My Profile | Active Users | Help | Search | Google Search
George@Fourtitude
Fourtitude Staff
Offline
Member Since
4-9-2004
Hershey PA
2010 S4 (on order), 1984 4000 quattro x 2 , PREVIOUS CARS - 1991 200 Turbo quattro, 2002 A4 Avant 1
 Project B7 S4: Audio Upgrade« »
Audi’s S-cars are some of the best all-round vehicles anyone could hope to own. With few choices upon ordering, everyone seems to think getting all the options means getting the best. This is especially so when you consider the latest B7 S4 as we did with our 05.5 model year subject of this series and its then-new Audi Navigation+ system paired with satellite radio and the old standby high end Bose speakers. However, when it came ordering this particular B7, those options were purposely left off the check list, not because of the added cost but rather due to our modification priorities. Being ordered by an audio buff, these components were redundant as they’d soon be replaced.
Full Story
-G
10 S4 | 84 4000 S quattro
FOURTITUDE on TWITTER
FOURTITUDE on FACEBOOK
FOURTITUDE on MYSPACE
iwantanaudi
Member
Offline
Member Since
6-8-2006
OC CA
 Re: Project B7 S4: Audio Upgrade (George@Fourtitude) »« »
Is that an OEM RS4 steering wheel, how difficult was it to install and is it functional (as far as the Sbutton etc.) ?
Thanks
(That wheel looks soooo much better than stock)
George@Fourtitude
Fourtitude Staff
Offline
Member Since
4-9-2004
Hershey PA
 Re: Project B7 S4: Audio Upgrade (iwantanaudi) »« »
It is. We'll be covering the install of that soon, although our airbag-sourcing was a bit different than most. I hear some are using the A8 bag, though there are some wiring issues. Ours is a euro bag.
-G
.:RDriver
Administrator
Offline
Member Since
10-4-1999
In the shadow of the Nations Capital
S4 Avant
Were you able to incorporate the roof antenna for the GPS and XM on the Pioneer unit, or did you have to mount additional antennas for both somewhere else?
Forum Rules | Forum Help System
Jim Sykes Photo
George@Fourtitude
Fourtitude Staff
Offline
Member Since
4-9-2004
Hershey PA
 Re: Project B7 S4: Audio Upgrade (.:RDriver) »« »
I'll pass this along to Justin (the car's owner and the author) to see if he can answer.
-G
JusTTin
Member
Offline
Member Since
1-5-2006
Dalton PA
2008 Ibis White Audi TT 3.2 S-Line
That's a good question. The roof antenna is for GSM / SAT Radio / GPS....... I used all three and it wasn't easy. Just that install alone could be an entire article. I did take pictures of that install, but I can't seem to find them. I'll tell you right now that it involves taking down some of the headliner and routing cables through some of the toughest spots in the car, so I don't plan on taking it back apart for more shots.
Basically, there were some plugs I sourced from VAG Parts in terms of plugs needed. All of the wires on my side then needed a lot of custom work, as all of the connections themselves had to be redone to match Audi's plugs.
The bottom line:
1. XM reception is BETTER than it was when I was testing the system with the stock xm magnetic antenna while I was waiting for the proper plugs..... that's amazing. Quality and reception are simply top notch there. Also, I would note that the issues Audi drivers with a radio with stock XM face, where they say the quality is poor and the volume is lower, etc.... There's no issue there for me, it probably has a lot to do with the aftermarket tuner.
2. GPS reception is also perfect. Again, while testing, the stock magnetic reciever that comes with the system worked well, but it was never perfect.... even if you placed it up on top of the trunk where it had a perfectly clear view.
3. GSM reception is again, perfect... without any amplifiers. I'm running that wire all the way to the front to the HSPDA wireless router I currently have installed in the glove box. A PCMCIA HSDPA wireless broadband card attaches to the antenna wire and instead of going directly into a laptop it installs into what is basically a wireless router. One thing about wireless broadband, the better the reception, the more bandwidth you end up with. Using the card with it's built in antenna, inside the car is less than stellar, this setup makes it very, very good. Plus, one advantage is that we can split that signal between more than one device at a time, and it has a range of about 150' radius around the car. Anyone that stopped by the Fourtitude stand at Waterfest this past year may have gotten a taste of how that works. It'll be used more this year with multiple devices inside the car making use of always-on internet.... look out for that
For good measure, the system's FM source is being fed through the diversity antenna on the rear glass as well.... That was actually a bit harder to accomplish because of the size of the wires that needed to get spliced, but it works great.... even though I don't remember when the last time I listened to FM was....
Justin
My Garage: pics of my cars
2005.5 B7 S4 Sedan: Sprint Blue on Silver Nappa / 6MT - SOLD (05.02.05 - 04.24.09)
2008 MK2 TT 3.2 Coupe: Ibis White on Black Nappa / S-Tronic
roadKonig
Member
Offline
Member Since
10-27-2005
Tustin CA
 Re: Project B7 S4: Audio Upgrade (PROPort) »« »
Awesome system / install. I'm thinking of going with the Pioneer AVIC-D3 unit. Do you see any fitment issues with a 2DIN unit?
Gone but not forgotten.
2005 S4 6MT Nogaro Blue
04 A4 1.8T USP 5MT
99.5 VW GTI VR6 5MT
92 Mazda MX5 5MT
JusTTin
Member
Offline
Member Since
1-5-2006
Dalton PA
 Re: Project B7 S4: Audio Upgrade (roadKonig) »« »
No, not at all. I did make the custom faceplace and bracket for this single din unit, and at the time it was purchased The D series wasn't out yet, nor was the new Z series (Bought the N1 almost 9 months before my S4 even arrived - and close to a year and half before it ended up installed in it).
I was considering swapping this one out with a Z2 when they come out in April and making a new bracket. All I can tell you is that between the headunit itself and all the wiring, there isn't much room behind the dash and there will be even less with a double din unit. The only problem I can see is that the bracket/faceplate will have a much thinner bezel.... which could be a problem to make, but I don't think so.
Justin
ProjectA3
Member
Offline
Member Since
8-11-2005
Anthem AZ
2008 Audi A3 S-Line
what is the yellow thing in the glove box? you didnt go into detail about that (that i saw)
awesome simple system that looks stunning and i bet it sounds great too.
Audi Brand Specialist @ Audi North Scottsdale
bmccauley@penskeautomotive.com
2008 Audi A3 2.0T S-Line S-Tronic BSH Motor Mount / Euro mirrors / B&B 3" "Stealth" TBE / EVOMS GT28RS big turbo kit w/ EVOMS IT and DSG flash / DBCPerformance / OEM S4 BBS 18's
AKA VR6 NRG on VWVortex
JusTTin
Member
Offline
Member Since
1-5-2006
Dalton PA
 Re: Project B7 S4: Audio Upgrade (ProjectA3) »« »
That yellow thing is actually lime green...and it's a cellular broadband wireless router. Works like a wireless router in your house which is connected to a dsl or cable modem, but takes a pc card style cellular modem and then routes that signal.
The finished pictures were from a couple weeks back, but some of the projects were done last spring. There will be more articles as George said on the RS4 parts which I'll tie into the alcantara two-toned doors (which I'm surprised no one noticed), then I'll tie the wireless hotspot we created into an article on mobile computing (since the car is sponsered by my company and that's what we do... it's always been a part of this project).
Modified by PROPort at 6:42 PM 1/31/2007
Modified by PROPort at 8:38 PM 1/31/2007
Justin
roadKonig
Member
Offline
Member Since
10-27-2005
Tustin CA
Quote, originally posted by ProjectA3 »
Looks like the eflection of the dome light on the CF trim to me.
04 A4 1.8T USP 5MT
99.5 VW GTI VR6 5MT
92 Mazda MX5 5MT
16v
Moderator
Offline
Member Since
8-4-1999
10 years of laying the smack down from MA
06 3.2 Avant, 08 3.2 Golf
please expound on the 3G wireless router you're using:
Make of the unit and which data card you've got plugged into it
Since there's only one operator in NA with 3G services I am familiar with their offerings but haven't seen this router before
JusTTin
Member
Offline
Member Since
1-5-2006
Dalton PA
 Re: Project B7 S4: Audio Upgrade (16v) »« »
This is a system we've been dealers of since June of last year. It comprises of a wireless broadband router from a company called Junxion Box and a Option GT Max HSDPA 3.5g pcmcia modem with service from Cingular.
Junxion Box - I believe it's about $600
Option GT Max - $300 maybe
Cingular unlimited data - $60/month
It's not a cheap solution, but basically I looked at it this summer because I needed access on the road and our new notebooks all used express card slots -- while at the time anyway no one had yet made an express card modem.... so this was the best of both worlds.... plus it's built-in with better reception and allows for multiple connections..
As I said, I'll get more into this in another article probably later in the spring, I hope.
Justin
16v
Moderator
Offline
Member Since
8-4-1999
Hmm.. I've already got a few Option 3.6 and 7.2 cards as well as free data. I'll do some looking around for the Junxion box
Thanks
JusTTin
Member
Offline
Member Since
1-5-2006
Dalton PA
You're getting free data? I've got the luxury of having a developer account with cingular to test a lot of the products we bring it. If you want a junxion box, drop me a line... we sell them. Unfortunately margins are low and they're darn expensive, but I could help you out if you need one.
Justin
16v
Moderator
Offline
Member Since
8-4-1999
I work for them testing new devices.
Shoot me an IM with your email and I'll send you a note on monday from the office
Bootre
Member
Offline
Member Since
7-24-2004
Bedford NS
2006 Audi S4 / Sprint Blue
I would like to know where you got the RS4 grill. I want one...
Thanks,
Bootre...
» Return to S4 (B6 and B7)
Forum Jump
For advertising information Click Here
ZeroForum 2.1.2. ©2008 RelyNet, Inc.
