+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 84
Thread: Cracks found in A380 "non critical" wing attachments
    May 8th, 2002
    Plano, TX
    5,752
    2004 Toyota Corolla (freshly damaged from an idiot in a Jeep), 2007 Kia Rondo, 2008 Ural Gear Up
    01-10-2012 09:18 AM #1
  2. Member Ikey3125's Avatar
    Jan 27th, 2008
    Fairchild AFB/Spokane WA
    4,636
    08 .:R 2763/5000
    01-10-2012 01:47 PM #2
    You realize every plane has cracks in it right?
    Its the nature of metals and the fatigue put on them from flight.
    May 8th, 2002
    Plano, TX
    5,752
    01-10-2012 02:09 PM #3
    Quote Originally Posted by Ikey3125 View Post
    I just posted it as a news story for the aviation buffs on here - nothing more, nothing less
  4. 01-10-2012 03:49 PM #4
    Yeah, but after only a few years in service (the plane they detected the cracks on was pulled out of service in 2010) there's either a design issue or manufacturing problem.
  5. Member Ikey3125's Avatar
    Jan 27th, 2008
    4,636
    08 .:R 2763/5000
    01-10-2012 04:33 PM #5
    Quote Originally Posted by joness0154 View Post
    Or they'll rivet a beef up plate to the area and put it back in service.
    Its how we fix airplanes...
    Dec 11th, 2002
    4,730
    '03 Golf TDI
    01-10-2012 07:21 PM #6
    Not, generally speaking, in numerous 1- or 2-year-old airplanes.
    If it's not foggy
    and you have your fog lights on
    you are a doofus.
    "Pro Tip: Don't **** with people who've been trollin' longer than you've been alive." - OOOO-A3
  7. 01-10-2012 07:44 PM #7
    I understand that part.
    What I'm trying to say is that cracking in a part that's so new is not normal under these circumstances. It can lead to some pretty serious ****.
  8. Member Ikey3125's Avatar
    Jan 27th, 2008
    4,636
    08 .:R 2763/5000
    01-10-2012 08:25 PM #8
    True, lets blame the French...its what I do whenever I can
    [edit] being this is cracked on 3 different aircraft...its probably gonna be a normal "issue"
  9. Member
    Dec 11th, 2002
    4,730
    '03 Golf TDI
    01-10-2012 11:03 PM #9
    +1
    If it's not foggy
    you are a doofus.
  10. Member Zombiee313's Avatar
    Apr 27th, 2011
    Bay Area, CA
    247
    Old Ford Truck
    01-10-2012 11:28 PM #10
    screw that...
    Quote Originally Posted by Elbows View Post
    You should instead be praising the fact that life is so good, and safe that you can be afforded the luxury to be outraged by the death of one civilian, at the other end of the world. That's phenomenal.
    Quote Originally Posted by Jim Harbaugh
    Who's got it better then us?!? ...... Nooooo-body!!!
  11. Member
    Sep 30th, 2009
    Guelph, ONT \ Daytona Beach, FL
    850
    06 Jetta 2.5L 5spd (LSD+ .717 TDI 5th swap)
    01-11-2012 10:04 AM #11
    ...You can't rivet CFRP
    It is very difficult to make consistent and equal parts from carbon fiber and other composites. On the other hand for metals it is much easier. The lay-up process for CFRP is and can be very complicated. They have been switching to robots with have certainly helped but extremely expensive. To repair CFRP (holes or patches) is a long and tiring process in the industry not only are there miles of paper work but the engineers must run countless models on the modification (depending where the patch is needed, key stress points or load paths etc) to insure it will work and is safe. There are still huge areas of unknown with CFRP and that is why boeing took forever to come out with the 787 and rightfully so. There will be a number of problems for years to come before we can get better at this.
    C2 tune, Peloquin LSD, .717 TDI 5TH gear swap, USP test pipe, AWE exhaust (AMAZING), BSH CAI, H&R street sport coilover + 25mm RSB, neuspeed short shifter, 17x8 BBS RGR. **********FOR SALE THREAD:********** http://forums.vwvortex.com/showthrea...-%28OEM-LED%29*****http://forums.vwvortex.com/showthrea...0#post76396880
  12. Member Zombiee313's Avatar
    Apr 27th, 2011
    Bay Area, CA
    247
    Old Ford Truck
    01-11-2012 06:02 PM #12
    Its how we fix airplanes that are made out of metal...
    FTFY
    ever heard of composites? yeah not all airplanes are made out of metal
  13. Member Ikey3125's Avatar
    Jan 27th, 2008
    4,636
    08 .:R 2763/5000
    01-11-2012 06:31 PM #13
    Quote Originally Posted by Zombiee313 View Post
    FTFY
    I didn't read the article...and we don't use composites on structural parts of military aircraft...just skins. but what do I know, I've never fixed a plane...you must have
    But reading the article finally...they have repair procedures in place...
    Also the cracks are on ribs, imagine that, a structural component, therefore, probably an aluminum rib, so again, rivet beef up plate on.
  14. Member
    Sep 30th, 2009
    850
    01-11-2012 09:23 PM #14
    Just under half of the ribs are CFRP and the spars are made out of a special 7 series aluminum alloy. It really depends on where the cracks are and how high the stresses and their concentration are. (And yes I have a good amount of knowledge in here as im an aerospace engineer)
  15. Member chrismkay3's Avatar
    Jan 16th, 2008
    Winnipeg
    2,607
    e46 m3
    01-11-2012 10:46 PM #15
    Quote Originally Posted by Anile_eight View Post
    bondo, lots and lots of bondo
    and i'm only half kidding. in engine repair on composite (non-metal) parts, most repairs i've seen consist of cleaning up the crack and applying a high-strength filler material then some sort of protective film
    i think the scarier part about new CFRP parts is they cannot be NDT'd the same way metal parts can. How do you detect cracks? you cannot liquid penetrant inspect it, you can't eddy current inspect it, how do you know?
  16. Member Zombiee313's Avatar
    Apr 27th, 2011
    Bay Area, CA
    247
    Old Ford Truck
    01-11-2012 11:42 PM #16
    Why would the do the ribs half and half like that?
    How would they repair a structural rib that is constructed out of CFRP?
  17. Member Zombiee313's Avatar
    Apr 27th, 2011
    Bay Area, CA
    247
    Old Ford Truck
    01-11-2012 11:46 PM #17
    of course they have repair procedures in place
    of course the cracks will be on structural components... those are the parts of the plane that handle the stresses of flying... Also I highly doubt that the composite sections have a bunch of metal bracing... that would defeat the WHOLE POINT of being built mainly from CFRP. The article does not specifically mention whether it is in a CFRP or aluminum part of the aircraft that is cracking. I love how you automatically know how exactly how they would fix it without knowing anything about it..... And yes you are right it if was an aluminum rib they could rivet a beef up plate there.... but if it is two different components I am pretty sure they can't do that... also if it was a composite you can't just rivet into that, especially if it is not a flat surface or at the end of the rib(like they said in the article the location is at)!!
    here take yourself to school and learn a little ok
    http://en.wikipedia.org/wiki/Carbon-...forced_polymer
    http://www.sandwichpanels.org/articles/wing_repair.html
    I have fixed plenty of planes... remember I used to be an A-10 CC.... I KNOW we have talked about that before... do you really want me to answer your sarcastic question of what you know??... your response is yet anther reason why I don't like you and think that you give Air Force mechanics a bad name
  18. Member Zombiee313's Avatar
    Apr 27th, 2011
    Bay Area, CA
    247
    Old Ford Truck
    01-11-2012 11:54 PM #18
    Quote Originally Posted by chrismkay3 View Post
    Yeah I have seen that repair method used on engine parts and some non-structural composite parts.
    They can use ultrasonic, thermal, and other methods that do not depend on magnets or conductivity.... also check visually for delamination, visible cracks, or loose fibers
  19. Member Ikey3125's Avatar
    Jan 27th, 2008
    4,636
    08 .:R 2763/5000
    01-12-2012 01:35 AM #19
    Oh yeah...now I remember you...as for AF mechs a bad name...think we all give ourselves a bad name...
    But FYI, heavies suck...I wanna go back to fighters so bad...
    But still...I blame the French...seen a show, think it was on Discovery, about building the A380, and it seemed that the jet was rushed...
  20. Member Zombiee313's Avatar
    Apr 27th, 2011
    Bay Area, CA
    247
    Old Ford Truck
    01-12-2012 02:00 AM #20
    Yeah heavies do suck
    I blame France for everything.... Or I do like to blame Canada a lot too
    Every jet now-a-days is rushed... and if it isn't rushed then it goes MASSIVELY overbudget
  21. 01-12-2012 08:13 AM #21
    I've seen it on primary structure as well. It all depends on the part and the type/extent of damage.
    Also, you forgot the tap test. It's usually the first step in NDI of composites. Just a simple hammer with a flex shaft that will bounce on properly laid up composites and pretty much fall dead on delaminated stuff.
  22. Member
    Sep 30th, 2009
    850
    01-12-2012 01:51 PM #22
    First off it's Airbus... They done done crazier things.
    The inner ribs are made mostly out of the 7 series aluminum as it is a much more critical area which needs to be structurally sounds. Airbus can't take chances in that area. The chances are to do with the lack of relative knowledge of CFRP comapred to the aluminum. The outer ribs just past quarter span is cfrp to save weight.
    There are a couple different ways that you can repair cfrp but i'll assume Airbus has a proprietary way of doing this depending on where and what the damages are. A "simple" patch and lots of FEA on the work must be done. If it is not structural component it is much easier, similar to fiber glass repair. Structural parts like holes in the wrong spot of manufacturing defects. The engineers would go through a very thorough process the company has planned out to decide if they can repair it and then what kind of repair they must make. If not they will have to make the component over again. This is a relatively unknown and hard part of cfrp.... lift span, repairs, cyclic loading, delamination etc...
  23. Member
    May 15th, 2007
    Fussa, Japan
    487
    01-12-2012 03:32 PM #23
    Wow, and I thought fighter pilots were a bunch of whiny babies lol, it's community wide!
  24. Member
    Sep 30th, 2009
    850
    01-12-2012 06:09 PM #24
    Quote Originally Posted by yz1337 View Post
    huh?
  25. Member
    May 15th, 2007
    Fussa, Japan
    487
    01-12-2012 06:20 PM #25
    huh?
    forgot to quote, was poking fun at ikey and zombie, fighter community babies
  26. Member Ikey3125's Avatar
    Jan 27th, 2008
    4,636
    08 .:R 2763/5000
    01-12-2012 06:38 PM #26
    we take after our pilots
  27. Member NZTIGUAN's Avatar
    May 22nd, 2008
    Alexandra, New Zealand
    2,419
    2013 Tiguan 07 Suzi Swift
    01-12-2012 07:24 PM #27
    If they can build and repair composite glider wings that will take the stresses shown in this pic then I don't think these repairs are as difficult as some seem to suggest. It's just a matter of new technology that needs new systems to handle it, doesn't mean it isn't just as good or possibly even better than other construction methods.
    Cheers
    Derek
    Alexandra New Zealand
    Second Tig, 2013, TDi, Auto, night blue, park assist 2, auto lights and wipers, RCD510, fogs, tow pack
    http://www.alexandra.co.nz/
  28. Senior Member J-Tim's Avatar
    May 26th, 2000
    29,368
    Blue Bavarian Wagon. Couple of Trek bikes and a pair of trainers.
    01-12-2012 07:34 PM #28
    To be fair to froggies, all wings for A380 are manufactured in England and then shipped to Toulouse for final assembly.
    Taking on them mountains. One hill at a time.
    http://imageshack.us/a/img42/5453/bikev.gif
  29. Member
    Sep 30th, 2009
    850
    01-12-2012 08:57 PM #29
    Lol I see.
    J-tim u are correct.
    Nztiguan:
    Stresses are different then deflection as shown in the picture of the glider. The stresses are much less in gliders than that in the a380 therefore allowing simpler repairs. The airline industry has beyond absurd standard which forces the airlines and companies to install rigorous repair specifications and methods. There are a number of fea analysis that are requires. Physically its not overly difficult but technically it was challenging.
    I dont agree. Composites have been around for more than thirty years in the industry, they just haven't been uses in this magnitude.
    Its the issue with the area of unknown which is the unpredictivity cfrp. The test results have a large range of results comparing them to aluminum especially A or B basis.
  30. Senior Member J-Tim's Avatar
    May 26th, 2000
    29,368
    01-12-2012 09:31 PM #30
    To anyone interested, there is a BBC series, called "How to Build:". One of the episodes is called "A Super-Jumbo Wing", where it goes into details on how an A380 wing is built, fitted and tested.
    Fascinating stuff.
  31. Member Zombiee313's Avatar
    Apr 27th, 2011
    Bay Area, CA
    247
    Old Ford Truck
    01-12-2012 10:04 PM #31
    Quote Originally Posted by NZTIGUAN View Post
    Cheers
    Who would want to fly a plane with no engines??
    I bet those same people would jump out of a perfectly good airplane too huh?
  32. Member Zombiee313's Avatar
    Apr 27th, 2011
    Bay Area, CA
    247
    Old Ford Truck
    01-12-2012 10:05 PM #32
    Quote Originally Posted by J-Tim View Post
    The french must have installed the wing wrong
  33. Member Ikey3125's Avatar
    Jan 27th, 2008
    4,636
    08 .:R 2763/5000
    01-13-2012 08:51 AM #33
    But didn't the Froggies design it?
  34. Member
    Sep 30th, 2009
    850
    01-13-2012 08:56 AM #34
    Haha, I have my glider's license as well as my private license and let me tell you it is certainly an awesome experience being up there! No vibrations, a little wisp from the air rushing by but it is so peaceful and so much fun you can stay up for hours if you know what you are doing!
    And no, never have been sky diving.
  35. Member Zombiee313's Avatar
    Apr 27th, 2011
    Bay Area, CA
    247
    Old Ford Truck
    01-13-2012 02:23 PM #35
    I was joking when I was making fun of gliders.
    My uncle has been flying gliders for years and years and years.... he used to do competitions also... no real idea how you can do that but yeah.
    My dad and I went and checked out a two seater glider for his club to buy (out in California) and I have always wanted to go up in it but I just haven't. He lives in Texas and I live in California.
+ Reply to Thread
