Fourtitude.com - Audi RS Q3 Official Details
    Results 1 to 25 of 48
    1. Global Moderator
      Apr 9th, 2004
      Hershey, PA (USA)
      16,868
      Blog Entries
      965
      2013 Audi TT S line competition, 1984 Audi 4000S quattro, 2000 Chevrolet Silverado 1500
      02-19-2013 08:38 PM #1
      quattro GmbH chief van Meel: “The compact Audi RS Q3 creates a new class in the SUV segment.”
      Combines excellent power with outstanding everyday practicality
      2.5 TFSI with 228 kW (310 hp) and 420 Nm (309.78 lb-ft), 0 to 100 km/h (62.14 mph) in 5.5 s
      Audi is presenting the RS Q3 at the Geneva International Motor Show, the first RS model for the successful Q line-up. It combines outstanding everyday practicality with dynamic driving performance: It takes just 5.5 seconds to complete the sprint from 0 to 100 km/h (62.14 mph), and its top speed is electronically governed to 250 km/h (155.34 mph). The 2.5-liter five-cylinder turbo produces 228 kW (310 hp) and has an average fuel consumption of just 8.8 liters of fuel per 100 km (26.73 US mpg).
      “The RS Q3 transfers the performance philosophy of Audi to the compact SUV segment, thereby creating a new performance class,” says Franciscus van Meel, Managing Director of quattro GmbH. “In addition to the RS 5 Cabriolet, RS 6 Avant and RS 7 Sportback, the RS Q3 is the fourth RS model that we are launching on the market in 2013. The RS family is growing to eight members – more than ever.” The RS Q3 combines typical RS properties such as high performance and driving pleasure with lifestyle qualities and high utility value. The Audi RS Q3 was developed by quattro GmbH which is a wholly-owned subsidiary of AUDI AG.
      An award-winning high-performance engine, the 2.5 TFSI, is at work under the hood of the RS Q3. This five-cylinder engine has been named “International Engine of the Year” in its class for three consecutive years since 2010 by an international jury of automotive specialists. From 2,480 cc of engine displacement, the turbocharged direct-injection engine produces a maximum power of 228 kW (310 hp) at 5,200-6,700 rpm; its maximum torque of 420 Nm (309.78 lb-ft) is available between 1,500 and 5,200 rpm. These two values signify that the RS Q3 is unrivaled in its competitive field. This five-cylinder is a special engine, beginning with its fundamental concept. It is familiar from the TT RS and RS 3 Sportback, and quattro GmbH modified it for use in the RS Q3.
      The 1-2-4-5-3 ignition sequence, supported by the geometry of the air induction and exhaust systems, generates a sporty engine sound that first made Audi popular back in the 1980s.
      Drivers can influence the flap control for the exhaust system and the accelerator characteristic by choosing one of the modes auto, comfort and dynamic using the standard Audi drive select system. In the dynamic mode, engine response is sharper and the engine sound more intensive.
      The 2.5 TFSI accelerates the Audi RS Q3 from a standstill to 100 km/h (62.14 mph) in just 5.5 seconds – the best performance value in this segment. The vehicle’s top speed is electronically limited to 250 km/h (155.34 mph). In the RS Q3, the Audi five-cylinder engine is working together with a standard start-stop-system for the first time. Other efficiency measures such as a regulated oil pump, which only pumps lubricant when needed, contribute to the car’s low average fuel consumption of 8.8 liters of fuel per 100 km (26.73 US mpg) which equates to 206 grams CO2 per km (331.52 g/mile).
      A standard seven-speed S tronic transfers power to the drivetrain. It was designed in a compact three-shaft configuration, and its seventh gear has a long gear ratio to save on fuel. Drivers can choose between the D and S modes for automatic shifting of the dual clutch transmission, or they can shift manually – using the shift paddles on the steering wheel or the selector lever that sports a unique RS design. The Launch Control function controls acceleration from a standstill to attain optimal traction.
      The heart of the quattro permanent all-wheel drive system is the hydraulically operated and electronically controlled multi-plate clutch located at the rear axle. It ensures proper distribution of torque between the front and rear axles.
      The Audi RS Q3 impresses with dynamic and stable handling without sacrificing comfort. The RS sports suspension lowers the body of the compact high-performance SUV by 25 mm (0.98 in). The battery is located in the luggage compartment to achieve better weight distribution. The independent rear wheel suspensions are controlled by four links.
      The electro-mechanical rack and pinion steering system operates very efficiently, conveying a stiff, precise steering feeling. An electro-mechanical parking brake and hill hold assist are also standard.
      In the RS Q3, the internally ventilated and perforated brake discs at the front wheels have a wave design with wave-shaped outer contours, which saves approx. one kilogram (2.20 lb) of weight at the front wheels. The discs have a diameter of 365 mm (14.37 in), and they are gripped by eight-piston calipers painted black with RS logos. The electronic stabilization control (ESC) has a sport mode, and it can also be deactivated entirely.
      The Audi RS Q3 comes on the German market with standard 19-inch alloy wheels. Three versions of 20-inch wheels are offered as well. One of these is the exclusive 5 dual-spoke V design, which is based on the Audi RS Q3 concept car that was shown at the 2012 Auto China motor show.
      In addition to its engine, the Audi RS Q3 also demonstrates its special status within the Q3 line-up with a number of visual highlights. RS-specific design details emphasize the confident look of the compact, high-performance SUV. They consist of body accents and roof rails in matt aluminum, special door sill plates and door trim strips, a high-gloss black honeycomb front grille, RS front bumper and quattro emblem in the front air intake. A large roof spoiler, rear bumper with distinctive diffuser insert, large elliptical tailpipe and an RS Q3 logo accentuate the rear. At a length of 4,410 mm (14.47 ft), the dynamic top model is 25 mm (0.98 in) longer than the Audi Q3. It weighs in at 1,730 kg (3814.00 lb).
      The Audi RS Q3 can also be customized by one of two optional styling packages – matt aluminum or black. Styling features include the flaps in the side air intakes, the trim on the diffuser and the fins on the roof spoiler. The Audi RS Q3 is available in eight exterior colors, including the exclusive Sepang Blue pearl effect.
      The sporty lines of the exterior are continued in the interior styling. The instrument cluster has gray gauges with white scales and red pointers. Contrasting stitching in rock gray trim the three-spoke multifunction steering wheel with its flat bottom as well as the gear selector lever. The MMI and driver information system displays welcome the driver with the RS logo. Drivers can call up the boost pressure, oil temperature and a lap timer via the RS menu in the driver information system.
      Along with the pedals, a foot support also shines in aluminum look, and the standard inlays are in piano finish black. quattro GmbH offers aluminum race or carbon as alternatives here. Black headlining is standard, and lunar silver headlining is optional.
      Sport seats with embossed RS Q3 logos are also standard and are upholstered in black Alcantara/leather. Customers can also choose the optional Fine Nappa leather in black or lunar silver with contrasting stitching in rock gray or the design package with diamond stitching.
      The cargo area has a base capacity of 356 liters (12.57 cubic ft), which can be increased to 1,261 liters (44.53 cubic ft) by folding down the split rear seat backs. A practical reversible loadliner is standard. Those wishing to transport even more cargo can order the towing bracket that is offered for the RS Q3.
      Other standard features of the Audi RS Q3 include – in addition to the RS-specific driver information system – park assist plus, Audi sound system with ten loudspeakers, xenon plus headlights and LED tail lights. When they are not lit, the tail lights display a dark red tint.
      In the infotainment area, a modular component system offers a wide range of options; at the top there is the hard-drive based navigation system, MMI Navigation plus. The surround sound system from Bose drives 14 loudspeakers with up to 465 watts of output power, while the Bluetooth car phone online together with WLAN hotspot connects the compact high-performance SUV with the Internet and brings the online services of Audi connect into the vehicle. Highly advanced driver assistance systems round out the options program.
      In Germany, the base price is €54,600, and deliveries begin in fall 2013.
      More pics HERE: http://fourtitude.com/galleries/?c=s...rom%202013/(EU)
    3. 02-19-2013 08:44 PM #2
      RS6 avant please!
    4. 02-19-2013 08:59 PM #3
      dont want truck, want rs3 on mbq platform
    5. Member rconn14's Avatar
      Sep 6th, 2006
      Connecticut
      5,642
      2004 R32, 2012 Abarth
      02-19-2013 09:02 PM #4
      I don't care what you do to a Q3, I still don't want one.
      Quote Originally Posted by mookieblaylock View Post
      X2
      Instagram: @clink_clank_clunk
      Feb 18th, 2006
      PA
      4,426
      02-19-2013 09:07 PM #5
      It seems underpowered for an RS car.. The RS Q3 concept had 360hp, which seems more like it
      As with the TT RS, the RS Q3 Concept's I-5 produces 360 hp and likely the same 343 lb-ft of torque.
      http://www.motortrend.com/roadtests/...pt_first_look/
      2014 Porsche 991 Turbo S
      Aug 15th, 2009
      Philadelphia, PA
      696
      2000 Jetta VR6, 2010 GTI & 2014 JSW
      02-19-2013 09:46 PM #6
      Avant please
      2010 GTI & 2002 Passat Wagon
    8. Member rconn14's Avatar
      Sep 6th, 2006
      Connecticut
      5,642
      02-19-2013 09:48 PM #7
      Quote Originally Posted by EKaru View Post
      Eh, it being an A3-level vehicle it doesn't seem that underpowered. I don't think anyone would have a real issue even if the RS3 had "only" 310 hp. The Q3 is pretty small. More power wouldn't have hurt, but eh, the people that buy this don't really give a damn about how fast it goes anyway - or they'd get a car instead of a cute ute.
    9. Senior Member Mazda 3s's Avatar
      Nov 12th, 2003
      Garner, NC
      22,336
      2017 Subaru Outback 2.5i Limited, 2013 Hyundai Elantra Limited
      02-19-2013 09:51 PM #8
      What an oddly proportioned duck of a trucklet. What a waste. Gimme an A4/S4 Avant.
      "Of course that's just my opinion; I could be wrong."
      Quote Originally Posted by The Igneous Faction
      Have you ever popped the hood on a powerstroke E350?
      Quote Originally Posted by WhistlerYOW
      No, I got good grades in school
    10. Member JDBVR6's Avatar
      Dec 28th, 2006
      Houston, Tx
      2,287
      2016 GTI DSG Performance Package, LP and DCC
      02-19-2013 11:44 PM #9
      I second that.
      Q3/ RS Q3 =
    11. Senior Member Ryukein's Avatar
      Dec 10th, 2006
      Detroit
      26,678
      1984 Mercedes-Benz 300TDT, 1994 Miata R-Package
      02-19-2013 11:49 PM #10
      It's interesting that they're releasing an RS Q3 before an S Q3
    12. Banned Fritz27's Avatar
      Mar 8th, 2003
      Brickell
      26,435
      1986 Legs and/or 2014 Blue Non-MANual European Turbo Hatch
      02-20-2013 12:05 AM #11
      This thing is the bomb. Only thing is I wish it had dual exhausts.
      Any chance this thing comes to the Land of the Free?
    13. 02-20-2013 12:14 AM #12
      Looks cool, but would rather have the RS3 / S3 sportback in the USA
    14. Member SoSuMi's Avatar
      May 14th, 2004
      Akron, OH
      1,003
      2017 BMW 330i Touring / M Sport / Estoril Blue
      02-20-2013 12:36 AM #13
      Quote Originally Posted by Fritz27 View Post
      ...Any chance this thing comes to the Land of the Free?
      Not a chance. And it won't come to America either
      Mark me down for another of those "gimme an S4 Avant" chumps... or at least shove the damn 3.0 sc engine in the allroad.
      ____________________
      Byron
    15. Member MrKevkevL's Avatar
      Nov 6th, 2009
      Des Moines, IA
      1,951
      2015 F30 BMW 328i
      02-20-2013 12:40 AM #14
      I want it. Too bad it won't come to our shores though
      Past: 1999.5 MKIV GTI, 2004 Audi S4, 2009 MKV Jetta, 2009 MKV Golf, 2007 B7 Audi A4
      Quote Originally Posted by Roketdriver View Post
      Toyota is kind of like the Black Eyed Peas. The majority of their product line is cars for people who don't like cars.
    16. Senior Member feels_road's Avatar
      Jan 27th, 2005
      East Bay Area
      23,391
      2016 MkVII e-Golf, 2017 MkVII Golf Alltrack, 2000 B5 4M Passat Wagon
      02-20-2013 03:21 AM #15
      Eh, over 300 hp and ft-lbs is quite good for a small CUV; also, the power and torque bands are pretty wide (310 hp @ 5,200-6,700 rpm / 309.78 lb-ft between 1,500 and 5,200 rpm; i.e., 80% of peak power is available from 4,160 - 6,700 rpm, or a factor of 1.6 - that's huge!). However, if you compare to the new R engine (almost 300 hp out of 2l), it does seem a bit detuned.
      I like it, I even like the looks of it - but the hatch is too small. So I'll chime in re wagon.
      After incessant complaints from a to z, I am now calling all of my characters "special."
    17. Member warren_s's Avatar
      Apr 26th, 2009
      5,382
      2016 TTS
      02-20-2013 05:16 AM #16
      This isn't a "truck" by any stretch of the imagination. It's built on the same car platform as the Audi RS3 and has roughly the same dimensions, but it's got a higher ride height (easily fixed) and is a few inches taller.
      MQB RS3 is probably still a few years off, too.
    18. Senior Member feels_road's Avatar
      Jan 27th, 2005
      East Bay Area
      23,391
      02-20-2013 05:45 AM #17
      Quote Originally Posted by warren_s View Post
      This isn't a "truck" by any stretch of the imagination. It's built on the same car platform as the future Audi RS3
      FTFY.
    19. Member Professor Gascan's Avatar
      Sep 11th, 2002
      Canada
      10,846
      02-20-2013 08:02 AM #18
      Quote Originally Posted by feels_road View Post
      FTFY.
      No, you made it incorrect. The Q3 is on the PQ35 platform. It was out before MQB was announced.
    20. Senior Member FlashRedGLS1.8T's Avatar
      Apr 17th, 2001
      Ohio
      23,893
      02-20-2013 08:04 AM #19
      Do want! I love that thing.
    21. Senior Member feels_road's Avatar
      Jan 27th, 2005
      East Bay Area
      23,391
      02-20-2013 08:10 AM #20
      Quote Originally Posted by Professor Gascan View Post
      You sure? I guess I am wrong, then.
    22. Member warren_s's Avatar
      Apr 26th, 2009
      5,382
      2016 TTS
      02-20-2013 08:24 AM #21
      It's really confusing right now. VW has said that it'll be several years before everything is switched over to MQB, which makes sense since they can't just redesign every car from the ground up all at once. Even at the factory in Spain where the current Q3 is built, they just started building the MQB Seat Leon a couple of months ago, but the Q3 is still PQ35. So the factory is ready to build an MQB Q3 but it's not ready yet.
    23. 02-20-2013 08:39 AM #22
      What is the point of crap like this? RS needs to get their head out of their ass and offer us an rs4 and an rs6. They have the weakest lineup by far versus AMG and M.
    24. 02-20-2013 09:13 AM #23
      Quote Originally Posted by Rob View Post
      They do make an RS6, as far as I know its VW/AOA's decision not to bring it to the states.
    25. Global Moderator
      Apr 9th, 2004
      Hershey, PA (USA)
      16,868
      Blog Entries
      965
      02-20-2013 09:46 AM #24
      Quote Originally Posted by SoSuMi View Post
      Don't bet big amounts of money on that. It could happen and there's probably more case for it than an RS 3 Sportback.
    26. Global Moderator
      Apr 9th, 2004
      Hershey, PA (USA)
      16,868
      Blog Entries
      965
      02-20-2013 09:49 AM #25
      These things don't happen overnight. The Q3's been out about two years now. Likely they had the option to push off two years by going MQB or they could have the product two years earlier and go PQ35.
