Just wanted to update you guys regarding this. So I ordered the adapter and installed it. The install is a breeze (just slightly time consuming).
Here is the adapter installed..it sits right under the MAP sensor on the intake manifold:
What was sort of a pain was that the hose the gauge came with was a bit small compared to the adapter nipple. So I had to use a heat gun to soften the tube up to make it work. Thats the only thing that should be considered when installing this.
Running the hose was easy since I just followed the wire route for my audio system.
Took about 45 minutes as the wiring took some time since I had to grab some
spare wire to use as extensions. But it is complete.
I will more than likely go with the NSP vent pod but this will do for now.
Sent from my LG V10 using Tapatalk
