Fourtitude.com - Fuse 43 (S243) at wits end!
    Results 1 to 6 of 6
    1. Member soulnomad's Avatar
      Jan 7th, 2010
      Richmond, VA
      108
      MK4 K04 AWP JETTA, BAGGED/SHAVED/EUROSPEC
      03-20-2017 04:38 PM #1
      Hey guys, I have been frying my brain over this S243 issue with my AWP 1.8t. Thus far I have disconnected.
      -front/rear o2 sensors
      -N112(removed/resistored)
      -J229 (replaced)
      -MAF
      -N80(removed/resistored)
      -Leak detection pump
      The fuse immediately shorts when the key is turned to "on" position with all these accesories removed. I also noticed when i pulled J271 (relay label 428, ECM Power Supply) the fuse does not short. I have some diagram references from my haynes manual as they are not very helpful though. Could anyone suggest a path to take next. My ECM should be sound, no exposure to water etc., butanyway to test it as well? Thanks
    3. Member elRey's Avatar
      May 15th, 2001
      8,022
      16vt 2.0L MK4 Jetta Wagon | B6 A4 Avant
      03-20-2017 07:28 PM #2
      both O2 heaters also on that fuse.
    4. Member soulnomad's Avatar
      Jan 7th, 2010
      Richmond, VA
      108
      03-22-2017 02:09 AM #3
      As of today, checked both heater wires to o2 sensors. Cut and replaced both heater wires as they did have openings throughout the wire jacket, yet still no improvement. Any suggestions now? thanks!
    5. Member soulnomad's Avatar
      Jan 7th, 2010
      Richmond, VA
      108
      03-22-2017 05:16 PM #4
      UPDATE FIXED: replaced j271/j299 and disconnected bank1/2 oxygen sensor. Fuse intact with start....bank 1 oxygen sensor internal short causing the slew of short to ground codes. Hopefully this will help someone in the future.
      Sep 5th, 2013
      Minneapolis
      227
      2001 Jetta, 2004 Passat 4mo 1.8t (RIP)
      03-22-2017 06:08 PM #5
      Quote Originally Posted by soulnomad View Post
      thanks for coming back and posting what you found, we appreciate it
    7. Member soulnomad's Avatar
      Jan 7th, 2010
      Richmond, VA
      108
      03-22-2017 08:18 PM #6
      Also forgot to add I found 3 shorts in the o2 heater wire circuit (red/blue stripe). Pulled and ran new wires as well! Unresolved threads suck.
