Fourtitude.com - changing own oil (2010 Audi A3 TDi...service light)
    Results 1 to 12 of 12
    1. Member AllThingsGhetto's Avatar
      Jul 30th, 2004
      Southern California
      3,596
      ones that roll
      07-13-2010 03:40 AM #1
      Haven't purchased the Audi-Care just yet and about to change the oil. Anyone ever reset the "service due" light? If so, can you please give me a head's up on how to reset it for the next upcoming oil change? Thank you in advance.
      MYKEY
      IG: @royal_aloha
    3. Member AllThingsGhetto's Avatar
      Jul 30th, 2004
      Southern California
      3,596
      ones that roll
      07-13-2010 10:47 PM #2
      Does anyone change their own oil?
      MYKEY
      IG: @royal_aloha
    4. 07-13-2010 10:51 PM #3
      Quote Originally Posted by AllThingsGhetto View Post
      No one does. That's what Jiffy Lube is for.
      Read the manual.
    5. Member
      Feb 19th, 2010
      Greenville, SC
      288
      2010 Audi A3 TDI
      07-14-2010 02:14 AM #4
      FYI, the DSG requires a 30k mile service that requires a Vagcom tool to finish it off, so unless you have a buddy that has that capability. The Audi Care is well worth the $790....
      If the search function works yet, take a look, but the consensus is always that it is a good deal.
    6. Member trucaliber's Avatar
      May 13th, 2009
      Seattle
      191
      09-A3Q 06-A4Q 02-GTP 97-S10 79-MGB
      07-14-2010 10:54 AM #5
      I'm not sure about a 2010 TDI but my '09 2.0t requires a vag-com to reset the service light. I can reset the oil-change interval using the dash stalks but the service interval can only be viewed, not rest via the dash.
      I've since change the oil-change interval from 10k to 5k with my cable, along with a number of other things. So, If I ever pass down my A3 it'll nag the next driver at the correct interval.
      Invest in a cable now, you can thank me later
    7. Member AllThingsGhetto's Avatar
      Jul 30th, 2004
      Southern California
      3,596
      ones that roll
      07-15-2010 01:40 AM #6
      Quote Originally Posted by crew219 View Post
      Read the manual.
      I've read the manual. Want me to recite it backwards? I probably can at this point. LOL! It only tells me how to reset the mileage intervals, but doesn't tell me how to get rid of the "service due" light. Any ideas on this?
      MYKEY
      IG: @royal_aloha
    8. Member trucaliber's Avatar
      May 13th, 2009
      Seattle
      191
      07-15-2010 10:28 AM #7
      I've read the manual. [B]ut doesn't tell me how to get rid of the "service due" light. Any ideas on this?
      1. Get yourself a Hex+Can-USB cable from Ross-Tech.
      http://www.ross-tech.com/vag-com/hex-usb+can.html
      2. Download and install VCDS on a laptop
      http://www.ross-tech.com/vcds/download/current.html
      3. Plug cable into your car and laptop.
      4. Turn on car but do not start
      5. Fire up VCDS
      http://www.ross-tech.com/vcds/tour/main_screen.html
      6. Click on SRI Reset Button
      7. In the Operations drop down select "General Reset"
      http://www.ross-tech.com/vcds/tour/sri-reset.html
      8. Press the "Perform SRI"
      There are 1,001 things you can do with the Ross-tech cable. So it is a good investment at $350.
    9. Member SilverSquirrel's Avatar
      Jul 24th, 2006
      Gloucester, MA USA
      3,083
      '06 A3 3.2Q+'13 JSW Tdi
      07-15-2010 12:35 PM #8
      Quote Originally Posted by trucaliber View Post
      5. Fire up VCDS
    10. 07-15-2010 01:07 PM #9
      http://www.myturbodiesel.com/1000q/8...oil-change.htm
      btw, that forum is real good for anything TDI related.
    11. Member AllThingsGhetto's Avatar
      Jul 30th, 2004
      Southern California
      3,596
      ones that roll
      07-16-2010 02:50 AM #10
      Thank you all for the tips. I called Pops and it turns out he still has his VAG-COM that he uses on his 2002 Golf TDi. I'm assuming I can just update that via Ross-Tech?
      MYKEY
      IG: @royal_aloha
    12. Member AllThingsGhetto's Avatar
      Jul 30th, 2004
      Southern California
      3,596
      ones that roll
      07-27-2010 01:45 AM #11
      5. Fire up VCDS
      I've tried the above steps as my father had the VAG-COM this whole time I've been stressing about it. I've also downloaded the VCDS and when I hit SRI Reset, it says something about the cluster not existing. Anyone ever experience this? I feel like I am so close, yet so far.
      MYKEY
      IG: @royal_aloha
    13. Member AllThingsGhetto's Avatar
      Jul 30th, 2004
      Southern California
      3,596
      ones that roll
      07-28-2010 11:44 PM #12
      Any experiences? Please assist.
      MYKEY
      IG: @royal_aloha
