Anyone looking to trade their car?
First and last Images are how it looks currently with the wider beach bars.
I have a 1995 Limited edition FLSTN Harley with tons of Chrome and top notch saddle bags. 16k Miles ONLY!!!!!
The Harley Davidson Nostalgia was only produced in very limited numbers from 1993 - 1996. Only 2700 were produced per year. The 1993's were numbered on the dash and the 94, 95, & 96' model years you can look under the speedometer and is numbered there. The bike originally was only suppose to be built for Harley Davidsons 90th Anniversary, but sold out so fast they continued to sell the bike as a limited production. From 1993 through 1996 these bike were always first come first serve ordered, then wait until it arrives. They were not common on a showroom floor for sale unless the person that ordered backed out. These bikes only came in one two tone color option each year, another words, you had no choice on color. The 1993 was Vivid Black and Birch White with inserts on the leather products of two toned colored cow hide. Each bike was completely different because they were cut from different parts of the two color cows hide, hence the nick name MOO GLIDES. 1994 was Brilliant Silver and Artic White, 1995 sold out the quickest and was Vivid Black and Metallic Grey, and 1996 was Mistique Green and Platinum Silver.
Bike is extremely clean runs great and ready to ride or show. There is an elite owners group that eat breathe and sleep the 93 to 96 Nostalgias. This bike has original paint and parts and wide white walls. The exhaust is not original equipment. This bike is a long term investment and will not depreciate if kept in original condition and clean. It will only appreciate. It has a Clear title with matching factory original frame and motor identification numbers. Sold as-is, no warranties expressed or implied, please write before bidding if you have any question.
Bike includes:
Tons of Chrome parts, Ness Chrome Tank cover, Saddlebags ( the bags alone are $1,000) ( Iron Bags - Iron Max )
COLOR: Black on Charcoal with plum pinstriping
Engine and transmission:
Engine type: 2 cylinders, 4-stroke, 45° V-twin
Displacement: 1338 cc (81.75 cubic inches)
Bore × stroke: 3.46 inch × 4.25 inch (undersquare - longstroke)
Cooling system: Air cooled
Power: 47.59 HP (35 kW) @ 4900 rpm
Torque: 86.3 Nm (63.65 lb-ft) @ 2400 rpm
Throttle: Cable operated
Valves:
Valve train: OHV, variable
Valves per cylinder: 2
Fuel and ignition:
Sparks per cylinder: 1
Fuel supply system: Carburetor
Compression: 8.5:1
Engine mounting: Transverse
Lubrication system: Dry sump
Gear box: Manual 5-speed
Clutch: Wet, multiple discs, cable operated
Final drive: Belt
Starter: Electric
Dimensions:
Seat height: 26.4 inch
Weight:
Dry weight: 793.7 lbs
Chassis and suspension
Frame type: steel, Double cradle frame
Front:
Suspension: Cartridge
Brake: Single Disk
Rear:
Suspension: mono shock, Swingarm
Brake: Disk
Other
ABS available: No
Fuel capacity: 5.2 gals
Number of riders: 2 persons
