Fourtitude.com - 110.4hp per hole or 55.2hp per valve.
    Page 1 of 5 12345 LastLast
    Results 1 to 25 of 106
    1. 09-01-2003 10:45 PM #1
      first pull on the dyno netted 411whp with no nitrous and never running it on the dyno with the new setup best past prior to dyno was [email protected] this is all done with the factory ABA coil, factory distributor, and a set of 4 year old jacobs plug wires off a G-60 that were laying around. for those that do not know the setup 2.0ABA crossflow, built motor, autronic ecu and ignition.
      here is high boost versus low boost and nitrous.
      wish we could have dynoed highboost and nitrous but. we stripped 3rd gear out on the dyno. 3-3rd gears on the dyno for this motor. did pull it in 4th then....turbo lou style [IMG]http://*****************.com/smile/emthup.gif[/IMG] but ran into miss firing i think I found the limit of the factory ignition components. AT 441whp with a 17% drive train loss that puts it at 516hp at the crank.bhp so was hopping for possible but i think we will be going coil per plug for the next application.......i really wanted to push the factory components maybe swap out the coil....but dyno time and money i will just switch out and go back. i am happy with my progress to day.....thanks again Lugnuts.....Kevins rates are going up sooner you get your **** tuned the cheaper it will be....free plug....
      Modified by purple-pill at 10:58 PM 9-1-2003
      Modified by purple-pill at 11:00 PM 9-1-2003
      Modified by purple-pill at 9:53 PM 9-4-2003
    3. 09-01-2003 10:56 PM #2
      wow. gives me something to dream about.
      wow. huge props.
    4. Member turboit's Avatar
      Oct 4th, 2001
      Delaware
      4,230
      '07 Audi S4 Avant, '93 Corrado SLC
      09-02-2003 12:32 AM #3
      Man O Man! Those are awesome #'s!!
    6. Banned nycvr6's Avatar
      May 4th, 1999
      6,686
      09-02-2003 12:58 AM #4
      Nice #'s Joel. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    7. 09-02-2003 01:01 AM #5
      Good **** joel.. you running sunday at mir??? also... what does the rado way?
      97 GTI VR6T (Sold) - 11.50 @ 121.29 17psi - ATP Stage 2, EIP Chip/FMU
      All Motor - 3.39 R&P, DSR 256 Cams, 215/50/15 Dunlop SP5000, 2750lbs
      13.961 @ 99.55mph
    8. 09-02-2003 01:31 AM #6
      Holy crap.....
      I just love seeing ABA's that kick ass [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    9. 09-02-2003 03:07 AM #7
      Wow, that looks great. The turbo spools up and power is pretty much flat too 8500 rpms. How are you getting that to happen? What turbine trim and A/R are you running on it? Cams? You are really showing that the 8v isn't as weak of a head as everyone thinks [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Jan 9th, 2002
      Baton Rouge, LA
      10,102
      Finally VW-less
      09-02-2003 08:03 AM #8
      Very nice Joel. [IMG]http://*****************.com/smile/emthup.gif[/IMG] Wish I could have met you at Waterfest. Awsome HP line.
      Roll Tide & War Eagle but stuck in LSU Country
      UAB Blazer Basketball
      Saints - WHO DAT! ROAD WIN?!
      NOLA Pelicans
      Orioles - Thank You Showalter & all the O's!
    11. Member
      Nov 26th, 2000
      New Jersey
      10,230
      A2 GTI,B5A4,B6A4, 2.7t
      09-02-2003 09:00 AM #9
      Double D Dope bro! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    12. Awaiting Email Confirmation ALpHaMoNk_VW's Avatar
      Mar 26th, 2001
      Allentown PA, Rockland NY
      2,786
      82 Rabbit, 92 Jetta, 98 Jetta
      09-02-2003 09:39 AM #10
      very nice numbers
      what compression are you running at and how much boost?turbo specs?
    13. Member TooLFan46n2's Avatar
      Oct 18th, 1999
      Lancaster PA
      5,656
      '02 GTI 337, '02 BMW 540i, '03 BMW M3, '07 Jetta 2.5
      09-02-2003 09:54 AM #11
      Quote, originally posted by ALpHaMoNk_VW »
      very nice numbers
      What is done exactly to your "built motor"? Stock camshaft?
      Insane numbers! I'll come over and cut your grass if you take me for a ride
      GTi 337.:R
      {PPT T3/T4 50 TRIM .63 Haldex Kit - Eurodyne Maestro - 630cc Injectors - IE Rods - AEB Head w/ VVT - CAT Cam Gear - Walbro Inline - Audi S3 Gearbox - Peloquin Diff - SouthBend STGIII Clutch - .:R32 LCA's/Spindles/Rack - Ksport Coilovers - Swaybars - Porsche BBK - Eurojet FMIC - FSI Coils - 2 Stage Boostvalve - HKS SSQV }
    14. Member
      Dec 19th, 1999
      Toronto
      5,636
      1989 Fox 2dr, 1995 GTI, 2004 Jetta TDI, 2007 GTI 3dr, 2006 Audi A4 Quattro, 2012 VW GTI
      09-02-2003 10:21 AM #12
      real nice numbers for sure. What to know a little bit about the motor specs. I know your running a to4s turbo with a fairly large hot side. mmm guessing around .82 or something. Also what is done with the head?
      Current: 2015 Audi A3 Technik S-Line Glacier White, 19's. 2008 Touareg V8 Exec. Lux (Air Suspension, Nav, Trailer Hitch) 2008 Mastercraft X-Star 40th Anniversary Edition, 81 J-Craft 19' Long deck with 200 Mercury, 98 Seadoo GSX Limited
    15. 09-02-2003 10:47 AM #13
      Wow those are some sick numbers!! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    16. 09-02-2003 10:56 AM #14
      factory solid lifters,longer valves, ABA head gasket, WEB-CAM camshaft. stock bore and stroke, smaller than a .82 A/R
      do all the pics work for you guys i only get the last one they all worked lastnight oh well.
      Modified by purple-pill at 10:58 AM 9-2-2003
    17. 09-02-2003 11:43 AM #15
      What kind of boost number are you running, I have the same setup, but stock crossflow head, stock ecu with 310 chip. Pushing 20 PSi and getting 302 WHP, what do you have done to the head(machinework wise).
      Great numbers though.
    18. 09-02-2003 01:13 PM #16
      pics not working. Looks like that site doesn't let you reference pics to an outside website.
      Nice #rs, congrats.
    19. 09-02-2003 01:14 PM #17
      Nice #rs, congrats.
      It is time to show the VR6s that a 4 banger can get into the 9s too!
    20. Member
      Nov 26th, 2000
      New Jersey
      10,230
      09-02-2003 02:33 PM #18
      The trick is in the turbo and you heard the man say that it wasnt a .82 since a .82 is a T3 hotside.
      $50 bucks and i'll tell u the specs
    21. Member turboit's Avatar
      Oct 4th, 2001
      Delaware
      4,230
      09-02-2003 03:04 PM #19
      somebodies running a straight T4
    22. Member TooLFan46n2's Avatar
      Oct 18th, 1999
      Lancaster PA
      5,656
      09-02-2003 03:17 PM #20
      GTi 337.:R
    23. Member
      Nov 26th, 2000
      New Jersey
      10,230
      09-02-2003 03:23 PM #21
      Quote, originally posted by GTRTim »
      Which way?
    24. 09-02-2003 04:19 PM #22
      I'm guessing its a similar turbo to what Kevin is running... O-trim, tang divided .7 a/r ??? But its a TS04 Compressor which is a little smaller then Kevins T61..
    25. 09-02-2003 04:28 PM #23
      machine work wise?.....valve job, some porting. head was o-ringed, shaved alittle once so the head would mate to the block well.(but that is a given when making sure you want a good seal for the headgasket) other than that that is all the machine work done to the head.
    26. Member turbodub's Avatar
      Jul 6th, 2000
      garden state
      4,262
      94 golf
      09-02-2003 07:33 PM #24
      not bad
    27. Member turbodub's Avatar
      Jul 6th, 2000
      garden state
      4,262
      94 golf
      09-02-2003 07:34 PM #25
      not bad
