Yeah, put the correct part # in.
Jack
#1
My friend has 2003 jetta TDI and he recently had to replace ABS module.
Now the one he installed is different part number to the original but he said that he checked and they are supposed to be interchangable.
I think his car has ASR/ESP and the car module was taken out of doesnt?
The coding in the module is different since its from a car that only has ABS so i tried recoding but it wouldn't accept the new code. So just wondering if somone could help out with this and point me in the right dirrection.
heres is the full auto scan from his car
Thursday,16,December,2010,18:54:15:36874
VCDS Version: Release 10.6.3
Data version: 20101206
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Control Module Part Number: 1C0 907 379 M
Component and/or Version: ESP FRONT MK60 0102
Software Coding: 0019458
Work Shop Code: WSC 00066 000 00000
VCID: 3469CA7F2EBD
4 Faults Found:
00493 - ESP-Sensor Unit (G419)
014 - Defective - Intermittent
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
00526 - Brake Light Switch-F
01435 - Brake Pressure Sensor 1 (G201)
Monday,24,January,2011,20:29:24:36874
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: 3VWSP69M03M141047 Mileage: 74210km/46111miles
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 GN
Component: 1,9l R4 EDC G000SG 4308
Coding: 00002
Shop #: WSC 00066
VCID: 62C57C27C4C9
3VWSP69M03M141047 VWZ7Z0B6594167
2 Faults Found:
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 - -
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 C
Component: ABS FRONT MK60 0103
Coding: 0004097
Shop #: WSC 00066 000 00000
VCID: 2A55D407FC79
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 04 AIRBAG VW61 0202 0001
Coding: 12340
Shop #: WSC 00066
VCID: 27532D33EF6B
No fault code found.
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 806 L
Component: KOMBI+WEGFAHRSP VDO V64
Coding: 07332
Shop #: WSC 00000
VCID: 3061C66FDAA5
2 Faults Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
01330 - Central Control Module for Central Convenience (J393)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00066
VCID: F0E1866F9A25
3 Faults Found:
00778 - Steering Angle Sensor (G85)
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00066
VCID: 3773FD733FCB
Part No: 1C1959801A
Component: 1H Tõrsteuer.FS KLO 0009
Part No: 1C1959802A
Component: 1H Tõrsteuer.BF KLO 0009
Part No: 1C0959811A
Component: 1H Tõrsteuer.HL KLO 0009
Part No: 1C0959812A
Component: 1H Tõrsteuer.HR KLO 0009
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 D
Component: Radio ZSW 0010
Coding: 00401
Shop #: WSC 00066
VCID: 2147332B814F
2 Faults Found:
00878 - Connection to Speaker Front Left
36-10 - Open Circuit - Intermittent
01336 - Data Bus for Comfort System
37-10 - Faulty - Intermittent
End ---------------------------------------------------------------------
#3
#4
#5
Lot of people don't understand VW and Audi cars.
The number it self does not make difference in part number.
That Letter on the end is what makes difference is pat number.
1C0 907 379 M
1C0 907 379 C
#6
I guess that answers my question regarding putting a MK4 module or whole ABS system onto my Eurovan... Jack, this is Mike, I dropped by your shop yesterday to say hello.
#7
Hello Mike
Yup.
Thanks for coming by. Nice meeting you.
Let me know if I can be of assistance.
Remember, by appointment only.
Good luck with your swaps.
Best,
Jack
