Car runs like **** when stopped, missfires on all cyl
not my car but the guy is pretty broke, and hopes to fix it first try, any help?
I think a huge vacuum leak at the BB since its only on stop
VCDS Version: Release 11.11.5
Data version: 20121222
Friday,22,February,2013,13:37:38:61598
Chassis Type: 9M - VW Jetta IV
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: 3VWSE69M22M135593 Mileage: 158540km/98512miles
Address 01: Engine Labels: 06A-906-032-AWP.lbl
Part No: 06A 906 032 HF
Component: 1.8L R4/5VT G 0006
Coding: 07550
Shop #: WSC 00066
VCID: 69D7425513897C50962
3VWSE69M22M135593 VWZ7Z0A4697734
9 Faults Found:
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 35-00 -
16514 - Oxygen (Lambda) Sensor B1 S1
P0130 - 35-00 - Malfunction in Circuit
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 -
16685 - Cylinder 1
P0301 - 35-00 - Misfire Detected
16687 - Cylinder 3
P0303 - 35-00 - Misfire Detected
16688 - Cylinder 4
P0304 - 35-00 - Misfire Detected
16497 - Intake Air Temp. Sensor (G42)
P0113 - 35-10 - Signal too High - Intermittent
16486 - Mass Air Flow Sensor (G70)
P0102 - 35-10 - Signal too Low - Intermittent
16686 - Cylinder 2
P0302 - 35-00 - Misfire Detected
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09A-927-750.lbl
Part No: 09A 927 750 T
Component: AG5 Getriebe 09A 0193
VCID: 3C79CB012C9B39F83D4
4 Faults Found:
00268 - Solenoid Valve 6 (N93)
30-10 - Open or Short to Plus - Intermittent
01166 - Engine Torque Signal
16-10 - Signal Outside Specifications - Intermittent
00526 - Brake Light Switch-F
28-10 - Short to Plus - Intermittent
01316 - ABS Control Module
49-10 - No Communications - Intermittent
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
Part No: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0018945
Shop #: WSC 00028 000 00000
VCID: 3265E539AEDFFF88E78
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 04 AIRBAG VW61 0202 0001
Coding: 12340
Shop #: WSC 00066
VCID: 2753046DC51D8A20406
5 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
00592 - Seat Belt Switch; Passenger (E25)
32-10 - Resistance too High - Intermittent
01218 - Side Airbag Igniter; Passenger Side (N200)
00591 - Seat Belt Switch; Driver (E24)
01217 - Side Airbag Igniter; Driver Side (N199)
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0003
Coding: 00118
Shop #: WSC 00028
VCID: 2F63EC4DEDEDD260886
No fault code found.
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 N
Component: KOMBI+WEGFAHRSP VDO V62
Coding: 07234
Shop #: WSC 00000
VCID: 336BE03D01C5F680ECE
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway KCAN 0001
Coding: 00006
Shop #: WSC 00028
VCID: F0E1AF31B0530D9851C
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00028
VCID: 3773D42D15BD1AA0D06
Subsystem 1 - Part No: 1C1959801A
Component: 1H Tõrsteuer.FS KLO 0004
Subsystem 2 - Part No: 1C1959802A
Component: 1H Tõrsteuer.BF KLO 0004
Subsystem 3 - Part No: 1C0959811A
Component: 1H Tõrsteuer.HL KLO 0004
Subsystem 4 - Part No: 1C0959812A
Component: 1H Tõrsteuer.HR KLO 0004
3 Faults Found:
00912 - Window Regulator Switch; Front Left (E40)
27-10 - Implausible Signal - Intermittent
00913 - Window Regulator Switch; Front Right Driver (E81)
01358 - Internal Central Locking Switch; Driver Side (E150)
