Fourtitude.com - Quick question.. how many liters of coolant does our radiator hold?
    Results 1 to 4 of 4
    1. 07-28-2003 11:50 PM #1
      Topic says it all
      Feb 23rd, 2000
      Shepherdstown, WV
      18,080
      07-29-2003 12:04 AM #2
      Quote, originally posted by laylomo »
      Topic says it all
      Actually the topic says nothing. do you want the radiator itself, the whole coolant system, for a golf, NB, passat, A4???
      Generally though if you are draining and refilling which is useless unless its visibly discolored, it will take just shy of two gallons 50/50 coolant/water.
    4. 07-29-2003 12:17 AM #3
      I thought most of the coolant is held in the radiator? Well .. I guess my question is how much coolant in the entire coolant system
      2 gallons? its already 50/50 mixed with water from factory?
      Thanks for clearifying!
    5. Member
      Feb 23rd, 2000
      Shepherdstown, WV
      18,080
      07-29-2003 12:27 AM #4
      alot is in the radiator yes, but probably less then half, you have the block, head, heatercore, hoses, and overflow tank also.
      The car comes with it mixed about 50/50 yes, the coolant from the dealer however is straight coolant not mixed.
