George@Fourtitude
Fourtitude Staff
Offline
Member Since
4-9-2004
Hershey PA
2010 S4 (on order), 1984 4000 quattro x 2 , PREVIOUS CARS - 1991 200 Turbo quattro, 2002 A4 Avant 1
Project A3 DSG: Rolling Stock and Stopping Power | « » 12:41 AM 12/9/2005 | |
We all know that wheels can dramatically change the appearance, look, and character of any car, truck, or SUV, and can be the single best or worst modification that an owner can be made to a vehicle depending on who you ask. For wheels, we were thinking of doing something different, something German and something that would provide clearance with the aggressive choice in brakes we had in store. Further, knowing Project A3 was headed for SEMA, we wanted to do something a little bit more aggressive than you might typically see. Full Story
-G 10 S4 | 84 4000 S quattro FOURTITUDE on TWITTER FOURTITUDE on FACEBOOK FOURTITUDE on MYSPACE
ProjectA3
Member
Offline
Member Since
8-11-2005
Anthem AZ
2008 Audi A3 S-Line
Re: Project A3 DSG: Rolling Stock and Stopping Power (George@Fourtitude) » | « » 12:10 PM 12/9/2005 | |
damn thats sexy
Audi Brand Specialist @ Audi North Scottsdale bmccauley@penskeautomotive.com 2008 Audi A3 2.0T S-Line S-Tronic BSH Motor Mount / Euro mirrors / B&B 3" "Stealth" TBE / EVOMS GT28RS big turbo kit w/ EVOMS IT and DSG flash / DBCPerformance / OEM S4 BBS 18's AKA VR6 NRG on VWVortex
crew219
Member
Online
Member Since
10-18-2000
ITH NY
» | « » 12:18 PM 12/9/2005 | |
that porsche sticker is good for +5 hp
Forge DV Review APR SII beta logs REVO 93 logs APR 93 logs
portishead
Member
Offline
Member Since
7-28-2005
venice ca
2006 A3 DSG/Sport Black on Black
Re: (crew217) » | « » 1:21 PM 12/9/2005 | |
How much would it cost to put those porsche brakes on? Would they even fit with factory wheels?
REVO (Uninstalled)//Huper Optik Tint 30%//PIAA Low & Fog (Will Fry your wiring)//IceLink//Split Side Mirrors//S4 Mirror covers (not anymore)//GLI Pedals (Only brake pedal)//AWE Boost Gauge (uninstalled)
judgegavel
Member
Offline
Member Since
4-26-2002
Staten Island NY
2004 Audi allroad 2.7t/ 2008 Mini Cooper S
Re: (portishead) » | « » 1:46 PM 12/9/2005 | |
| Quote, originally posted by portishead » | | How much would it cost to put those porsche brakes on? Would they even fit with factory wheels? |
I think its a little over $2K here the down side though courtesy of Dave. : "First of all . . . . I doubt that the MC is properly sized to push 6 pistons. Hard to say because ECS does not make or modify their own calipers. They just bolt on whatever fits. I doubt you can make the argument that the A3 has the same master cylinder as the Cayenne, GT and Gallardo. 2nd, the rotors are larger and move the rotating mass further out from the center, still causing increased loss. 3rd, the ECS rotors are slotted wrong. They are slotted in a way that will increase pad smearing and issues with brake vibration & whatnot. 4th, the pad selection is a joke and replacement pad costs are $$$$$$$$$ 5th, ECS use coleman racing directionally vaned rotors . . . very basic, not the best design for cooling. The rotors are also slotted and drilled poorly thus making it much easier to heat / stress crack 6th, you really want to run the smallest brake kit possible for unsprung weight / low rotating mass / run smaller diameter wheels. You increase the size of the rotors if you are having cooling issues. With a better constructed aero rotor, you reduce the need for larger brake rotor sizes. Ultimately, smaller diameter wheels will have less rotating mass and more of the mass will be placed in the center. 7th, Porsche monobloc calipers are overrated. Monobloc does not equal stiffer and was implemented as a cost-saving feature from a manufacturing standpoint. Monobloc calipers make up for stiffness by increasing mass. 8th, cost of the ECS BBK is now up there with reputable brake companies . . . . i'd go with a kit specially designed for the vehicle with properly sized pistons and rotors instead of something made by one-size-fits-all calipers. Oh yea and factory brakes are 12.3". Dave " and, "Some updated info . . . ECS's kit weighs 1.5lbs less than OEM . . . . here's the kicker . . . . the rotors weigh more than OEM and the weight is placed further out Piston Area is increased from 2205mm2 to 2747.5mm2. ~25% increase in piston area . . . yea it really makes me wonder now how much more it's stretching the abilities of the stock master cylinder. Dave"
Modified by judgegavel at 1:48 PM 12/9/2005
2006 A3 2.0T DSG, heres the stats: The A3-Go APR
crew219
Member
Online
Member Since
10-18-2000
ITH NY
» | « » 1:47 PM 12/9/2005 | |
I think its slightly under 2k or around there. ECS has raised prices on them enough times to make me forget how much they actually cost. Then again, anyone can buy the calipers themselves and get coleman racing to manufacture hats / rotor rings for probably cheaper than what ECS wants.Dave
ProjectA3
Member
Offline
Member Since
8-11-2005
Anthem AZ
2008 Audi A3 S-Line
Re: (crew217) » | « » 3:20 PM 12/9/2005 | |
dave seems to be pretty "knowlegeable" on this subject, makes it sound fishy and bitter for some reason.this isnt a thread to bash anything, just to post updates on my car and give thanks to the companies that are helping.
judgegavel
Member
Offline
Member Since
4-26-2002
Staten Island NY
Re: (ProjectA3) » | « » 3:32 PM 12/9/2005 | |
| Quote, originally posted by ProjectA3 » | | this isnt a thread to bash anything, just to post updates on my car and give thanks to the companies that are helping. |
No the article gives the updates and thanks to the companies, the post is to discuss it in an open FORUM both positive and negative, and related questions and opinions.
borg54
Member
Offline
Member Since
11-16-2005
San Francisco Ca
2006 Audi A3
Re: (judgegavel) » | « » 5:58 PM 12/9/2005 | |
there are of course pros and cons to every mod. lets face it...on a racecar every thing must perform at the top level, but for the street looks and coolness are big factors. Personally i think those brakes, while total over kill, look bitchin. 15' wheels might be better for the track too, but they look like crap.
crew219
Member
Online
Member Since
10-18-2000
ITH NY
Re: (borg54) » | « » 6:28 PM 12/9/2005 | |
| Quote, originally posted by borg54 » | | there are of course pros and cons to every mod. lets face it...on a racecar every thing must perform at the top level, but for the street looks and coolness are big factors. Personally i think those brakes, while total over kill, look bitchin. 15' wheels might be better for the track too, but they look like crap. |
Still doesn't justify a poorly designed BBK that costs $2250 which could be had for $1600 a few years ago. My money goes to Stoptech ($1900), Brembo or Alcon. Dave
George@Fourtitude
Fourtitude Staff
Offline
Member Since
4-9-2004
Hershey PA
Re: (judgegavel) » | « » 8:28 PM 12/9/2005 | |
| Quote, originally posted by judgegavel » | No the article gives the updates and thanks to the companies, the post is to discuss it in an open FORUM both positive and negative, and related questions and opinions. |
You are correct in this. I think there are some strong opnions being voiced here leaning one way, and at the same time it's also natural for Brian to be defensive about his car and his choices. More importantly.... | Quote, originally posted by borg54 » | | there are of course pros and cons to every mod. lets face it...on a racecar every thing must perform at the top level, but for the street looks and coolness are big factors. Personally i think those brakes, while total over kill, look bitchin. 15' wheels might be better for the track too, but they look like crap. |
Well said.
RED WHIP
Member
Offline
Member Since
12-9-2005
Miami FL
Audi A3 2.0T 6spd
» | « » 8:30 PM 12/9/2005 | |
Gotta love forums where once can voice opinions, facts and do it civil.  Brian's car is very nice for the theme he is going for.
ProjectA3
Member
Offline
Member Since
8-11-2005
Anthem AZ
2008 Audi A3 S-Line
Re: (RED WHIP) » | « » 8:34 PM 12/9/2005 | |
again , i like them and on a daily basis and for the autoX use i have used them for they work awesome with no fad or bad pedal feel.i do plan to run NASA or other track events in the future and only then will i be able to see the systems full potential, goods and bads. but for now they look bad ass, work great, made great, and perform nicely.
mack73
Member
Offline
Member Since
1-1-2002
Seattle WA
'07 A3 3.2Q, '04 A4 3.0Q, '94 Golf Rally Project,
Re: (ProjectA3) » | « » 9:17 PM 12/9/2005 | |
Looks very nice, Just played Speed channel's Sema coverage off the Tivo and it was very nice to see the car it on tv for a split second
'07 Audi A3 3.2Q: '94 Rally Golf: Watch the build '04 Audi A4 3.0Q: The wife's ride
ProjectA3
Member
Offline
Member Since
8-11-2005
Anthem AZ
2008 Audi A3 S-Line
Re: (mack73) » | « » 10:23 AM 12/10/2005 | |
| Quote, originally posted by mack73 » | Looks very nice, Just played Speed channel's Sema coverage off the Tivo and it was very nice to see the car it on tv for a split second |
i missed that damn show. I am gonna have to get them to send me a copy. or hope its available for download sometime soon.
Black20th
Member
Offline
Member Since
7-3-2002
Re: (ProjectA3) » | « » 2:01 PM 12/10/2005 | |
awesome, love ProjectA3
mack73
Member
Offline
Member Since
1-1-2002
Seattle WA
Re: (ProjectA3) » | « » 2:13 PM 12/10/2005 | |
| Quote, originally posted by ProjectA3 » | i missed that damn show. I am gonna have to get them to send me a copy. or hope its available for download sometime soon. |
They started the shot looking at the hood, zoomed in close on your euro plate, then panned around the drivers corner to show the wheels/calipers
ProjectA3
Member
Offline
Member Since
8-11-2005
Anthem AZ
2008 Audi A3 S-Line
Re: (mack73) » | « » 2:47 PM 12/10/2005 | |
| Quote, originally posted by mack73 » | They started the shot looking at the hood, zoomed in close on your euro plate, then panned around the drivers corner to show the wheels/calipers |
awesome, thanks and thanks for the compliments the next article will bring one true surprise to everyone.
