My Profile | Active Users | Help | Search | Google Search
MDTurborocco
Member
Offline
Member Since
8-24-2003
Silver Spring MD
 How bad is it to run out of diesel? Bleed the system?« »
Im starting to drive my 97 passat more and I want to fill it all the way to the top and run it all the way till empty. Would it be as easy as filling it up with a gallon or two when empty and just turning over the engine till it starts? TIA
81 Rabbit truck diesel
04 Ducati Monster 1000
V-TEC this!!!
Member
Offline
Member Since
5-4-2003
London Ont
1990 Corrado G60,1995 Golf TD, 94 Golf TD
 Re: How bad is it to run out of diesel? Bleed the system? (MDTurborocco) »« »
Once you run the car out of diesel...you will need to bleed the system....diesel also lubricates the pump. So running the pump low on diesel can cause damage.
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, pizza in one hand, beer in the other, body thoroughly used up, totally worn out screaming "WOO HOO what a ride!"
I rather push a VW than drive a Honda!!
Ian'89Fox
Member
Offline
Member Since
3-14-2001
Lindsay ON
1993 Golf GL TD, 1994 Jetta GL TD, 1987 Yamaha XT 600
That's right, don't run a diesel engine out of fuel. I don't see why you'd want to anyway.
'93 Golf diesel rustbucket >>368,000 km
'94 Jetta TD dusty mauve >>255,500 km
chittychittybangbang
Member
Offline
Member Since
5-27-2007
shoreline ct
It's not good. You have no electric fuel pump to prime the system. When you run out of fuel, the lines will have some air in them. Plus, it's a safety hazard to drive along and then run out of fuel in the middle of an intersection, highway, etc.
Edit: Yes the injection pump is self priming but you might run down the battery or fry the starter before you get the engine to start if you're that dry. The best way to restart it is to manually use suction at the return fuel line at the injection pump (engine) to draw fuel all the way through the lines. Don't keep cranking if you have no fuel since it just sucks in more air.
If you want to see your max range, drive until almost empty. Open the top of the fuel tank. It's in the back, it looks like a little port. Remove the fuel level sender. Suck out all the fuel in there and then measure it. Use the same pump so that the calibration will be the same and you know how much fuel you are getting.
Modified by chittychittybangbang at 6:22 PM 5-27-2008
2009-2010 Jetta TDI buying FAQ - invoice, options, and more
2010 Golf TDI buying checklist
TDI FAQ index and how to
MDTurborocco
Member
Offline
Member Since
8-24-2003
Silver Spring MD
 Re: How bad is it to run out of diesel? Bleed the system? (chittychittybangbang) »« »
I was gonna do this to figure out mpg. I drove it the other day at 12 gallons and over the day drove only 40 miles and it went down to 10..... I just started driving this car, it has diesel from at least 6 months ago if that matters. Thanks for the suggestions though
Ian'89Fox
Member
Offline
Member Since
3-14-2001
Lindsay ON
Quote, originally posted by MDTurborocco »
To figure out your mpg, do the following:
-Fill tank to the very top, or first click on pump (has to be roughly the same on every fill-up)
-Reset your trip odometer
-Drive until you need to fuel up
-Fill tank to the same spot as previous
-Note miles driven and gallons of fuel added, then just do your calculations
Tim Birney
Member
Offline
Member Since
6-1-2003
Dearborn Heights MI
2005.5 Jetta TDI
 Re: How bad is it to run out of diesel? Bleed the system? (Ian'89Fox) »« »
... or just fill up, keep a receipt, make a spreadsheet of the Gallons, Miles, and MPG.
Average the entire spreadsheet from beginning to end.
If you want a 350 mile tank average, then you could get picky about HOW you fill each tank.
(I have tanks, in the MKV Jetta, of 48 MPG, and 31 MPG, and overall 36 MPG, I do a lot of City driving. If you travel 500 miles on the Highway, your spreadsheet will reflect the good MPG, if you drive consistently in the City, then you will eventually see your true City MPG.)
My B5.5, 2.0L Passat is very religious at 30MPG in the city, and 40MPG on the highway, and how I fill that beast does not play into the picture.
Just don't run it dry, take the overall average.
2005.5 NEW JETTA TDI (Rain Closing Windows, Euro Switch, goF raeR, Aspherical Mirrors, Euro LED Tails AMBER CLUB, Osram High/Low) - 2004 PASSAT TDI (Aspherical Mirrors, Stealth Rear Turn Signals) VAG-COM S.E.Michigan
No Gimmicks, just plain well built
HD-BP 102
Radeberger!
MDTurborocco
Member
Offline
Member Since
8-24-2003
Silver Spring MD
 Re: How bad is it to run out of diesel? Bleed the system? (Tim Birney) »« »
roughly 750 miles out of my first tank not bad Did I hear a quart of atf is good for the injection pump??
Fat Jon
Member
Offline
Member Since
2-26-2007
Ft Lauderdale FL
2003 Truck Youcanwalkunder
1 oz ATF (or 2 stroke motor oil) to 1 gallon of diesel is the general rule..
I love the smell of diesel in the morning
Trev0rBr
Member
Offline
Member Since
11-25-2004
York PA
81 Jetta 81 Rabbit
you don't need to bleed the system? you just add fuel and crank till it starts, it bleeds itself
Jettas thread--EMAIL ME
..........___................____
......._//_|_\__.........//|_|_\__ Never give 110%, people that use
O0o|_@_|_|@|..O0o|@_|_|@| too much effort get hemroids.
MG MOTORWERKS Its a great place to buy vw parts
Trev0rBr
Member
Offline
Member Since
11-25-2004
York PA
81 Jetta 81 Rabbit
also atf is corrosive to the ip, i wouldn't run it regularly, although i think its good to run a quart through every once in a while
Mr Bungle
Member
Offline
Member Since
3-23-2008
Tacoma WA
02 VW NB, and 79 VW Rabbit
 Re: How bad is it to run out of diesel? Bleed the system? (Fat Jon) »« »
And if you are going to use 2 stroke oil use ashless or smokeless, same thing.
It is clean and not full of carbon particles that can score your injectors at their high pressure. especially for like tdi pressure.
Tinker Toy
Member
Offline
Member Since
9-12-2005
Milwaukee WI
1986 NA IDI 259k mi.
 Re: How bad is it to run out of diesel? Bleed the system? (Mr Bungle) »« »
Quote, originally posted by Mr Bungle »
This is off topic but carbon particles may not be as bad as stated and last I heard, graphite is a good lubricant. Check out the following site:
http://www.embedded.com/story/OEG20010618S0078
Otherwise Google Cummins Centinel.
Modified by Tinker Toy at 11:42 PM 5-24-2008
QuantumSyncro
Member
Offline
Member Since
4-28-2000
des moines ia
1997 Jetta TDI
 Re: (Trev0rBr) »« »
The IP has an internal lift pump so priming is automatic. OTOH, it creates a lot of wear and tear on the starter to prime the system every time you run out of fuel.
Additionally, the IP has an internal reservoir that holds enough fuel to lubricate the pump but not enough to push to the injectors, so running out of fuel won't draw all the fuel out of the IP.
It's preferable never to run out of fuel. The only priming you want to have to do on a diesel is when you change the fuel filter.
97 Jetta TDI, 86 Golf diesel, 81 Caddy diesel,
79 Peugeot 504 D, 94 Chevy Silverado K1500 6.5 TD
Gir - You're on fire!
Zim - Am I?
Trev0rBr
Member
Offline
Member Since
11-25-2004
York PA
81 Jetta 81 Rabbit
word. mine always started in a few cranks as long as i put the pedal down a good bit. the longest it ever took for a car to start for me was when i did my td swap. took forever.
Fat Jon
Member
Offline
Member Since
2-26-2007
Ft Lauderdale FL
 Re: (Trev0rBr) »« »
Quote, originally posted by Trev0rBr »
yeah, i've got to hold my pedal down a good bit to get it started as well... any idea why that is ? why wont it just start up, my diesel truck does. lol
Trev0rBr
Member
Offline
Member Since
11-25-2004
York PA
81 Jetta 81 Rabbit
i just do it because i figure it will help bleed the pump faster since its trying to move more fuel.
Fat Jon
Member
Offline
Member Since
2-26-2007
Ft Lauderdale FL
im gonna test my glowplugs
Mr Bungle
Member
Offline
Member Since
3-23-2008
Tacoma WA
 Re: (QuantumSyncro) »« »
Quote, originally posted by QuantumSyncro »
Good to know, thanks
transient.labor
Member
Offline
Member Since
1-10-2007
Somewhere in CO
1984 VW Rabbit L - Two door, Diesel *putt-putt* 1981 VW Dasher Diesel Wagon
 Re: (Mr Bungle) »« »
I've run mine out of fuel twice unintentionally and once intentionally. You can easily restart the engine after refueling if you don't try to get every last drop out of the tank and lines.
As soon as you feel the engine losing power, the pump is sucking air. Immediately stop the car, refuel and the pump should prime instantly.
Don't keep trying to start the car without refueling because the more air that enters the system the harder the car will be to restart.
Abstain from eating animal products and reduce our dependence on foreign oil.
http://www.vegansociety.com/html/environment/energy/
OttoSchultz
Member
Offline
Member Since
4-15-2004
Hatfield MA
2009 Jetta TDI 6spd Platinum gray, totally stock aka MayorDJQ
 Re: (transient.labor) »« »
TDI's and Rabbit are very different creatures. ATF is NOT recommended for TDIs. Also, the drive-by-wire function can do some funky things. Putting the pedal to the floor while cranking won't necessarily help in getting the car re-started after running out of fuel.
In theory, the injection pump is self priming, but many people have found from experience, that this is not always the case. Just try putting a new fuel filter on the car totally empty, and see what happens.
My GF was driving us home one night, she woke me up at 1am to say we had run out of fuel. We were about 2 miles from the Blanford service station on I90, about halfway between exit 2 & 3. We called AAA and waited. The truck showed up finally and the driver dumped in 5 gallons of Diesel. I didn't have a funnel or other convenient way to pre-fill the filter, nor a vacuum pump to draw fuel to the IP. After cranking until the battery started dying, the car still wouldn't start. The driver refused to tow us and leave us at the next service area, but took us 20 miles back to exit 2 in Lee, and dropped the car at the truck stop, which was all but deserted. Since the battery was pretty weak at this point, the clerk helped to jump start the car. The cables were only hooked up for 30 seconds and it fired right up.
So the self-priming fuel pump is sort of self-priming, eventually.
MDTurborocco
Member
Offline
Member Since
8-24-2003
Silver Spring MD
 Re: (OttoSchultz) »« »
Thank you for everyone that has posted, this is exactly the information I was looking for and overall a very informative post. So really atf is not needed? I got this thing at 170k miles with no previous history im just trying to do everything possible to keep it tip top and keep the injectors/IP in good working order
OttoSchultz
Member
Offline
Member Since
4-15-2004
Hatfield MA
 Re: (MDTurborocco) »« »
Don't use ATF. Go over to http://www.tdiclub.com and do a search there in the Fuel & Lubricant section, and you'll get a whole bunch of reasons not to use ATF.
Trev0rBr
Member
Offline
Member Since
11-25-2004
York PA
81 Jetta 81 Rabbit
pressing the pedal down will help it prime faster since the plunger will stroke further
OttoSchultz
Member
Offline
Member Since
4-15-2004
Hatfield MA
 Re: (Trev0rBr) »« »
Not in a TDI. There's no cable from the pedal to the pump, so the ECU controls how much is injected during startup. Stepping on the pedal won't help reprime a TDI.
» Return to TDI and Diesel Forum
Forum Jump
For advertising information Click Here
ZeroForum 2.1.2. ©2008 RelyNet, Inc.
