Fourtitude.com - Mk1 ABA Swap, Starts then dies
    Results 1 to 3 of 3
    1. 12-01-2016 12:09 AM #1
      Hey! So I've been having some problems with my swap. I'm swapping it into my mk1. Everything is hooked up. I can get it to start for about 5 seconds, revs up to about 500rpm then dies. Even If I keep throttle on it. I've replaced my stock fuel pump. I've done timing multiple times, bypassed the fuse relay. Everything is at TDC. I have no idea what to look at.
      I'am throwing the code p0341.
      I've bought a new distributor and it does not have a mark for the rotor. I've lined up the window to the hall sensor. Could that be the issue?
    3. 12-25-2016 12:05 PM #2
      Hi . I have the same problem after i swaped an 1.8 engine. The imobiliser doesnt transmit signal to ecu for start. Verify the immo
    4. Junior Member barnacles1992's Avatar
      Oct 24th, 2016
      New England
      37
      MKII VW Jetta GL, MKIV Wolfsburg Jetta
      03-20-2017 11:42 AM #3
      Immobilizer. Get it coded out of the ECU. Any other weird things that its doing?
      That n00b title is so degrading......had an old account but lost it. RIP
