My Profile | Active Users | Help | Search | Google Search
Pretarion
Member
Offline
Member Since
6-13-2003
North Tx
 Vag Com Steering/Boost pressure settings« »
Anyone tightened up the steering with vag-com? Just curious
Why do we drive on Parkways , and park on Driveways ?
Misano
Member
Offline
Member Since
5-29-2003
Van Nuys ca
 Re: Vag Com Steering/Boost pressure settings (Pretarion) »« »
I am currently on setting 3, much improved over the stock setting of 8
amartinez
Member
Offline
Member Since
7-24-2005
NORTH LAS VEGAS NV
2006 A3
 Re: Vag Com Steering/Boost pressure settings (Misano) »« »
How do you do this? Where do I find this in my Vag Com. Ijust got the cable a couple weeks ago so I'm still trying to figure out the interface.
Theresias
Member
Offline
Member Since
2-11-2004
Magdeburg Germany
'07 Skoda Octavia 2.0T, '67 Mustang Conv. 289
VAG-COM > SELECT > 44 - Steering Assist (Drivetrain) > Adaptation - 10 > Channel 001
Sebastian @ www.Ross-Tech.com
Current VAG-COM/VCDS Version: 908.1
Current VAG-COM/VCDS Beta Version: ---
Männer haben Garagen, Frauen haben PAX.
crew219
Member
Offline
Member Since
10-18-2000
ITH NY
Quote, originally posted by Misano »
It seems that most cars are shipping out with stock setting "6"
Dave
Forge DV Review
APR SII beta logs
REVO 93 logs
APR 93 logs
Theresias
Member
Offline
Member Since
2-11-2004
Magdeburg Germany
The setting depends on what steering assistent generation one has and which type of vehicle (low weight/high weight).
GTI017
Member
Offline
Member Since
7-21-2004
Seattle WA
'08 R32 -- '06 A3(sold) -- 20th AE GTI (Sold) -- '72 Type II Riviera -- 2008 Touareg
 Re: (Theresias) »« »
Quote, originally posted by Theresias »
i am going to have this done tonight... is there anything else i should know? Should i wait until i lower the car first?
TIA
.:'08 MKV.:R32 - '72 Type II Bus - '08 T2 Touareg:.
I wish I was your derivative so I could lay tangent to your curves.
BPC--Dubs» I'm not only a member, I'm also your father
judgegavel
Member
Offline
Member Since
4-26-2002
Staten Island NY
2004 Audi allroad 2.7t/ 2008 Mini Cooper S
 Re: Vag Com Steering/Boost pressure settings (crew217) »« »
Quote, originally posted by crew217 »
Dave
I dont know maybe currently, but when we checked Chris W. ChrisC. mine Ryans and Uwe's atr the BBQ over last summer, all but Uwes was set at 8, but those were all early shipped models.
As for it being lower I hate it, too much work when the cars under 10 mph. when I tested Ryans car (I think it was at 4) it felt like I was driving my 81 Toyota corola (which had no power steering) when I was making slow turns. Perhaps I'm just real use to the way it is.
2006 A3 2.0T DSG, heres the stats:
The A3-Go APR
OOOO-A3
Member
Offline
Member Since
7-19-2004
Newark DE
2006 Audi A3 2.0T
 Re: (GTI017) »« »
Quote, originally posted by GTI017 »
TIA
No, just do it. I set mine on '3' and it's perfect.
A3 info
Get FireVortex
OOOO-A3
Member
Offline
Member Since
7-19-2004
Newark DE
2006 Audi A3 2.0T
 Re: Vag Com Steering/Boost pressure settings (judgegavel) »« »
Quote, originally posted by judgegavel »
I don't find it to be stiff at low speeds at all. The variable-boost takes care of that fine. I did find it to be excessively sensitive/twitchy when at the original setting of '6'.
A3 info
Get FireVortex
GTI017
Member
Offline
Member Since
7-21-2004
Seattle WA
 Re: Vag Com Steering/Boost pressure settings (OOOO-A3) »« »
Quote, originally posted by OOOO-A3 »
i guess i will have to play around with it. I am doing that and my rear fog tonight
3dr A3 3.2
Member
Offline
Member Since
12-28-2004
france
2005 3dr Audi A3 3.2 Q - Manual
Stock was at 8, tried 0 for a while, then went to 3, will probably go to 2.
The heavier, firmer steering more closely matches my stiffer shifter, and the stiffer suspension. Now If I could only have a harder brake pedal, all the controls would be nicely balanced...
Ben's home-grown RS3:
3dr Audi A3 3.2 Quattro MT6 - KW V3 - HPP - H&R - Stasis 14.5" front BBK - VF mounts - DG - Nspd RS-6
OSIR design fenders / S3 body kit.
HPA\\\ FT450, Peloquin TBD , Spec SM FW and clutch, EvoMS intake & Snow Boost Cooler. Phil @ BSH =
yam
Member
Offline
Member Since
7-18-2005
Santa Jose CA
A3 3.2Q DSG S-Line
Stock was 5, currently at 3. May go to 1 shortly. 3 is a nice compromise though.
aeitingon
Member
Offline
Member Since
3-20-2005
Orlando FL
2006 Audi A3 2.0T DSG Premium
Stock was 8 - went to 5 - then settled on 6.
2006 Brilliant Red A3 2.0T, DSG, Premium, Nav+, Xenon, Open Sky, Sound, Sirius
Mogul2001
Member
Offline
Member Since
3-17-2003
Heidelberg / Germany
2005 AUDI A3
Help me out guys,
do i have to change the channel 001 to 003 if i want the setting 3 or how does it work ?
Perhaps somebody can make a screenshot of the vagcom while playing with theese settings.
Patronus
Member
Offline
Member Since
11-14-2003
Vancouver WA
 Re: (Mogul2001) »« »
I wonder if the US Premiums are set at 8 and the sports/S-lines at 5? Any data to support this?
GTI017
Member
Offline
Member Since
7-21-2004
Seattle WA
Quote, originally posted by Mogul2001 »
Help me out guys,
x2
bassbiker
Member
Offline
Member Since
10-29-2005
Hunt Valley MD
'06 A3 2.0T DSG
Help me out guys,
Here ya go, and you do not change the Channel from 001 to 003.
You go to up Channel Number 01, then you will see a Stored value to the right of that.
That is the factory setting or previously saved setting if you've changed it before.
To enter a new value, you type the number in the New Value field, hit Test button, then hit Save button.
Hit Done and exit all the way out. Power off ignition, power it back on and crank engine and go for a spin. Test out how it feels for slow speed parking and u-turns, then take it for spin on the highway.
Adjust, if necessary. Do not try to change this setting on the fly, only do it parked and engine off, with ignition switch in ON position.
Modified by bassbiker at 6:42 PM 3/14/2006
Modified by bassbiker at 6:43 PM 3/14/2006
Modified by bassbiker at 6:47 PM 3/14/2006
Mogul2001
Member
Offline
Member Since
3-17-2003
2005 AUDI A3
 Re: (bassbiker) »« »
Thx a lot bassbiker !
GTI017
Member
Offline
Member Since
7-21-2004
Seattle WA
it should also be mentioned that you have to have the very latest VAG-COM adapter and download the very latest software. My friend has the 2nd to last version of the adapter so it did not work
kr964
Member
Offline
Member Since
3-22-2005
White Plains NY
1979 VW Golf GTI
But it only affects steering boost at low speeds.
The level of steering assist at the highway speeds DOES NOT change at all...
2004 A4 Avant 3.0, sport pkg, 6-speed,
2006 A3 Sportback 2.0T, 6-speed,
1991 Porsche Carrera 2 (Type 964)
RyanA3
Member
Offline
Member Since
5-11-2005
Philaburbia PA
Audi A3 2.0TFSI
I was at 8 stock. I changed it to 6. Judge I think you're def just used to what you have (8) and like it.
I drive two A3s. One is at 6 (my modified car), the other is at 8 (stock). I love it at 6. I haven't tried anything lower but plan on testing other cars at future GTGs.
It will be a matter of preference for each person. I feel that it adds to the sportiness of the car having it lowered some. With a chip, 18"s, rear sway bar, and the steering adjusted - it really FEELS like I'm driving a sports car.
My media-room
The Volvo C30 Thread
OOOO-A3
Member
Offline
Member Since
7-19-2004
Newark DE
2006 Audi A3 2.0T
 Re: (kr964) »« »
Quote, originally posted by kr964 »
That has not been my experience at all. Highway-speed boost has been reduced, resulting in more stable handling on the road.
A3 info
Get FireVortex
RyanA3
Member
Offline
Member Since
5-11-2005
Philaburbia PA
Audi A3 2.0TFSI
 Re: (OOOO-A3) »« »
Exactly.
More steering assistance is provided when the vehicle is traveling at low speeds / the steering wheel is undergoing larger and faster rotations. Assistance is reduced when traveling at higher speeds / the steering wheel is undergoing smaller movements.
0-10mph, a map is selected by the control module in response to the more rapid turns and larger amount of force placed on the steering wheel.
At 62mph and up, the module will choose to apply little to no steering assistance b/c you would be applying a lighter force to the steering wheel, such as when changing lanes.
The module has room for 16 different maps. VW/Audi has installed 13 maps in the module. Each map is based on the following factors...
-vehicle weight
-vehicle size
-shocks
-springs
-wheels
-tires
-fwd or awd
My media-room
GTI017
Member
Offline
Member Since
7-21-2004
Seattle WA
 Re: (Patronus) »« »
Quote, originally posted by Patronus »
Well i played with mine last night and it was set to 5 and i have the Premium package.
i plan to change it to 3 but i want my cup kit to settle a little first.
RyanA3
Member
Offline
Member Since
5-11-2005
Philaburbia PA
Audi A3 2.0TFSI
 Re: (GTI017) »« »
what cup kit do you have, and do you have a link to pics?
My media-room
GTI017
Member
Offline
Member Since
7-21-2004
Seattle WA
 Re: (RyanA3) »« »
Quote, originally posted by RyanA3 »
shh i just got the H&R kit last night.
i will be taking pics this weekend... it looks amazing
theskippur
Member
Offline
Member Since
6-26-2000
Kent WA
2008 4dr Black GTI
 Re: (GTI017) »« »
Bumping this in hopes of an answer to the question, why is there no rhyme or reason for the stock steering setting? It seems like a lack of quality control when some are set to 8, while others are set to 5. Anyone know why this is?
yam
Member
Offline
Member Since
7-18-2005
Santa Jose CA
A3 3.2Q DSG S-Line
There is rhyme or reason. The setting depends on the options that affect the weight of the car, as well as sport or premium suspension. So open sky + DSG + Premium package will have more boost.
bassbiker
Member
Offline
Member Since
10-29-2005
Hunt Valley MD
'06 A3 2.0T DSG
 Re: (theskippur) »« »
The quote above is the definitive answer to your question.
Theresias is actually part of the VAGCOM support team and is the real guru when it comes to these German machines and their control modules.
rektek
Member
Offline
Member Since
12-20-2004
Los Angeles CA
Stock was 5, now it's on 2. Perfect for me. Wifey's bmw still way-way-way more effort to turn than even 0 on the a3.
2002 TT225 | giac | ssr type c-rs
2006 A3 3.2q dsg | lava | nav | xm | 18’s | closed sky | bone stock
2004 Touareg v8 - rip
asylum
Member
Offline
Member Since
1-11-2000
Ajax,Ontario
 Re: (rektek) »« »
mine was also set to 5 stock. I just set mine to 3 so Im going to try that out
06 Audi A3 2.0t (APR STAGE 3 - 344whp)
04 Dodge SRT4 (465whp) , 09 Suzuki Hayabusa (not stock anymore )
97 VW golf cl auto (work vehicle - 70whp )
K&H is an authorized APR distributor! Call 416-266-7777 for more details
**** DYNO SERVICE AVAILABLE!!!!!! ****
bluely
Member
Offline
Member Since
12-4-2001
Santa Monica CA
 Re: (asylum) »« »
my stock was 8 (I had an early production vehicle). switched it to 3 last weekend. will likely switch it to 0 next chance.
kennyA3
Member
Offline
Member Since
1-14-2006
So Cal
2006 Audi A3 2.0T Sport
 Re: (bluely) »« »
went from 5 to 3....lovin it. dunno if i'll go lower tho
2006 A3 2.0T
Sport/OSS/Xenon/6MT
B7S4 CH's // SolarGuard 25/40 // GTI pedals // MK2 TT dead pedal // DICE // Vag'd // debadged // premium mats // THULE aero roof rack // NEUSPEED RSB // AWE Boost Gauge // Carbino // STaSIS streetsports // Eurogear CF hood w/ AeroCatch latches // ATE super blue // ss brake lines
WhyteA3
Member
Offline
Member Since
4-12-2006
Edmonton AB
2007 Subaru STI Limited & 2006 Audi A3 2.0T
I had stock setting of 5 (Sport Package).
I went from 5 to 2. It was okay, but I wanted more feel, and I've settled on 1.
Great tight feel.
504WHP Pump gas; 600WHP Race Gas '07 STI Limited
First  1 2 >  Last
» Return to A3 & S3 (8P)
Forum Jump
F1 Marketing Group, Inc.
For advertising information Click Here
ZeroForum 2.1.2. ©2008 RelyNet, Inc.
