My N/A Build--Finally Started thread!
128K views 168 replies 46 participants last post by  fourthchirpin
#1 · (Edited)
First I would like to thank these people that helped me through it all to make it to this point.
Jerome Foster- you was there every step of the way from day one bro with advice/motivation/knowledge/manhours lol
Janhoi - another one that has been there from the start that all nighter with the welder was memorable.
Gino @ Evolution Racing Engines - machining/building/guidance/knowledge - http://www.evolutionracingengines.com/
Paul (need_a_vr6) @ KPTuned - for 24/7 tech-support and many more. http://kptuned.com/
Chris Palumbo (XXX007XXX) - for much help with the car, support!
Ed @ Force Fed Engineering - support, fabrication/welding! - http://www.fferacing.com/
Swoops - fabrication/welding
DJ - for his multiple Rx7 runs ;), suppport from day one as well.
Brian Daponte - his spare 24v for mockup of 02m mounts
Rhussjr & Issam Abed - assisting me with pistons.
Weasel410 - for designing of the pistons
Shawn Dezego - 02m Mounts
Mark @ Falcon Clutches - http://www.falconauto.com/
Here are the highlights: As the full build is on my page here where you will see the start up video at the end enjoy everyone!
--> http://seansal.info/fourthchirpin.php
6
#168 ·
Update:
After waiting since Aug 2018. I pulled the plug on the standalone. Sadly I couldn't wait any longer and the whole experience just made me have a sour taste with going further in the motor. As of now im just trying to return it back on a stock ECU and finding stock wiring to get it up and running. Hopefully to just enjoy the car soon. So as of now I going back to stock ECU and I put a twin disc in the car. Take care everyone.
#169 ·
3-15-2015 - REVOTECH ECU (no fuel pump module)
p2400-EVAP Leak Detection Pump Control Circuit/Open
p2138-Throttle/Pedal Position Sensor/Switch D/E Voltage
p0480-Fan 1 Control Circuit
p025a-Fuel Pump Module Control Circuit/Open
p2185-Engine Coolant Temperature Sensor 2 Circuit High
p2540-Low Pressure Fuel System Sensor Circuit Range/Performance
12-10-2015- UM PERFORMANCE (no fuel pump module)
p0501-Vehicle Speed Sensor Range/Performance
p0063-HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
p0042-HO2S Heater Control Circuit (Bank 1 Sensor 3)
3-18-2018- UM PERFORMANCE (no fuel pump module)
p2539-Low Pressure Fuel System Sensor Circuit
p025A-Fuel Pump Module Control Circuit/Open
Just posting this for informational purposes of the codes ive had the whole time. Still returning back to stock wiring, ecu and other wiring that I needed.
