My Profile | Active Users | Help | Search | Google Search
kayaker10
Member
Offline
Member Since
1-10-2006
Portland OR
2006 A3 2.0T
 Revo Question« »
Yesterday I had my A3 2.0T chipped with Revo. While I've only driven the car about 15 miles, I have not noticed as big a difference in power and torque as I anticipated. While it did not feel noticebly faster, it did feel like the torque was being deliverd more smoothly. I was expecting to have issues with increased wheel hop, but it had less.
The install took a little over and hour. Revo's web site says it takes 10 minutes. The tech said the download rate is very slow and the 2.0 FSI cars he does takes longer. He also owns a A3 2.0.
Am I missing something, or is the Revo just so much smoother than stock the difference is that subtle. With a supposed increase of 65 Hp and 97 lbs of torque, I expected more of a rush. He set it for the 92 octane we have in Portland, Oregon. I'll call him later this moring once he get into the shop and see what he says.
2006 A3 2.0T, Lava, Premium, Tan, Cold, OS, GIAC DSG Flash, AWE 2.5" DP HJS Cat, 3" Jetex cat back exhaust, Calera 18's, Toyo T1R's, 35% tint, stasis streetsport co, carbonio cai, SS break lines, VF engine mounts, BHS Stage I PVC Revamp, upgraded sound system. AWE KO4, S3 IC, S3 Injectors, and AWE HPFP GIAC Tuned.
crew219
Member
Offline
Member Since
10-18-2000
ITH NY
 Re: Revo Question (kayaker10) »« »
Quote, originally posted by kayaker10 »
The flash should take only 8 minutes. The ME9 can be flashed much quicker than the old ME7 ECU which took ~20 minutes.
REVO is dead linear and smooth. Not as much of a torque spike down low but the power doesn't drop off either. The car will only get stronger as you put on more miles to allow it to adapt. When you call him, ask him what he set Timing, Boost and Fueling at. Haven't heard of 92 specific settings, only 91 and 93. I think from this latest dyno on a mustang, you won't be disappointed with it.
Dave
Forge DV Review
APR SII beta logs
REVO 93 logs
APR 93 logs
kayaker10
Member
Offline
Member Since
1-10-2006
Portland OR
2006 A3 2.0T
 Re: Revo Question (crew217) »« »
I just spoke with the tuner. He said he set the timing at 2 for the 92 Octane, and the boost is set at the default 6, and the fueling is whatever the program sets it at. He also said it takes a few cold starts before the programs totally sets itself. And, that if I get the select switch, it will put it at either 91 or 98 octane, or back to stock. If I want the 92 octane setting, I'd just have to stop by the shop if I have to switch it to stock for any audi service intervals.
crew219
Member
Offline
Member Since
10-18-2000
ITH NY
No offsense to your tuner, but it sounds as if he might have set the timing a bit low.
91 octane settings for REVO (as recommended by REVO) are:
Boost: 5
Timing: 3
Fueling: 9
93 octane settings:
Boost: 7 (or 8)
Timing: 5
Fueling: 9
I would think that 92 octane would be somewhere inbetween the 91 and 93 octane settings. Then again, he could be adjusting for regional differences (altitude, type of gas & etc)
Also, with regards to SPS-select, I was under the impression that you could choose which two octane programs you received (tuner sets them for you).
Dave
Forge DV Review
APR SII beta logs
REVO 93 logs
APR 93 logs
kayaker10
Member
Offline
Member Since
1-10-2006
Portland OR
2006 A3 2.0T
He said he set the timing at 2 because of the poor quality of gas we have in the area. He did not recommend setting it higher than 3 before you start banging into the knock sensor. I think I'll drive it for a while and let it settle in. Then have him try a 3. It would be great to feel all this program has to offer.
Crew, thanks for the info!
scotchy
Member
Offline
Member Since
10-2-2005
Canada .
2006 A3 2.0T
Damn Portland gas...I guess it's too much of a pita to jump over to Washington for fuel all the time tho.
liquidhg
Member
Offline
Member Since
2-7-2006
San Diego CA
2004 VW - Reflex Silver
Quote, originally posted by crew217 »
Dave,
Are those numbers whp? Thanks!
"liquid: You need a smog in 2010... we could all be dead by then. Don't worry." -Nebuchadnezzar
crew219
Member
Offline
Member Since
10-18-2000
ITH NY
 Re: Revo Question (liquidhg) »« »
Quote, originally posted by liquidhg »
Dave,
Yessir.
Forge DV Review
APR SII beta logs
REVO 93 logs
APR 93 logs
leosgatagti
Member
Offline
Member Since
8-22-2003
rockville centre ny
01 gti
was that only revo or an exhaust and intake to?
judgegavel
Member
Offline
Member Since
4-26-2002
Staten Island NY
2004 Audi allroad 2.7t/ 2008 Mini Cooper S
 Re: Revo Question (leosgatagti) »« »
^ Revo stage 2, TBE, no intake.
2006 A3 2.0T DSG, heres the stats:
The A3-Go APR
Rhd_King
Member
Offline
Member Since
4-11-2006
Cypress TX
2006 Platinum Gray MKV GLI - Package 0
just be patient and let the program set itself after acouple of hours of stop and go driving. it really only does take about 10 mins but it seems as if your revo dealer was being courteous and making sure the settings were right. my dealer spent a lot of time with me to set my program at its full potential. after flashing it, he rode with me to ensure that all the flash was stable. it took about 3 runs in the car to finally perfect the program. the first test run, the car ran great but he said the computer log showed that i could make it a bit more aggressive. did another run and said my car is adapting to it fine and i gave him the word to adjust it once again and i finally set the limit. ive had the flash for over 2000 miles and i have had NO MISFIRES or any other mechanical failures. im sure you will be happy with it once the program finally sets in. sorry for rambling on, i just wanted to help you with your question
Modified by Rhd_King at 11:20 PM 5-23-2006
» Return to 2.0T FSI Engine Forum
Forum Jump
Northern Tool Inventory Reduction
For advertising information Click Here
ZeroForum 2.1.2. ©2008 RelyNet, Inc.
