Hey TSI experts,
I have an 09 GTI w/ 185k TSI engine. Purchased the car for cheap as there is an engine issue. To get right to it, the timing chain tensioner did fail on the previous owner and was replaced last year. According to the previous owner, when coming back from lunch, the car would not start. Car was taken to the mechanic, in which metal shavings were found in the oil pan. I have removed the pan and saw no oil shavings in the pump filter or anywhere that I could see. I cannot seem to remove the top aluminum portion of the oil pan off to inspect bearings. Any chance someone knows a trick on that? Everything should be loose as far as I can tell.
Anyways, car pulled up 14 codes (cylinder 1, 2, 3, and 4 misfires, crankshaft position, camshaft position, etc...). The idle is rough. The valves were done (as they were all bent) when the timing chain tensioner was replaced as well. The chain seems a bit loose, not crazy loose but enough for me to notice (not sure if that's normal or not). I did break the oil pump rail/tensioner so maybe that has something to do with it. Instead of purchasing a new chain and tensioner not knowing if that will fix the issue (maybe valves are bent?), what are the next steps I should take?
Get it timed correctly, put it back together and see how it runs?
Any thoughts would be appreciated.
Thank you!
Thank you!
