Guys, I just installed a AEM methanol kit Stage 2 (30-3300), the problem is during my accelaration process, the error led begins to flash in red (1 flashes, low level tank), but the amount of fluid in the tank is ok. Please see the video attached.
Anyone had the same problem?. Anyone know the root cause of the problem and how it can be solved?
Havent had this issue because im not running meth yet but probable cause might be the actual sensor or wiring. Double check the circuit for the sensor and the sensor itself
Thanks Joy, but in case of sensor or circuit sensor could be the problem, when a press the test controller module button (with the nozzle disconnected from the engine) in order to test the system functionality, the error LED by low level tank should appears, but in my case it is not happen...the functionality system test happens with no problem, previous and during the total test process, totaly normal, so I understand the sensor level and wires are ok.
sprinkle some salt into the reservoir. i get a low level all the time, it has to do with the conductivity of the sensor.
