Fourtitude.com - Camshafts alignment
    Results 1 to 5 of 5
    1. Member PernellGTI's Avatar
      Jan 1st, 2010
      Phoenix
      341
      B8.5 A4 Stage 2+, 2011 Q5, E30, B7 A4 S-line, B5S4 Stage 3
      05-18-2017 03:16 PM #1
      Hey guys and gals, I recently repaired a 2.0t (early version, non valve lift) due to a broken cam chain tensioner, as you could expect, cam adjuster, tensioner, chain, adjuster bolt and 2 intake valves took a dump, long story short I replaced all, rebuilt head etc. But I have some codes:
      3 Faults Found:
      012555 - Low Pressure Fuel regulation
      P310B - 008 - Fuel Pressure Outside Specification - MIL ON
      Freeze Frame:
      Fault Status: 11101000
      Fault Priority: 0
      Fault Frequency: 5
      Reset counter: 255
      Mileage: 312564 km
      Time Indication: 0
      Freeze Frame:
      RPM: 966 /min
      Load: 67.0 %
      Speed: 0.0 km/h
      Temperature: 31.0°C
      Temperature: 33.0°C
      Absolute Pres.: 950.0 mbar
      Voltage: 13.970 V
      000768 - Random/Multiple Cylinder Misfire Detected
      P0300 - 001 - - MIL ON
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 5
      Reset counter: 255
      Mileage: 312564 km
      Time Indication: 0
      000772 - Cylinder 4
      P0304 - 001 - Misfire Detected - MIL ON
      Freeze Frame:
      Fault Status: 11100001
      Fault Priority: 0
      Fault Frequency: 2
      Reset counter: 255
      Mileage: 312564 km
      Time Indication: 0
      Freeze Frame:
      RPM: 755 /min
      Load: 18.0 %
      Speed: 0.0 km/h
      Temperature: 92.0°C
      Temperature: 69.0°C
      Absolute Pres.: 960.0 mbar
      Voltage: 13.589 V
      I bought this car for dirt cheap and I have zero info on previous maintenance so I have been doing a lot to it, it is a 06 A4 2.0t s-line, everything is really nice except the problems above.
      So far besides fixing/rebuilding the top end I have done:
      -new oil separator and all pcv hoses
      -new coilpacks
      -new spark plugs
      -new oil filter
      -new VVT solenoid (n205)
      I am wondering if I have a cam timing issue, or a HPFP issue. My manual literally only says to make sure cam lobes on cyl. 4 should be pointing up and inwards and has a tiny picture as example, timing marks all align fine, engine turned fine and without issues by hand, runs good but has some idle issues. I am puzzled.
      Anyone has some input?
      "If you no longer go for a gap that exists, you are no longer a racing driver" -Ayrton Senna
      GTX2867R/Autotech Intake Cam/ACT STG 2 Clutch/BOSCH 1000cc Injectors/IE RODS/70mm Throttle Body/Ported Intake Manifold/ATP T3 Exhaust manifold/Full 3" Exhaust, Catless, /VF Mounts/Eurodyne Maestro 7/Water & Meth Injection/Vibrant FMIC. IG: imola_yellow
      Nov 27th, 2011
      MD
      1,650
      05-19-2017 07:36 PM #2
      There is a Tsb/ Ts for the P310B Dtc. If you can not find it PM and I can send it to you via email.
      As for the misfire dtc swap coils 4 and 3 see if misfire goes over to 3.
    4. Member PernellGTI's Avatar
      Jan 1st, 2010
      Phoenix
      341
      05-20-2017 02:49 PM #3
      Quote Originally Posted by GTI's View Post
      I found the TSB! Thanks! I am going to check the car today, also I did move the coils but I get both misfire codes, multiple and cyl 4.
    5. Member
      Nov 27th, 2011
      MD
      1,650
      05-20-2017 04:06 PM #4
      Did you forget to clear the dtc after swapping the coils. If you did then swap spark plug 4 to 3 clear dtc and see if misfire codes come back or watch for misfires with Vcds in engine control module.
    6. Member PernellGTI's Avatar
      Jan 1st, 2010
      Phoenix
      341
      05-20-2017 06:37 PM #5
      ok, switched coils and cleared DTC's, no more misfires!
      But the fuel pump codes keep coming back after some driving around the block... Now, I remember the previous owner (older lady) said she personally changed the intank fuel pump, and it seems like non original Audi/VW pumps trigger this DTC too?
      I am going to follow the instructions on the TSB, luckly I found a low miles working HPFP and I will test it, and test the LP fuel sensor as well, after that I guess the only thing left to do would be the intank pump, And damn, almost $300 for that..
