Fourtitude.com - Air fittings - insulation on threads
    Results 1 to 5 of 5
    1. 05-19-2017 11:09 AM #1
      Does the white insulation or paint that comes on air fittings threads need to be remove before applying tape or sealant?
    3. Member northendroid's Avatar
      Sep 16th, 2014
      Cornwall, Ontario, Canada
      1,300
      Bagged 2015 Passat - !991 Corrado G60
      05-19-2017 07:09 PM #2
      What you're referring as "paint/insulation" is mostly likely pipe dope. No need to remove it or apply teflon tape, just screw it into the port.
      2015 Passat TDI Highline (SEL) Yes It's Bagged Build, Restoring 1991 Corrado G60
    4. Member cmdshft's Avatar
      Oct 17th, 2011
      Hackensack, NJ
      971
      2003 GTI 1.8T Airlift 3P
      05-19-2017 10:14 PM #3
      If you ever have to take them out for some reason, get "Permatex Thread Sealant", it's a white bottle and it works better than the teflon tape.
      But yes, if the fittings came with teflon on them, use them as they are and just bolt them in where they go. Tighten but don't over tighten.
    5. 05-19-2017 11:19 PM #4
      This stuff doesn't seem like telfon tape to me. But I just wired brush it off and used loctite 545.
    6. Member MechEngg's Avatar
      Jan 12th, 2009
      Calgary, AB
      7,579
      06-02-2017 04:46 PM #5
      It is a teflon paste, not tape form. Be careful wire wheeling it off because the brass is soft and you can end up causing leaks if you use steel brushes or hold it on for too long.
      Follow me on IG @Mech_Engg
      A-very-technical-build | Part I | PART-II | PART-III
      OpenRoadTuning | Accuair
