #115
      well the AEB is 9.5:1 compression, i'm guessing with some porting and good tuning, the g60/lysholm at lower boost you might be able to rock out 10:1 or 10.5:1 without blasting the motor apart.
      remember those guys hit 240wft/lbs at 21psi peak torque at 14.5:1 air fuel ratio, so those are some damn well designed combustion chambers to take that abuse.
      i'd probably say raise the compression if all you got is a g60 to blow it
    18. Member
      Dec 25th, 2003
      N. Phx, Az
      5,878
      91 20vG60 GTi, 91 VR6T GTi, 12 Golf R
      12-10-2004 11:03 AM #116
      Quote, originally posted by mrkrad »
      Considering Im wailin out 38 degrees advanced at 6500 on 11psi in 100 degree weather on 91 octane, Id agree [IMG]http://*****************.com/smile/emthup.gif[/IMG] Ill have some numbers here shortly. Im lookin to bump the compression to the 9.7ish range.
    19. Member vwpat's Avatar
      Oct 25th, 2000
      ATL
      6,667
      12-10-2004 11:09 AM #117
      The Audi 3.0L pistons are 11:1 IIRC but they they may be for long rods (i.e. ABA).
    20. Banned Scirocco20v's Avatar
      Mar 24th, 2004
      2,293
      12-10-2004 01:15 PM #118
      Because the motor puts out more hp stock doesnt mean its any better. They run more boost, a better flowing turbo and have variable cam timing. The AEB is actually a better engine since it comes with forged crank, rods and a big port head. Things the transverse motors wish they had.
    21. 12-10-2004 11:12 PM #119
      is the AEB german or mexican built
      i gotta stupid question but here goes would the AEB crank fit a 2.0
      Modified by GTi Leo at 10:22 PM 12-10-2004
    22. Member Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      13,487
      91 Audi 80 2.0T
      12-10-2004 11:24 PM #120
      AEB = German
      AEB Crank = 86.4mm Stroke
      AEG Crank = 92.8 mm Stroke
      the 2.0 comes from the Crank guy....
    23. 12-11-2004 02:35 AM #121
      AEB = German
      lol that means what they won't fit what if i change the rods
    24. Member Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      13,487
      91 Audi 80 2.0T
      12-11-2004 09:50 AM #122
      come on man.The AEB crank Will fit in the AEG block but why would you do that?You pretty much "destroking" the engine carrying it from a 92.8mm (AEG) stroke to a 86.4mm (AEB) stroke.
      Lemme guess,your going to use your 2.0 Block and stuff the 1.8 Crank,conrods and Pistons in there?
      If so...again good luck.Bore of the AEG block is 82.5mm and bore of the AEB Block is 81mm.If your so mind set on placing a 20V head on the AEG block just get custom pistons made for 83mm guy.Simple. [IMG]http://*****************.com/smile/emgift.gif[/IMG]
    25. 12-11-2004 02:50 PM #123
      lol not doing it just asking lol so pretty much the AEB has the same block as the 2.0. k thanks man i'll prob do the head thing and get the forged pistons to fit. you have given me lots of good advice thanks for your help
    26. Banned Scirocco20v's Avatar
      Mar 24th, 2004
      2,293
      12-11-2004 05:47 PM #124
      No the AEB block is no where close to the mk4 2l engine. The reasons have been stated before. Please read everything carefully
    27. Member Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      13,487
      91 Audi 80 2.0T
      12-11-2004 05:58 PM #125
      No....
      AEG = Complete new Cast with Internal Water Pump and different style Oil Filter Flange.
      AEB = Old Style Block with External Water Pump and Hole for a Distributor that has been modified for 5 Oil return holes.
