Fourtitude.com - Time to get a Mullet. Camaro purchase inside.
    Page 4 of 9 FirstFirst 12345678 ... LastLast
    Results 76 to 100 of 215
    1. 12-11-2015 12:38 PM #76
      Quote Originally Posted by 200HP4dr View Post
      Hmm... should I go fuel injected?
      Up to you. I am converting to a carb setup for simplicity. Down the road, I may upgrade that to a self-tuning EFI setup.
      Dempsey Bowling
      Sales Consultant at Doug Smith Dodge/Chrysler/Jeep/Ram/Subaru/Kia/used
      My fleet: 91 Miata, 98 Wrangler Sport, 01 Suburban 2500 8.1L, 14 Impreza Limited, 80 Grand Prix LJ 454
      Nov 19th, 2006
      Raleigh, NC
      2,930
      2009 BMW 328i xDrive Wagon 6MT
      12-11-2015 12:39 PM #77
      Quote Originally Posted by karl_1052 View Post
      I imagine it had to do with adding leafs to the rear to make the suspension stiffer, at the same time raising the ass end.
      If you change the shackle length to change the angle of the leaf spring, you can influence the roll-steer characteristics of the car. Most stock leaf spring vehicles have the front eye of the spring lower than the rear eye, this is the safer configuration because it causes roll understeer. When that particular side is compressed, that wheel moves forward in the wheel well and pivots about the horizontal axis (remember its a solid axle so its tied to the other wheel on the other side) so that it toes in.
      If you "shackle up" the rear by lengthening the rear shackle, the rear leaf spring eye drops in relation to the front eye, reducing the amount of roll understeer, or possibly even adding roll oversteer. Basically, it makes the handling feel sportier but more "dangerous". The other thing that is done is to relocate the front spring mounts up an inch, it has a similar effect but lowers ride height instead of raising it.
      Check this link, its pretty interesting how they made these older, simpler cars handle well despite leaf springs and solid axles:
      https://books.google.com/books?id=cr...20axle&f=false
    4. Member Crispyfritter's Avatar
      Nov 21st, 2001
      SW KS
      11,729
      12-11-2015 12:44 PM #78
      Quote Originally Posted by TurboMinivan View Post
      What are you doing for a transmission? Mounts, controller, etc?
      Chris
      | 2017 Korean Appliance SE | 2008 Suburban LTZ | 2003 Dodge Ram | 2002 BMW 530i con mañuel | 1974 SuperBeetle x 2 | 1979 Camaro | 1975 Scout |
      The poster formerly known as 200HP4dr
    5. 12-11-2015 01:05 PM #79
      I'm using the 4L80-E from my donor van. I will need to make a modification to my stock trans crossmember for the mount to line up, but that will be a simple operation. I plan to buy a TCI EZ-TCU standalone controller to operate it.
      Dempsey Bowling
    6. Member Crispyfritter's Avatar
      Nov 21st, 2001
      SW KS
      11,729
      12-11-2015 01:06 PM #80
      Okay. Awesome. I just found a complete truck for $1100 with that set up. Hmm....
      Chris
    7. Member karl_1052's Avatar
      Feb 10th, 2008
      O-Town
      5,244
      2009 Mazda 6s
      12-14-2015 09:34 AM #81
      Quote Originally Posted by mrothwell View Post
      If you change the shackle length to change the angle of the leaf spring, you can influence the roll-steer characteristics of the car. Most stock leaf spring vehicles have the front eye of the spring lower than the rear eye, this is the safer configuration because it causes roll understeer. When that particular side is compressed, that wheel moves forward in the wheel well and pivots about the horizontal axis (remember its a solid axle so its tied to the other wheel on the other side) so that it tows in.
      This is pretty cool info.
      "The Sebring is an extraordinary car. Ugly to behold and hateful to drive, it is not cheap, elegant, comfortable, practical, prestigious, clever, economical, luxurious, well designed, well thought out or, if the rental car I drove in America this year is anything to go by, especially well made either." - Jeremy Clarkson
    8. Banned Check Out My Mixtape's Avatar
      Dec 11th, 2015
      Destin, FL
      67
      92 GTi
      12-14-2015 11:43 AM #82
      yeeeeeeeeeeeeeeehawwwwwwwwwwwwwwwwww
    9. Geriatric Member
      Jun 23rd, 1999
      New England
      54,014
      '97 BMW 328i | '12 XC70 T6
      12-14-2015 01:06 PM #83
      Did your folks drive it up from the Bahamas?
      Quote Originally Posted by Harv View Post
      Quote Originally Posted by patrickvr6 View Post
      I believe that is a flamingo.
      there's a distinct lack of soundtrack to this whole thread
      You should twine wrap that steering wheel:
    10. Banned Check Out My Mixtape's Avatar
      Dec 11th, 2015
      Destin, FL
      67
      92 GTi
      12-14-2015 01:11 PM #84
      Is there a Boston tape stuck in the deck?
    11. Member Crispyfritter's Avatar
      Nov 21st, 2001
      SW KS
      11,729
      01-11-2016 10:16 AM #85
      Quote Originally Posted by Check Out My Mixtape View Post
      No radio. Just gauges in an aluminum mounting plate.
      So, as we were pulling the engine, there were the "washers" used on the chrome fan guard.
      Started at 5:20 on Saturday with this:
      Ended at 7:10 with this:
      and this
      and this
      I'm still looking for the perfect donor vehicle.
      Chris
    12. Member Stevo12's Avatar
      Jul 27th, 2015
      Hartford, CT
      1,287
      '14 WRB Frontier, '97 M3, '92 GTI project
      01-11-2016 10:27 AM #86
      You also have 3/4- and 1-ton vans to be able to source the 6.0 and 4L80E, just in case 2500HD's are out of your reach
    13. Member Crispyfritter's Avatar
      Nov 21st, 2001
      SW KS
      11,729
      01-27-2016 10:31 AM #87
      I found a package deal for a 6.0L (LQ4, I believe)a rebuilt 4L65, standalone harness and tuned ECU.
      It should be shipped in a couple of weeks! I'm pumped!
      Chris
    14. Geriatric Member Aonarch's Avatar
      Dec 4th, 2006
      Atlanta, GA
      40,400
      ATS-v | All Track CEL
      01-27-2016 10:39 AM #88
      Chris
      Solid!!!
    15. Senior Member
      Nov 7th, 2001
      The Village
      22,999
      KAR 120C
      01-28-2016 10:21 PM #89
      Sweeeeeet. That thing should haul bass.
    16. Member Crispyfritter's Avatar
      Nov 21st, 2001
      SW KS
      11,729
      01-29-2016 10:45 AM #90
      Yeah, it should be pretty snappy. I imagine it will make a healthy 350HP, get better fuel mileage and be a cross country driver, should I opt to take an epic road trip.
      Chris
    17. 01-29-2016 05:03 PM #91
      I hear ya. Once I get my Grand Prix running with the 454, I am dying to go get a photo of it parked in front of this church:
      Dempsey Bowling
    18. Member SchnellFowVay's Avatar
      May 20th, 2001
      Las Vegas, NV
      13,378
      '17 STI Limited, Ross Edition
      01-29-2016 05:54 PM #92
      Is this from kill bill? where is this?
    19. Banned patrickvr6's Avatar
      Dec 29th, 2001
      Marietta GA
      10,285
      '77 Bronco '85 Toyota 4x4 '87 930 '91 M5 '08 Xterra
      01-29-2016 06:12 PM #93
      Quote Originally Posted by SchnellFowVay View Post
      http://www.thekillbillchurch.com
    20. Member Crispyfritter's Avatar
      Nov 21st, 2001
      SW KS
      11,729
      02-12-2016 02:15 PM #94
      I love when I get stuff in the mail.
      Starting to get real. I'll be ordering motor mounts, headers and a trans cross member today.
      Woot!
      Chris
    21. Geriatric Member ValveCoverGasket's Avatar
      Mar 20th, 2002
      trendy homeless camp, OR
      39,424
      german and british
      02-12-2016 02:29 PM #95
      nice!
      i might have missed it, but what did you say the modern engine had for management?
    22. Member westopher's Avatar
      Mar 17th, 2013
      Vancouver
      1,174
      98 M3
      02-12-2016 02:31 PM #96
      This is awesome. The car I learned to drive stick on was my Mom's 98 z28 when I was 15. While far less bitchin than your example, lighting up those 275s or whatever they were was so ****ing fun.
      I've got a lot of interest in pretty much all generations of the Camaro.
      98 m3
      99.9k and about to officially become worthless.
      Technoviolet/anthrazit cloth
    23. Member Crispyfritter's Avatar
      Nov 21st, 2001
      SW KS
      11,729
      02-12-2016 02:43 PM #97
      nice!
      Its got a stock computer, but modified for tune and removal of VATS, EGR and downstream O2's.
      Chris
    24. Member
      Aug 21st, 2009
      LA LA Land, CA
      10,587
      02-12-2016 02:45 PM #98
      Is that the Kill Bill church???
      Quote Originally Posted by Fritz27 View Post
      You're a self-serving Japanese car-hating asshat.
      I drive two Japanese cars.
    25. Member Crispyfritter's Avatar
      Nov 21st, 2001
      SW KS
      11,729
      02-12-2016 03:04 PM #99
      Quote Originally Posted by DJMRDARK View Post
    26. Member
      Aug 21st, 2009
      LA LA Land, CA
      10,587
      02-12-2016 03:35 PM #100
      ROADTRIP!!!
      My wife would never understand.
